Old 08-02-2012, 06:51 PM   #26
Can't kech me
Can't kech me's Avatar
Re: my lowwww buck 83 build 5.3
nice nice i too have a 5.3l, will be getting a cam too, but yours will be much cooler with a manual!
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 08-03-2012, 04:31 PM   #27
<<<1983GMC>>>
Nice start
<<<1983GMC>>> is offline   Reply With Quote
Old 08-03-2012, 06:11 PM   #28
LEEVON
Moderator
LEEVON's Avatar
I don't want to poo-poo on your cool engine build, but I don't understand the front-mount distributors for LS based engines. They are really expensive, why not just use an MSD6010 controller? Then you can use stock accessories AND have computer-controlled timing.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-03-2012, 10:45 PM   #29
kwin
kwin's Avatar
Originally Posted by slinginrods View Post
this is what i started with .....
Thats what mine looks like now!
kwin is offline   Reply With Quote
Old 08-03-2012, 10:53 PM   #30
slinginrods
slinginrods's Avatar
i used the 6010 set up on my friends 69 camaro i did for him.the one drawback to that is the fact that your stranded if it goes out on the road. i plan on driving the hell outa this truck and i dont want to buy 2 of those just to carry around incase it craps out.i cant seem to find any one who has used them as a dd.just mainly a wekend warrior so im skeptical on its longevity.if you have ever used any msd products they have the ability to stop working at the most inconvienent time.i have however decided not to go carb at all i have changed my mind and will be using fuel injection of some kind.most likely the factory truck set up since i already have it .but you never know i could chang my mind again.if i can find some people who will attest to the msd with significant miles on the set up i may consider it.i llike alot about it ,just dont really trust it.
any ways tonite spent most of the night cleaning parts, ill post some pics of the internals tomorrow.looks pretty clean
slinginrods is offline   Reply With Quote
Old 08-07-2012, 05:12 PM   #31
slinginrods
got the engine apart this weekend ,cleaned up the pistons .looks pretty good inside.will be taking the heads apart tonight.
Old 08-08-2012, 04:31 PM   #32
slinginrods
Got these headers for a sweet price,yeah i know they dont match.they were on speedway performance garage sale.ill just get the other one coated if they fit.the one coated has me a bit worried hope it clears.
Old 08-09-2012, 10:06 AM   #33
slinginrods
last night i started on the heads,i will be replacing the valve springs ,mild port job and new valve seals.heres where i started
Old 08-09-2012, 10:11 AM   #34
slinginrods
started on the bowls ,cleaning up the valve guide bosses, working on the swirl ramp a little
Old 08-09-2012, 10:13 AM   #35
slinginrods
intake still needs work
Old 08-09-2012, 10:15 AM   #36
slinginrods
exhaust is close
Old 08-09-2012, 10:23 AM   #37
slinginrods
head cleaned up some.hopefully ill get my seals and springs this weekend and i can get these done.these arent getting any state of the art port work ,for one i want to just clean up the important areas ,with that i should be close to or a little better than the z06 heads.these ar 706 castings which are pretty good out the box.im trying to keep in mind its a street truck.plust with me doin it its free!!(lowwwww buck)
Old 08-09-2012, 10:24 AM   #38
slinginrods
head clean
Old 08-09-2012, 10:57 PM   #39
robg2001ls1
bad ass build man. I did the opposite of what u did. I swapped in a 5.3 LS first then realized the suspension felt like sh##. Now i wanna drop it and do the suspension. cant beat the power, reliablity and fuel economy of fuel injection if set up correctly
robg2001ls1 is offline   Reply With Quote
Old 09-05-2012, 11:18 PM   #40
slinginrods
well not alot to show ,been busy helping my dad swap a 4 speed into his 32 ford.and finishing my model t hot rod.but i did get my blue ls 6 springs and finished porting one head.i have decided to go carb and th350 for now ,the manual will have to wait.any how heres some pics of the head ready for assembly.remember this isnt supposed to be the state of the art porting, but it should definetly wake the little 5.3 up with the cam im running.ill be using a ls2 timing chain,stock bottom end with new rings ,rods,main bearings,stock pushrods ,melling oil pump,ls7 lifters,stock rockers with upgraded trunions. i have my tci converter and tranny.need to finish the motor and do the rear end.i have a 9 inch housing the right width,gota get axles and a center section still.thinkin about 3.73.
Old 09-08-2012, 12:15 AM   #41
3r!c84
Badass
3r!c84's Avatar
porting looks good. what tools and bits are you using to port and polish ?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-08-2012, 07:59 AM   #42
rusty76
rusty76's Avatar
Pretty neat
rusty76 is offline   Reply With Quote
Old 09-09-2012, 09:40 PM   #43
slinginrods
man i was busy this weekend.friday after work i went to dads and installed the t top seals and t tops in the 84 z28 were building ,what a ***** getting them to fit and all adjusted.saturday i cleaned my boat and started getting it ready to redo the stringers and deck.tried to get my hot rod started to find i had no oil pressure!so out comes the dist to check with my tool.spun it up with the drill and bam ,40 lbs! must have been a sticky guage,anyway took it for a ride.then came back and cleaned the th350 and replaced th pump seal ,out put seal and filter/pan gasket .then painted it up.today i spent the better part of 4 hours dissasembling ,porting and cleaning the other head.it came out great! i gotta wait till tomorrow for the seals to come in,then i can lap the valves and reasemble.
Old 09-09-2012, 09:47 PM   #44
slinginrods
mini die grinder with harbor freight regulator.high speed carbide cutters.harbor freight porting kit.crafstman air compressor.i use trans fluid to cut with,you can buy cutting oil but this works good.
Old 09-09-2012, 09:58 PM   #45
slinginrods
these are the three that kept me busy all weekend
Old 09-14-2012, 04:07 PM   #46
slinginrods
finally got my seals last night ,lapped the valves and put them together
Old 09-14-2012, 04:10 PM   #47
slinginrods
so far 80.00 for the zo6 springs,16.00 for the seals. port and polish :free still need the trunion up grades they run about 140.00
Old 09-14-2012, 04:22 PM   #48
slinginrods
these upgrade the factory roller bearings with a captive design incase the bearing fails it wont spit bearing guts through the engine.recommended when upping the lift and pressures of an aftermarket cam.i will be upgrading the lifters to brand new ls7 units as well.the low buck is starting to fade but ,aftermarket rockers are 400-600 .00 and morel lifters run 500.00 so really at 140.00 for the ls7 lifters and 140 .00 for the trunion kit im saving alot of coin,and not giving up reliability.
Old 09-25-2012, 08:56 PM   #49
slinginrods
went to the junkyard with dad to get stuff for the camaro build.always keepin one eye open for any squares and damn if ididnt fid a 3/4 ton diesel sub.snatched the sway bar,been lookin for one for a while.paid 20.00 rubbers look ok but im replacing em anyway.cleaned a bunch of parts too.ofund a driveshaft for the th350,rolled it over and it had two big dents in it damm forklifts.heres some pic up dates
Old 09-25-2012, 09:00 PM   #50
slinginrods
donated my th350 to the camaro and scored a fresh th350 with shiftkit and installed my tci 10" 4000 stall converter.i still need to paint it ,its pretty clean though.it was in my dads 32 ford.it only has about 2000 miles on it.
