Old 07-23-2012, 11:57 PM   #1
slinginrods
slinginrods's Avatar
my lowwww buck 83 build 5.3
now that i finally have my engine im going to start my build.this truck is meant to be a low budget build that will be done in my driveway mostly,because my hot rod takes up my garage space and i cant really leave it out side(roadsters hate being rained in).my dad gave me this truck,ive wanted one for a long time.thanks pops!
slinginrods is offline   Reply With Quote
Old 07-24-2012, 12:04 AM   #2
slinginrods
Re: my lowwww buck 83 build 5.3
this is shortly after i got it.as you can see there has been some quality repair work going on here.now to be fair to my dad he never did any of this.he bought it with intentions of building it ,but changed his mind ,now its mine.more to come
Old 07-24-2012, 12:11 AM   #3
slinginrods
front suspension was shot.steering box was sloppy ,all steering gear worn and ball joints
Old 07-24-2012, 12:16 AM   #4
WarBeard
WarBeard's Avatar
Looking good so far! Custom exhaust huh
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 07-24-2012, 12:17 AM   #5
slinginrods
some shots of the steering shaft i built using a joint.also the notorious cracked frame
Old 07-24-2012, 12:21 AM   #6
slinginrods
frame repair......i had to go back and further reinforce the frame around the bolts with some thick washers welded in place around the holes. the plate they sell to fix this for the 4wd does not work on th 2wd.
Old 07-24-2012, 12:27 AM   #7
slinginrods
used a paint and rust removal wheel on the bed and painted it with ace hardware ruststop paint.way cheaper than spray in bed liner but not as strong.
Old 07-24-2012, 12:36 AM   #8
slinginrods
bought some spring pads for 12.00.made my own flip kit ,welded er up.used front shocks on the rear.cut off the bump stops.in the front bit the bullet and got summit racing spindles and springs.it now has all new front steering and suspension.need to add a sway bar .trying to find a 1 ton set up.big difference between the last pic and this one .i also replaced the rotors bearings ,and seals in the front.i replaced the shoes and turned the drums,replaced the axle bearings and seals.replaced the pinion seal and serviced the diff.crawled under and spray bombed everything satin black.made a huge difference.
Old 07-24-2012, 12:39 AM   #9
slinginrods
beside my buddys stock height truck at work.
Old 07-24-2012, 12:45 AM   #10
slinginrods
worked on the door panels some.these will get me by til i can get new ones.i am eventually going to replace all the interior .but im trying to get the echanicals done first.wanting to start on my swap soon.
Old 07-24-2012, 01:23 AM   #11
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Looks to be a really good foundation of a truck!
I like that blue!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 07-24-2012, 10:50 PM   #12
slinginrods
put on my salt flat discs,painted the rear filler .pulled the sickly 305.starting on cleaning the frame up
Old 07-24-2012, 11:04 PM   #13
slinginrods
after cleaning found even more cracks ....no wonder it felt so loose up front.between the worn out suspension and steering and the frame falling apart im surprised it went down the road at all.im used to working on much better frames these 73-87 frames have alot to be desired.if i decide down the road to really upgrade the suspension ill probably just fab my own up using a combo of 2x6 and 2x3 tubing and full coil over suspension ,rack steering,and a 4 link rear.i already have the 9 inch rear for it.i built a 55 this way and it was awesome .anyways i digress, heres were we are
Old 07-24-2012, 11:08 PM   #14
slinginrods
more
Old 07-24-2012, 11:16 PM   #15
slinginrods
redid the under hood harness,replaced all the headlight conectors and cleaned it all up
Old 07-24-2012, 11:23 PM   #16
slinginrods
originally put this together for the truck,406 ported heads.10.5:1 comp roller valvetrain etc.went 10.30s in the race car.but decided to use it in me and my dads camaro street strip car.got my heart set on the 5.3
Old 07-24-2012, 11:32 PM   #17
slinginrods
finally up to were i am now,got it on the stand last night ill be tearing into it to see what i have.still not decided on fuel system.ive put these in muscle cars and street rods before both with fi and carbed.it will get a cam and spring upgrade,and i have a set of 1 3/4 long tube headers.just gotta decide on intake.trans will be 4 or 5 speed manual.3:73 posi rear .should make about 350-380 wheel hp.hopefully.
Old 07-24-2012, 11:35 PM   #18
burb1085
burb1085's Avatar
That's crazy! I'm about to look over the frame of my Suburban. I have the same loose feeling in the steering you described.
burb1085 is offline   Reply With Quote
Old 07-24-2012, 11:52 PM   #19
slinginrods
examples of the carb/dist set up im thinking of.
Old 07-25-2012, 12:00 AM   #20
slinginrods
when turning the wheel the whole frame moves around,its crazy.part of e wants to tear the whole truck apart and just build a solid frame and suspension set up but remember the name of the thread low buck.we shall see if i can refrain
Old 07-25-2012, 06:12 PM   #21
stepside83
stepside83's Avatar
cool build sucks you have so many cracks in the frame, i have a small one by the mounting hole for the one of the bed bolts, the 5.3 carbed idea is cool i was thinking on doing this with my truck, will be watching closely
stepside83 is offline   Reply With Quote
Old 07-25-2012, 08:44 PM   #22
slimneverdies
slimneverdies's Avatar
They actually sell a plate for that frame fix that suppose to work. I've welded mine probably a total of 4 times and it just keeps cracking in different spots. I just bought a newer(better condition frame) and a dropmemember cause as long as you have that steering box on that cracked frame it's gonna be week.
Anyway, nice and clean upgrades
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 07-29-2012, 12:33 AM   #23
Can't kech me
Can't kech me's Avatar
sweet, i wanna build a carbd 6.0l, just think it would be cool
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 08-01-2012, 10:19 PM   #24
slinginrods
got the engine stripped down and cleaned up.the inside looks pretty clean,so far.im going to tear the bottom down and check the bearings.still gotta get my cam kit and gaskets.
Old 08-01-2012, 10:21 PM   #25
slinginrods
this is what i started with .....
