12-05-2016, 10:17 PM | #26 |
Re: Power Steering Hookup Question
Sorry to revive this old thread but it helped me and might can help someone else. Clinebarger you saved the day with your advise. I did unscrew the old adapter from 67 and put it newer 03 5.3 power steering pump. It screwed right in easy, peasy. Thanks for your wisdom again.
12-14-2016, 08:56 PM | #27 |
Can you use a fitting to attach the hose from stock gear box to the hose on the 05 pump
04-20-2018, 11:20 AM | #28 |
Reviving this again...so I took everyone's advice and swapped my LS pressure fitting out for the old SBC one...only to find that my steering gear is from a later model and uses o-ring style fittings going into the gear rather than flared. Can I go ahead and swap the LS fitting back in and use hoses from a newer truck? What would be the best way to handle this?
'71 C-10 SWB Shop Truck Currently 350/350, soon to be LS'd. |
04-20-2018, 12:01 PM | #29 |
I always run the newer boxes because they are less turns lock to lock. You can get lines from an '81-87 that will be o ring type that will fit both the box and the LS pump.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-20-2018, 01:08 PM | #30 |
You say LS pump, meaning LS fitting?
04-23-2018, 01:13 PM | #31 |
Got my lines switched over the weekend. Honestly, the one's from the 81-81 trucks fit better than the 67-72. I also put the LS pressure fitting back in. All is good!
08-22-2019, 04:07 PM | #32 |
