Old 02-14-2012, 03:15 AM   #26
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Will headers hurt exhuast flow?
Originally Posted by dugvera@gmail.com View Post
Agreed. What a cheap set of hraders will do is get you very good at changing out gaskets.
Sound like you have had bad experiences with warped flanges and headers.
Over tightening will cause blown gaskets. Bolts coming loose cause blown gaskets and making the header too tight causes a warped flange
A header lock washer kit and gaskets called REMFLEX fix the issues very nicely. Been running my paper thin flanged headmans for two years like this. Have had no issues so far
Look into REMFLEX gaskets they are nice
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-14-2012, 01:21 PM   #27
dugvera@gmail.com
dugvera@gmail.com's Avatar
Yes I have been through the thin flange header issues. I run a copper gasket in my dougs and have never had an issue on the upper. I for im dealing with thin flanged headers in ill look into that gasket for sure.
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline   Reply With Quote
Old 02-14-2012, 01:56 PM   #28
INSIDIOUS '86
Maybe someday I will have Doug's too haha but as soon as I'm done growing my money on the tree definitely gonna get some
Old 02-14-2012, 02:03 PM   #29
dugvera@gmail.com
Right! The set on my 76 I got a blemished set for about half the price but I need some for the burb now and im looking at paying a pretty penny for them.
Doug
66 4x4 GMC Suburban
Old 02-14-2012, 09:08 PM   #30
piecesparts
Parts and more parts
piecesparts's Avatar
Put teflon tape on the threads of the header bolts and they will not back out. When you want them out, they will unscrew as needed. It works like a charm and lasts a long time.
Frank
piecesparts is offline   Reply With Quote
Old 02-14-2012, 09:21 PM   #31
kevinr1970
I have never had a set of headers that I installed have the gaskets go out, but... I always use stock Felpro (or whatever?) manifold gaskets.
Never seemed to give me any issues?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-14-2012, 10:33 PM   #32
dugvera@gmail.com
I have herd that b4. Never tried it. seems like its not an issue anymore. My try y headers have been on 9 years with no leaks. No loose bolts.
Doug
66 4x4 GMC Suburban
