Old 02-06-2012, 11:55 PM   #26
slorio
slorio's Avatar
Re: V6 Pics
OK, here's mine. It's a 1966 305E with GM Hei distributor backed up by a 3 speed with overdrive transmission.
regards,
Steve
slorio is offline   Reply With Quote
Old 02-12-2012, 03:43 PM   #27
1972RedNeck
1972RedNeck's Avatar
Re: V6 Pics
More?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-12-2012, 10:27 PM   #28
A.T. RockDriller
A.T. RockDriller's Avatar
Re: V6 Pics
Neck....
I got yer pm...
My pc crashed a bit ago...first time back on on a lap-top.
I have no stored pic's and can't hook up my camera till I find the patch cord....but when I get her figured out, I'll send pics of my V-6 & P-steering.
See ya's
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 02-12-2012, 10:43 PM   #29
MusicMan70
MusicMan70's Avatar
Re: V6 Pics
Hope you don't mind Les, but your build is a Fav of mine; here's a pic from that...
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 02-13-2012, 11:41 AM   #30
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: V6 Pics
LOOK HERE!
GMC's Truck Built V-6 Engine!
http://www.6066gmcguy.org/gmcv6a.htm
V6 X 2
http://www.thunderv12.com/
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-15-2012, 10:51 PM   #31
T Herder
Re: V6 Pics
Here's mine, GM Throttle Body Injection, Mallory Maglite distributor, SM420 with a married Gear Vendors OD, divorced NP 205 transfer case, 4.56 final drive gears, BFG All Terrain 35's, plus a few other things.
Best regards,
T Herder
T Herder is offline   Reply With Quote
Old 02-15-2012, 10:58 PM   #32
A.T. RockDriller
Re: V6 Pics
Thanks MusicMan....
That's a great compliment....
Les Hunter
Old 02-16-2012, 01:51 AM   #33
Corts60
Just here to tinker
Corts60's Avatar
Re: V6 Pics
Best regards,
T Herder
Wow! Super nice! Can you tell us a bit more about how you did the TBI set-up? Parts used? Difficulties? I want to do this to my burb.
Old 02-16-2012, 10:35 PM   #34
T Herder
Re: V6 Pics
The TBI is a basic GM 1988 4.3L V-6 system. Stock throttle body, ECM, MAP sensor, temp sending unit, and O2 sensor. The O2 sensor is mounted in the drivers side exhaust manifold, the MAP is on the firewall just to the right of the heater box, the temp sender is tapped into the water manifold near the the factory temp sender, the ECM is under the dash on the passenger side, and the electric fuel pump is frame mounted on the passenger side. I formed new fuel supply and return lines to go back and down behind the head ending about 8 inches above the frame and used hose to connect to the new supply and return steel tubes. I ran the return line next to the supply line. I made the TBI adaptor out of 1 1/2 in thick aluminum.
Here's how to do the tank return:
Buy a new stock replacement fuel pickup and sending unit. Carefully remove the sending unit. Sand an area of approximately one inch diameter to bare metal on both sides of the new units mounting plate. Drill a 3/16” hole in the mounting plate and removed any burrs. Support the mounting plate on the internal side of the plate with a 9/16” six sided socket, the six sides towards the mounting plate. Take a 5/16” diameter tapered drift punch and drive it through the hole to form a tapered flare recess. This recess will be on the outside of the plate. Using a tubing bender, bend a 5/16” steel tube to parallel the fuel pickup line ending at the same bottom level BUT returning to the OPPOSITE side of the tank. Bend the external side of the return tube down to parallel the feed line. Carefully work the new return line through the 5/16” hole to what you THINK might be its final position. Then try fit it into the tank to confirm it will install with no problems. Once this is accomplished, Silver solder the 5/16” tube into the mount plate using 45% Silver solder.
If you’re hesitant to try this, practice first with a piece of scrap sheet metal and scrap tubing of the same gauge as your new replacement mounting plate.
I wanted the return to go back to the bottom of the tank. These tanks are vented and I didn't want fuel being sprayed back and vaporizing.
If you need more info let me know.
Best regards,
T Herder
Old 02-17-2012, 09:20 PM   #35
1972RedNeck
Re: V6 Pics
Originally Posted by A.T. RockDriller View Post
Thanks MusicMan....
What did that power steering pump come off of?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 02-18-2012, 12:00 AM   #36
A.T. RockDriller
Re: V6 Pics
The Hydro-Boost, p-steering box and pump all came off of a mid eighties 6.5 Diesel Blazer..
They sure don't need to be components from the same system.
The one ton 4X4's ( Diesel or not ) of the same vintage will have the right stuff, too.
Brackets for the pump were hand made...
Les Hunter
Old 02-18-2012, 06:01 PM   #37
Oldgearz
Oldgearz's Avatar
Re: V6 Pics
If anyone's interested I have a good running 305 v6 in my 62 for sale, all original as far as I'm aware, runs and idles well w/rebuilt 2bbl on it. Pm if interested.
1962 GMC 1/2 ton stepside longbed, 305 V6, Muncie 3spd HD tranny, stock rear end, rolling resto!
Oldgearz is offline   Reply With Quote
Old 02-19-2012, 07:24 PM   #38
factorystock
factorystock's Avatar
Re: V6 Pics
Probably 401 or 478.
factorystock is offline   Reply With Quote
Old 03-01-2012, 11:17 PM   #39
1972RedNeck
Re: V6 Pics
Is there any more out there? If I see any more I may have to break down and buy one though.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 03-02-2012, 05:53 AM   #40
dthela
dthela's Avatar
Re: V6 Pics
305 62
dthela is offline   Reply With Quote
Old 03-02-2012, 09:39 AM   #41
duallyjams
duallyjams's Avatar
Re: V6 Pics
Here's a 401M in my garage
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 07-22-2012, 04:54 PM   #42
1972RedNeck
Re: V6 Pics
http://sandiego.craigslist.org/esd/boa/3116268422.html
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 11-28-2013, 09:46 PM   #43
1972RedNeck
Re: V6 Pics
Do we have any more of these motors around?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 11-29-2013, 12:44 AM   #44
b.sharp
b.sharp's Avatar
Re: V6 Pics
I have one in a 63 1 ton with a 4 speed. Sorry, no pics right now. Motor is free and I will try to start it soon. I know nothing of these motors. Are they worth leaving in and running?
b.sharp is offline   Reply With Quote
Old 11-29-2013, 03:58 PM   #45
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: V6 Pics
Anybody here with a 379 or a 432 or 478? These were a little rarer. Only 13 702 v-12's were made.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-29-2013, 04:27 PM   #46
duallyjams
duallyjams's Avatar
Re: V6 Pics
I have seen a 432 they have different head bolts.
James
IG duallyjams
