07-15-2012, 02:02 AM | #26 | |
Re: Fuel gauge reading
0
07-15-2012, 02:25 AM | #27 | |
Moderator
Empty is 0 ohms. 3 O'Clock usually indicates an open circuit between the sender and the gauge. This is only true when the gauge remains pegged at 3:00 regardless of fuel level. Since the gauge is sweeping 1/4-3:00. The sender circuit has increased resistance, the 30 year old gauge calibration resistor has loose or corroded connections, or the sender has started to fail. Sources of increased resistance are damaged wiring between the frame ground and the gauge, loose spring contacts in the cluster housing, corrosion on the printed circuit to cluster plug. I'd look at the tank to frame ground first... Clean up a spot on the tank pinch weld with sandpaper then run a temporary jumper to a clean spot on the frame. The gauge can be tested by grounding the sender pin on the cluster and turning on the ignition. It should read Empty with a dead shorted sender wire. If it reads 1/4 the gauge or calibration resistor are the problem. Carefully clean up the resistor and nut contact surfaces with 000 steel wool and re-install. If the printed contact surface of the resistor is worn through to the ceramic you can put some slightly larger washers under the nuts to move contact to the undamaged portion of the resistor.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-15-2012, 02:39 AM | #28 |
72 BB C30 Super LongHorn
NICE description!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
