Old 02-08-2012, 10:15 PM   #26
85burb
85burb's Avatar
Re: Our new 85 long bed.
Got trucks horn working today. New batt installed and test drove with rebuilt carb. Ran good. It has pretty good power i guess. I am used to driving my burb tho. It will spin the rear tire tho. Also installed and bled master cylinder. Then went and got some new tires. Managed to mess up 1 stud somehow removing the nut. Had to break the stud. I am not sure how it happened. I had just installed the wheels sunday. I know i didnt mess up the threads going back on with nut then so not sure why it messed up coming out. So i now have to add a rear stud to parts list....
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-29-2012, 09:21 PM   #27
85burb
85burb's Avatar
Well i tryed to get it inspected last week and it failed for loose turn signals and hi beem. The grill was busted and the wronge year so had to order a new billit grille. Not exactly what we wanted but looks ok and was cheap. Also got new headlight screw assembleys and vent window lock.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-29-2012, 09:59 PM   #28
kelsfine69
18 Till I Die
kelsfine69's Avatar
Are those 454 SS rims?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 02-29-2012, 10:30 PM   #29
85burb
85burb's Avatar
I guess. Same style.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-10-2012, 04:07 PM   #30
85burb
85burb's Avatar
I finally got some hub caps for the long bed.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-10-2012, 07:11 PM   #31
79gmcclassic
79gmcclassic's Avatar
dont you guys mean th350? not b375?
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 03-10-2012, 07:28 PM   #32
85burb
85burb's Avatar
You talking about the trans that is in the truck? Po says it is a turbo 375. They are around i have found. Some are 400 in sides in a 350 case. Some are 350s in 400 case. It looks like a 400 pan so it is a 400 or 375 for sure not a 350. It shifts so i am not too worried what it is exactly.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-11-2012, 09:35 AM   #33
texassquarebodies
Truck Nut
texassquarebodies's Avatar
My girl likes trucks too. She wanted a 1970 Ford for some reason. Well, we can't have that !!! Im on the look out for a 87' 1/2 ton lwb for her now. Im an 87' guy all day. Truck looks good!!! Just needed some TLC.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 03-11-2012, 03:35 PM   #34
85burb
85burb's Avatar
Yes the previous owners have not taken care of it at all. I have had to redo the breaks in rear, rebuild the carb, fix lights, un-redneck the cluster, replace the front windshild, put new tireson, and that was what it took to pass inspection. Still need to rebuild the front end and figure out the drive train. The "freshly rebuilt" motor is loosing oil psi rapidly. I knew that the motor was a lie due to the oil leaks it had. Now to find a 5.3 to swap in....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-31-2012, 07:34 PM   #35
85burb
85burb's Avatar
Well we just lowered the back of the truck. It was sitting 32 5/8 and 32 7/8. Now it is 30 3/4 and 30 1/2. Cost was 0 bucks. If you dont count the jack stands i had to buy. Revmoved the over load and the middle leaf. It had 5 now it has 3. Rids great. It has 1/8 inch rake with the front being lower. Rides amazing. Nice and smooth. Need to rebuild the front and lower it then the 5.3 swap will be started. Nevermind the big ummmm flying sauser in one of them. The last on is how we got it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-31-2012, 08:01 PM   #36
munice
regular everyday normal guy
munice's Avatar
Originally Posted by Car'n'Guitars View Post
Very nice idle, not a bad set of rims either. The ones you have on it now remind me of hot wheels.
..so true
-Andrew-
1987 Chevrolet V10 SM465 NP208
w/ '89 454 dual plane hi-rise 750cfm 1407
w/ '86 10b /14b
new motor on the way:
GM#990 heads
25cc speed pro pistons
COMP XE 274h
crane gold rollers
munice is offline   Reply With Quote
Old 04-01-2012, 10:50 AM   #37
Zane M
Great truck.
Zane M is offline   Reply With Quote
Old 04-01-2012, 10:51 AM   #38
nekkidhillbilly
can she come breathe on my wife
nekkidhillbilly is offline   Reply With Quote
