#26 |
C10 addict
Re: Issues with CPP tubular upper control arm
Good old phone pictures
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
#27 | |
C10 addict
#28 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Yes they are.
The caster gains are the big bonus,... but I like more,... the fact that they help center the wheel in the fender!
#29 |
C10 addict
They will have to be a future purchase, do you think moving up to a 2" drop spring would help if the alignment shop can't get me some negative camber?
#30 | |
But I would just trim those since you already have them.
#31 |
![]() Join Date: Nov 2010
If u get a higher spring it will give even more camber- thats why the upper arms give u more camber people by them when unlower trucks cuz the lower u go the camber becomes neg so the arms makeup the diff
Some progress is better then no progress |
#32 |
Without the wheel the rotor looks pretty straight or em I seeing things
#33 |
C10 addict
Don't I have to take a complete coil off to make it seat properly in the cups? A full coil would probably be a substantial drop
Sorry, when I said move up to a 2" drop spring I meant move up from a 1.5" drop spring to a 2" drop spring.
#34 | |
#35 |
C10 addict
Those pictures are a little misleading because the driver side still has the tire on so the blocks aren't the exact same height as it would be with a wheel and tire. The first couple pictures show how the tire angles out towards the top.
#36 | |
You can cut less. Just seat the top of the spring in the spring pocket. (up in the crossmember) 1/2 coil cut = approximately 1" of drop. The real question,... is the truck the height you want it now? If it is,... I wouldn't lower it any more. Have you even driven it yet? I would put a few miles on the truck prior to alignment to make sure the springs settle. Also take some good measurements of the fender height. Make sure it is equal on both sides now and after the alignment. Many times the passenger side is slightly higher.
#37 | |
C10 addict
#38 |
I am at work so I only had a second to scan your thread. Given the parts that you installed and the info provided you have the wrong upper arms. Install the stock uppers again to see if that corrects the problem. The spindles and springs shouldn't affect the suspension like that. You're gonna have to call cpp and get the correct uppers. Don't get an alignment yet. There is no way that will rectify the situation.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#39 |
C10 addict
Unfortunately I don't have the stock upper control arms anymore
Keith, Would you mind taking a measurement on your CPP tubular arms from the cross shaft to the some point on the ball joint?
#40 |
C10 addict
Keith,
If you could measure the center of the cross shaft to the center of the inboard surface of the ball joint on your CPP control arms that would be very helpful ![]()
#41 |
I went out and measured the stock upper arm. From the face of the crossshaft where the forward retaining nut is to the c/l of the zerk fitting on top of the upper ball joint is 9". I can't post pics from my phone but if you need it I can post it from my laptop later.
#42 |
That measurement on my 72 with CCP tubular arms is 7 3/4.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#43 |
C10 addict
Thanks for the measurements guys, I will run home on my lunch break and measure mine.
I doubled checked the part number I ordered and it's correct. If they mixed up the parts I doubt they will do anything since it's been 8 months.
#44 |
wanna be 67
CPP exchanged motor mounts for me over a year later. They understood we buy parts as we can. That was a year ago too. I would at least call and ask. I have these same upper and lowers tubular but the truck is in paint jail and away from me to measure.
Posted via Mobile Device |
#45 |
C10 addict
Thanks, it's worth asking if they are indeed the wrong parts
#46 |
C10 addict
I measured the control arm and it's 7 3/4" as well, I'm going to take it to the alignment shop and have them measure the camber and see if the positive angle is just an optical illusion
#47 |
Looking at the pics on a laptop, the pics with the tire/wheel on do look like it has A LOT of positive camber but the pics without the tire look perfectly fine. Maybe it would be worth putting it on the rack and getting the numbers after all.
#48 |
![]() Join Date: Apr 2005
Any updates?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#49 |
C10 addict
I got the truck aligned and the best they could do was +0.5 camber. So for my truck the CPP upper tubular control arms won't get me the -0.5 camber I want with just a 1 1/2" drop spring.
#50 | |
