09-08-2012, 08:55 AM | #26 |
Re: How to install modern radio
please don't cut, you don't need a fancy high tech radio, just spend the time and modify it (threads above) and or spend the money on the aftermarket ones that fit the stock! its sad to see dashes all cut up.... but hey, its your truck! good luck!!
01-01-2014, 12:04 AM | #27 |
someone cut my dash before me. but they did a good job very clean cut. im putting in a pioneer radio with a cd player. no pics at this time unfortionatly
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust |
08-15-2014, 11:44 AM | #28 |
You've probably installed your radio by now, but I'm a poor white boy as well and here's how I decided I wanted to mount my new single-din without hacking up the dash.
I started with several feet of 2"x1/8" flat steel. I cut two 7.25" pieces, two 2" pieces, an 11" piece, and then got a 6.5" length of 1/4" rod. I tacked the 2" chunks vertical to one of the 7.25" strips, then tacked the other 7.25" on top of those. Once I got that, I went ahead and welded the outside edges of the rectangular box together solid. I then took an angle grinder and cleaned up the outsides, and in order for the radio to fit in it's new sleeve, I had to take a metal file and grind down the tacks I had done inside. That was time-consuming, to say the least. After I got the sleeve welded up, I took the 1/4" rod, laid it on the back edge of the top of the sleeve, centered it, and welded it down. After that, I centered the 11" strip on top of that (it will be angled down, with the shorter edge being the front) and welded it down flush with the front. Now, here's the tricky part: drilling holes. The main ones you need are the big ones through the 11" piece to bolt it to the bottom of the dash. (by the way, if it's a standard, don't worry about clearance; I checked it myself, and there's still two inches, give or take, of clearance between the bottom of the bracket and the shifter when it's in first and third.) With the head unit I bought, the tabs around the faceplate hold it up, but I will drill at least one hole in each side of the sleeve to screw the head into place. Sidenote, you will need to extend the wiring harness to reach the back of the head unit. My head didn't come with a harness, and I can't find a good pin-out diagram ANYWHERE, so I need to make up a new harness before I do anything else lol
'71 Custom-10 2wd longbed, 250 inline-6, NP 435 four-speed. Medium Bronze Iridescent. Farm truck deluxe. Rat rod build: 1949 Crosley Station Wagon body on 1993 Dodge D350 chassis, Cadillac 500 powerplant. |
08-15-2014, 12:40 PM | #29 |
Does anybody know if there are modernized steroid that fit these trucks? Maybe ones with aux ports and/or satellite radio???? If you had those options, you wouldn't need CDs, and if you don't need a CD player, you wouldn't need to cut the dash!!! I haven't played a CD in years!
I work with tools. |
08-15-2014, 12:40 PM | #30 |
*stereos
Not steroid.
08-15-2014, 01:22 PM | #31 | |
08-15-2014, 01:33 PM | #32 |
Get an underdash install kit off e bay. Theyre 11.00
1967custom |
08-15-2014, 02:12 PM | #33 |
Just get rid of those useless heater controls and install it there..no cutting of the dash..i made an outside trim panel to fit snug..looks like the truck came that way.
TRACK70 BUILD -> http://67-72chevytrucks.com/vboard/s...d.php?t=589761 King's Speed Shop |
08-15-2014, 02:25 PM | #34 |
In Montana, we don't consider our heater controls useless...
08-15-2014, 02:32 PM | #35 |
I'm in Nevada and I use my heater controls too.
I really just wanted to post here to say I'm a poor white boy too.
1972 Driver SOLD |
08-15-2014, 02:37 PM | #36 |
I'm such a poor white boy, that I don't even OWN a truck yet!
08-15-2014, 03:12 PM | #37 | ||
I cut my dash for my radio, and I don't regret it. So far I have had nobody say a word once about it, other than a "nice radio" comment. Since we own our trucks to build and to customize as we see fit, I don't see any difference cutting a dash for a single DIN radio to be any different than overlaying our glove box and instrument panel with aluminum diamond plate, or cutting out for a gas tank relocation, or when removing the body trim and filling in the holes, or shaving the door handles off and so forth. Our truck is a project, we will restore or modify it accordingly. The only point to make is that it should be done with class.
1968 C10, 327 large journal crank, TH400 trans, 12 bolt 3.73 geared rear axle, and rear leaf springs. HEI, Delco 10SI, and brake booster upgrades. Formerly known as mtndewmaniac66. |
08-15-2014, 04:29 PM | #38 |
You shouldn't have used the word "useless". I use mine all the time. If it's not a daily driver, which yours isn't, evidently, then they might not have much use, but for those of us who rely on these trucks to get us places, we need those controls when it gets cold.
08-15-2014, 04:31 PM | #39 |
I like knowing mine's not going to break anytime soon. Cheap plastic doesn't last long where I live.
08-15-2014, 04:32 PM | #40 |
I had mine cut as well and removed the gas tank to fit two 15" kicker's (life before kids) I eventually traded all the stereo equipment to a guy for computer parts.
1969 Chevy C10 2wd stepside longbox |
