C10 addict
Issues with CPP tubular upper control arm
I'm stumped so decided it was time to ask the community. I've got the front end of my truck back together on my 67 with 2.5" drop spindles, ECE 1.5" drop springs, stock lower control arms and CPP tubular upper control arms. When I installed the CPP tubular control arms I didn't install the factory shims between them and the frame because I could tell they were longer than the stock upper control arm. After I got the stock lower control arms, drop spindles and other suspension and steering parts installed and the truck back on the ground I noticed the wheels have a lot of positive camber. With the drop spring installed the lower control arm is at a slight angle past parallel to the ground but the control arm is parallel to the ground. This causes the top of the spindle to be pushed out. The blue lines in the image attached should help explain this.
As I mentioned I don't have any shims installed on the upper control arm so I can't move the upper control arm any closure to the frame. I'm not sure what to do, any suggestions??
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Issues with CPP tubular upper control arm
Do you have any actual pictures of your truck suspension?
I have CPP upper arms and stock lower arms on my red '69.
C10 addict
I'll try and get a couple pictures
![]() Join Date: Nov 2010
They may have sold u 1973 and up control arms
Some progress is better then no progress |
Same arm,... different balljoint.
I'm sure u bought 1973 and up drop spindles so they prob sold u the same year control arm by mistake I can see that happening
C10 addict
Here are a few pictures, the drop spindles were part of the disc brake conversion I bought from CPP as well. I pulled the wheel and lowered it onto some blocks of wood so it would be more clear. Everything has been rebuild so new bushings, ball joints, tie rods, etc.
But I think the drop spindle is for a 73 and up so the ball joint would fit.. Just a thought
Eat, Sleep, Drive a Chevy
I think I would have stopped at this point to confirm that I had the correct part, as far as I know the tubular arm should keep the upper ball joint in the same location as the stock arm
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
C10 addict
I bought the upper control arms at a different time and ordered 71-72 tubular control arms, how would I tell if they sent me the wrong ones?
seeing the new pics you just posted, your upper ball joint is installed incorrectly. It should be on top of the arm.
C10 addict
I figured it may have been a perception thing on my part since they are designed to provide more caster
#13 | |
C10 addict
![]() http://image.superchevy.com/f/360533...ntrol_arms.jpg
#14 |
I don't really see anything obvious.
Supposedly the CPP upper arms are 1/2" longer that stock. This works great with extreme drop springs because you normally run out of room to add shims to get the camber correct. I wouldn't worry about it until you get it to the alignment shop and let them do their job. I had these arms on my 2wd blazer when it was static dropped. I was able to get my caster higher than with the stock arms. Shoot for +5 caster or more. My blazer has power steering and it drove great.
#15 | |
You are relying on the shear strength of the bolt head,... to keep you from a bad wreck. They should be on top,... but CPP doesn't make the balljoint pocket big enough without grinding the crap out of the balljoint. I used them on my red truck,... because I had them. Porterbuilt wasn't around when I bought mine. I will buy PB control arms from now on. Especialy their Forward Series arms.
#16 | |
#17 | |
C10 addict
#18 | |
#19 | |
C10 addict
Because I ordered the 71/72 spindles to get the bigger ball joints
#20 |
Just a thought from the pics u don't have the upper ball joint bolted to the spindle nuts missing...if u put one on and u can't get a couterpin in the hole it's not properly seated and will cause positive caster cuz the spindle is not being pulled in if so the u for sure have the wrong parts
#21 |
C10 addict
The disc brake conversion was a complete kit, I got the drop spindle with the 71/72 ball joints. The only other part not in the kit was the control arms. Not sure what part would be wroing
#22 |
Positive camber is what I ment sorry
#23 | |
Look here: http://67-72chevytrucks.com/vboard/s...d.php?t=537266 Member Gringoloco is getting ready to install a set of lowers on his truck. http://67-72chevytrucks.com/vboard/s...d.php?t=444746 Portebuilt makes them for bagged trucks and has a bolt in adapter to hold a coil spring also!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-11-2012 at 11:14 PM. |
#24 | |
C10 addict
#25 | |
