#26 |
Re: Manual rack (MS II type), who is using these?
The rack you want to use is a 88 t-bird power rack
#27 |
To Scotts Hot Rods, why is that the one to use over the 79-93 Mustang. Is it 16" center to center? I have a Fatman crossmember and I used V8 springs with one coil cut out. Now after 500 miles the bottom A frames are 2" above the rack. What springs should I use and should I get some 2" drop spindles also? I am not far from your shop and have talked to you before about other things. Perhaps you can give me some suggestions. Thanks
#28 |
The power racks we have been useing for several years have been and will always be based on a 88 t-bird
1.Designed and will work with a gm pump no problem at all 2.Not as sensitive as the mustang power racks out there 3.Deisgned to work with a heavier car or truck 4.Now at this time the power racks we have are BRAND new not reman racks. These just came available to us a little over two months.The best thing on these new racks they come with LIFETIME warrantty so you buy once and never again. The price on these to buy are $389.00 and come with rack bushings and these have a lifetime warrantty to.You cannot go wrong at all. 5.The power racks at all the parts stores are not brand new at all.They are based off the mustang which had over 17 different power racks you can get at parts stores. 6.The mounting points on our power racks we use are 15 1/2 spread and they even come with the power rack fittings.This means no more messing up the threads at all. 7.The last thing if you are in Moorpark you are more than welcome to come on by and you can take a look at these power racks we have here in stock and you will be shocked on how they look compared to the others on the market. Justin |
#29 | |
#30 |
6>8 Plugless........
![]() Join Date: Sep 2007
I have been wondering about the T-bird rack and was contemplating upgrading my 40 up to one since mine is leaking and junk.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
