![]() Join Date: Dec 2001
Serpentine setup
I am putting in a 350ci/290 hp with GM Performance serp setup (no A/C). Crank pulley is laying on crossmember when we lower the engine. Why? Using same mount location. This has been a nightmare from the start. Any help appreciated.
Thanks, Dave
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America Last edited by daveo68; 09-04-2012 at 06:35 PM. Reason: spelling |
Re: Serpentine setup
Need pics and is it lined up with transmission?
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=531265 72 Cheyenne Super 90 Z71 S.B. 434 C.I. Stroker 78 Camaro Z28 (gave to wife she is restoring it) |
Just engine for now. The 3 speed manual needs some more work on it. No pictures for now.
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
ttt
What engine came out of the truck ?
Are you sure you have the angle right without the trans and tans mount? Don't know about your year but in my 72 it fit just fine.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Thats what i was wondering if since he didnt have the trans in if he had it to level and not angled down in the back or wrong engine stands if it didnt have a small block v8 in it before.
We took a 307 out. I think it might not be sitting right without the transmission. Will try again tomorrow.
Got the transmission and motor installed. Crank pulley sitting right on top of front crossmember.Still no idea why. Thinking about taking crossmember out and cutting and grinding. This really has got me stumped !!!
I'm using CCP tubular motor mounts. I know others have used stock mounts.
What motor mounts and stands are you using? post pics if you can.
I'm using new motor mounts like the original 307 had. Also stock stands, it has one bolt thru the mounts to the block. This has my brother and I totally frustrated. Still trying to find my camera.
#13 |
ttt
#14 |
Well need some pics because need to see whats going on. the balancer should be the same size as what was on the 307.
#15 | |
![]() Join Date: Aug 2008
Posted via Mobile Device |
#16 |
Ooops i thought the 307 had the 8 inch but anyways it should still clear his crossmember. I've seen lots of 67-72's with newer sbc in them with serpentine setup with no clearance probs too.
#17 | |
#18 | |
Thanks,guys
#19 |
VA72C10
![]() Join Date: Mar 2008
You sure you don't have some 6 cyl frame mounts? def need pictures
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#20 |
Unless they were put in the truck in 1968, I don't know.Will get pics later today.
#21 |
Here are some pics motor mounts and pulley on frame.
1 Pulley on frame 2.Passenger side mount 4 Driver side mount 5.Passenger side mount
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America Last edited by daveo68; 09-06-2012 at 09:12 AM. |
#22 |
That crossmember is bent bad!!!
#23 |
the cross member is bent up and should be bent down is it in upside down was it removed at one time or another?
#24 |
Still has rivets in so I don't think it has ever been out.Going to see if we can straighten it out.
#25 |
Looks like I'm going to need a new crossmember too then
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
