Old 04-26-2012, 09:34 AM   #26
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: overwhelmed
air bags are your best bet, you can run the hose to behind the license plate for your shrader valves so you can adjust as needed, bags will get you a better ride too.
Or you can static drop, thats what I did, 2"/4" and I tow a small trailer from time to time. I have also towed a 18' trailer without any issues but it wasnt loaded.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-26-2012, 09:37 AM   #27
OneOffStroker
Re: overwhelmed
Originally Posted by greasemonkey71 View Post
..i want to lower the truck a few inches..would i be able to put put some heavy duty springs in the rear so the truck wont sag.....
trucks got trailing arms
i dont want to mess with air bags
I'm not sure if you'd be able to find a heavy duty lowering spring. You could go with lowering blocks and keep your stock springs, that could get you 1-3 inches.
Or get lowering springs and use these: http://www.summitracing.com/parts/AIR-60789/
I know you said you don't want to mess with airbags, but these go inside your springs and air up with a regular air valve that you mount somewhere. Air them up if you need the extra lift when towing, deflate them when you don't.
Two viable and cost effective options for you.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
