Old 09-06-2012, 10:12 AM   #26
Roninwolf
Roninwolf's Avatar
Re: Serpentine setup
Here is a pic i found of a 68 with a 350 with serpentine.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=531265
72 Cheyenne Super
90 Z71 S.B. 434 C.I. Stroker
78 Camaro Z28 (gave to wife she is restoring it)
Roninwolf is offline   Reply With Quote
Old 09-06-2012, 10:14 AM   #27
Billett
Billett's Avatar
Nevermind then... disregard that. Although I can still take some pics if you want.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 09-06-2012, 10:18 AM   #28
Roninwolf
Roninwolf's Avatar
Another pic of it.
My build thread
72 Cheyenne Super
Old 09-06-2012, 10:27 AM   #29
daveo68
daveo68's Avatar
Yes, pics would be good.
68 C-10 Custom LWB
307 V8
Lexington,NC
davideowens@lexcominc.net
God Bless America
daveo68 is offline   Reply With Quote
Old 09-06-2012, 10:35 AM   #30
VA72C10
VA72C10
VA72C10's Avatar
Mounts are fine for a v8 in the front holes but looks like that crossmember is moved back 4-6" from where it started....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-06-2012, 12:13 PM   #31
Lee H
Lee H's Avatar
I've not seen a cross member bent toward the rear that badly. I'd be looking for a new one.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 09-06-2012, 10:34 PM   #32
daveo68
daveo68's Avatar
Drilled out rivets for crossmember and removed.It is not bent as bad as that picture looked. Drilled holes 1/2" closer to radiator remounted with Grade 8 bolts. Have about 1" clearance now.Now for the dreaded motor mount hole alignment. Any tips?
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 09-06-2012, 11:24 PM   #33
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Guess I'm too late with the pic.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 09-07-2012, 12:00 AM   #34
Zeke's Garage
Zeke's Garage's Avatar
Originally Posted by daveo68 View Post
Drilled out rivets for crossmeber and removed.It is not bent as bad as that picture looked. Drilled holes 1/2" closer to radiator remounted with Grade 8 bolts. Have about 1" clearance now.Now for the dreaded motor mount hole alignment. Any tips?
The V8 mounts are a bit easier than the 6 cylinder ones that have the mounts in the rear as well.
What usually works for me is to have all the bolts a bit loose, and use a couple tapered punches to get the holes lined up. Keep tension on the engine lift so you can wiggle it around a bit while getting thing aligned. Just keep at it, it will finally go.
As long as you have the right mounts that is...
Zeke's Garage is offline   Reply With Quote
