![]() Join Date: Jul 2007
AM Radios 2 truck 1 Corvair and other Radio stuff
I have some radios and hardware I need to get rid of. The truck radios do not work. I have tested them but thats as far as I went with them. Just radio w/no cups or knobs. The faces do have pits. They are numbered 11 and 12. see pic 25.00 shipped
62 Corvair radio that I tested and it does work and light up. Sounds like an AM though. I put it in a dash and it does fit the opening. You have to use two washers on the left to sandwich the hole in the dash instead of using a cup. Right side uses a cup. The knobs stick out a little but you can trim down the stems. You'll use your rear mounting bracket. It does have one on it from the Corvair but not sure if that'll work on a truck. As you see it in the dash with described hardware and knobs. 40.00 shipped Blue center dash section is 50.00 shippedSOLD! I'll post original mounting brackets, cups, & knobs after I get a good count on what I have.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 Last edited by thelonerife; 05-14-2012 at 06:47 PM. |
