07-11-2012, 12:24 AM | #1 |
Fuel gauge reading
Im having a problem with my fuel gauge, just recently after a fill up the gauge will read way past full. The gauge works and will move throughout the range but it just reads very far off the scale past full after a fill up.
07-11-2012, 12:47 AM | #2 |
Re: Fuel gauge reading
Its very possible that the sending unit is on the way out. I just had one do the same thing on my truck.
07-11-2012, 12:50 AM | #3 |
78 Big10 454
Mine has done that since factory new. 34 years later, no problems.
1978 Chevy SWB C-10 2WD 454/400 |
07-11-2012, 01:30 AM | #4 |
That's the good way for you gauge to be off. It's when it says you have a 1/4 tank left and your stuck on the side of the road is when it sucks
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
07-11-2012, 02:17 AM | #5 |
if you want to make it read right. you can alwas move the needle, run the tank dry the fill it half way then move the needle to the half point thats what i did on my when i replace the sending units.
07-11-2012, 08:02 AM | #6 |
Well, I guess that explains way changing my sending unit did nothing to correct the same issue with my gas gauge..Once it gets to a half tank look out it drops real fast..
07-11-2012, 08:09 AM | #7 |
It is possible that you have a defective gauge. If so, $50 fix at Classic Parts.
07-11-2012, 08:13 AM | #8 |
I had three different gauges in mine..did the same thing on all of them.
07-11-2012, 08:27 AM | #9 |
Interesting - I have had 3 squares and they all went about 1/4" past the full mark when full, but that seems consistent with all vehicles I have owned. I have read somewhere that those automotive engineers design the gauges to stay at the full reading for an abnormally long time and read empty prematurely. This gives the drive the illusion that they are getting a very full tank when they fill up and discourages them from running out of fuel by prematurely showing an empty tank. I have found this to be true in vehicles I have owned.
07-11-2012, 08:50 AM | #10 |
They think we are idiots...
07-11-2012, 09:22 AM | #11 |
78K & 79C Jimmys
my fuel gauge used to bounce when driving
since adding more grounds (behind cluster) <---I'd check that and changing from idiot lights to tach/gauges not a prob I had a switch on my tank,in high school it grounded the sending unit ,reading empty tank nobody bum a drive home with the tank empty ... if the sender wire is lifted (open) it will read over full other wise it worked as normal when i change a tank i bend up the arm of the float so the gauge reads full ,when full doing this leaves 1/4 tank ( about ) below E that way the line won't freeze up as easy and for those times,your "almost there" and i've heard of soggy floats...
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
07-11-2012, 01:28 PM | #12 |
Mine read like that with the original '84 cluster. Just last week i put a 90 burban cluster in for the digital speedo and now it seems to read full correctly. But I did notice that when I added 5 gallons to an emptied the 16 gal tank the guage read half full..? I guess I'll just learn and adapt to what it wants to do.
'87 R10 - 5.3, 4.8 Flat Top Pistons, 220r Cam, Long Tubes, P&P 862 Heads, 4L80e '84 C10 - 5.3, LS6 Cam, 4L80E, 3.73, Ported Heads 329hp/334tq !! STOLEN !! 2-15-13 North AL Click Here:How To DIY Port & Polish LSx Heads Videso by "AGearHead4Life" |
07-11-2012, 01:36 PM | #13 |
hhmmmm
adding more grounds? How did you do that? Ive got a very bouncy gauge and the lens and dash is out right now with the exception fo the gauges to its time to fix the bouncy gauge if I can
07-11-2012, 03:14 PM | #14 |
78K & 79C Jimmys
they all go to one ground
it's about a foot from the plug
07-11-2012, 04:05 PM | #15 | |
78K & 79C Jimmys
might be the prob
07-11-2012, 05:26 PM | #16 |
My bouncy gauge was caused by changing to aftermarket (Spectra Brand) fuel sending units. Previous AC Delco sending units did not do that. However Spectra Gauges were about $45 each and Delco gauges were about $145 each - so I will bounce along with the cheap gauges since the do read correctly when the vehicle is stopped for a while.
07-11-2012, 06:16 PM | #17 | |
78K & 79C Jimmys
After seeing spectra on the tank I didn't look any further And was pleasantly surprised when it stopped bouncing Just mentioning my 79 needs anew one and I'm ordering GM one based on problems others have said And my parts guy said he's never heard of it Thinks I'm nuts wanting a GM one $$ Thought mentioning it maybe it would help someone else Posted via Mobile Device
07-11-2012, 06:25 PM | #18 |
78K & 79C Jimmys
before
http://youtu.be/7lqXLgFScHw but actually i did change the gauge....going idiot to gauges or big to small but thats all i changed
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 07-11-2012 at 07:00 PM. |
07-11-2012, 07:01 PM | #19 |
Not sure how many gallons my 87 holds, but my gauge goes past full. When it shows about empty it takes 14 gallons to fill it up. I will just fill it up at one forth a tank from now on. The more gas in the tank the better. It will help keep the fuel pump cool. Do this on your new cars to.
07-13-2012, 01:10 PM | #20 | |
07-13-2012, 01:47 PM | #21 | |
07-13-2012, 04:55 PM | #22 |
my 78 blazer has a fuel gas that also has a bouncing needle. you can tap on the glass and sometimes it reads right for a minute then bounces again. it fluxuates from full to 1/4 sometimes while driving too. the speedometer and the rest of them seem fine though
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
07-13-2012, 06:22 PM | #23 |
Well I checked my grounds today and cleaned them up but still the same issue. And btw Im not talking about the gauge reading a little past full Im talking about reading at the 3 o'clock position. So whats the verdict here? New sending unit or new gauge?
07-14-2012, 11:31 PM | #24 | |
My guess would be that ground, the gauge or the sending unit. Knowing what ohm the sending unit should read would help to trouble shoot this. Anybody have this spec? Without this information, you could temporarily swap another gauge cluster to eliminate the gauge from the list. Odds seem to be in favor of it being the sending unit. If determined its the sending unit, you may even be able to clean it up or adjust it. LMC is probably a dependable source for a new sending unit.
07-15-2012, 01:53 AM | #25 | |
Moderator
GM senders were weighted to read full longer just after the 1973 OPEC oil embargo. I read this in one of my mid 70's Chevrolet Service News magazines.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
