Old 11-12-2012, 03:20 PM   #1
JGross
Power Steering Hookup Question
I upgraded my 65 C10 to power steering awhile back using a 72 pump and steering box. Now I’m swapping out the Gen I small block 350 with a 05 5.3 Vortec. How have you guys connected the modern power steering pump to the vintage power steering box?
JGross is offline   Reply With Quote
Old 11-12-2012, 08:07 PM   #2
clinebarger
Re: Power Steering Hookup Question
Remove the 1" pressure regulator nut on the '72 pump & Install it on the '05 pump, Easy as that.
clinebarger is offline   Reply With Quote
Old 11-12-2012, 09:13 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I used 05 truck accessories with the hydroboost truck pump, and a 72 steering gear/rack. since the pump came with lines, I just put the returns on with clamps (low pressure) and the high pressure metal line I just cut the end off of, and flared the SAE fitting off the 72 box onto the end. Took 10 minutes, works fine. My steering may be considered a bit overboosted since I didn't mess with any pressure stuff (although for the way my truck is setup and feels, I don't mind it much)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-12-2012, 10:12 PM   #4
clinebarger
That way will work without a doubt.
Though doing it my way doesnt require modifying the hose....He can reuse his '72 hose with 45 degree flares on both ends. This pays off in the long run....If he buys a hose later, He doesnt have modify the new hose & void the warranty.
Old 11-13-2012, 03:13 AM   #5
TopFuel1966
TopFuel1966's Avatar
I'm using a 68-72 steering gear with the OEM 5.3 pump with no issues.
TopFuel1966 is offline   Reply With Quote
Old 11-13-2012, 09:18 AM   #6
whitels1
whitels1's Avatar
I plumbed my Gen3 pump right into the 81 Box and no problems, seems to have plenty of turning power for the 35's.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 11-13-2012, 06:18 PM   #7
71chevystep4x4
71chevystep4x4's Avatar
I used a SAE to metric inverted flare adapter from Napa for less than $10. Screws right into your new pump, and your old line screws into it. Sorry I dont have the number.
71chevystep4x4 is offline   Reply With Quote
Old 11-14-2012, 12:19 AM   #8
71chevystep4x4
part number #1446
Old 11-14-2012, 06:48 AM   #9
eagleuh1
eagleuh1's Avatar
Same as above, Put Locktight on both adapter and hose end fitting though. Mine worked loose on drive from Arkansas to Arizona twice. No problems now though. Good luck. And the steering is probably the easiest of any truck I've ever owned. 2005 5.3, believe its the hydraboost pump and the stock 68 power steering gearbox. ?, has anybody put a cooler on their power steering circuit.
eagleuh1 is offline   Reply With Quote
Old 11-14-2012, 09:26 AM   #10
JGross
Originally Posted by 71chevystep4x4 View Post
part number #1446
Thanks for the Help
Old 11-30-2012, 06:55 PM   #11
JGross
part number #1446
In case anyone is looking for this fitting, NAPA no longer stocks it even though it shows up on the web site. They will order it from the factory but you have to buy a minimum of 5. They do have the same fitting made by Gates, (PN G49702-1606) it's the same fitting and $10 cheaper than the one made by Weatherhead. The guy at my shop had to call around to find one but I was able to get the next day.
Good luck
Old 01-30-2013, 10:04 PM   #12
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Wanted to revive this subject because I ran into a leaky pressure hose. I originally used Summit brand braided hose and 90° hose ends with Earls power steering adapters. After about 2000 miles the pressure line began to leak pretty bad so I have gone back to the drawing board. I found that Russell makes fittings and hose specifically for power steering. I ordered 3 hose ends and 6ft of their power flex hose from Summit Racing, and will keep the Earls fittings in the pump and the box. Hopefully this will prove to be sufficient.
Quantities and Part Numbers:
3ea -6 to 90° hose ends (RUS-620421)
6ft of their power flex hose (RUS-632610)
1ea EAR-991947ERL -6 TO 5/8-18 (box)
1ea EAR-991950ERL -6 TO 11/16-18 (box)
1ea EAR-991955ERL -6 TO 16MM X1.5 (pump)
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 02-05-2013, 03:34 AM   #13
BigDan3131
BigDan3131's Avatar
You bought the hose and ends made for power steering only right?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 02-05-2013, 07:41 AM   #14
C10_ustacould
Correct
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 04-27-2013, 09:38 AM   #15
5150
C10 Club Tennessee
5150's Avatar
Is this the correct fitting? I just ordered one from the store under the number 1446 and going to use the original 71 hose.
http://www.napaonline.com/Catalog/Ca...446_0000999999
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 04-27-2013, 06:41 PM   #16
clinebarger
If you still have your old pump....Just remove the old fitting & put it in the late model pump.
Old 04-27-2013, 06:43 PM   #17
5150
C10 Club Tennessee
5150's Avatar
No, I don't have anything but the 5.3 pump and the gear box.
Bryan
www.gmtruckshow.com
Old 04-27-2013, 07:30 PM   #18
clinebarger
There is no specs on the fitting in the link, So I don't know if it will work.
I would go to a wreaking yard & get the right fitting...Any 70's GM/Saginaw pump will have the fitting you need.
Old 04-28-2013, 08:06 AM   #19
JGross
This is the fitting I used with my swap and it worked fine. I have 1000 miles on the new motor with no leaks. I did use loctight on the threads so it wouldn't losen.
Old 04-28-2013, 09:19 AM   #20
5150
C10 Club Tennessee
5150's Avatar
Sweet, thanks.
Bryan
www.gmtruckshow.com
Old 05-03-2013, 08:50 PM   #21
5150
C10 Club Tennessee
5150's Avatar
I went by Napa and picked up the 1446 adapter today. Screwed right in, already had the hose screwed into the gear box. Took a little finagling, but it went right in.
Thanks for the assistance guys.
Bryan
www.gmtruckshow.com
Old 09-02-2013, 11:38 AM   #22
benjaminearle
Ok, so the 1446 adapter looks great (albeit expensive) if you want to use the old hoses, but how about a fitting that will thread into my '79 K15 steering box (flare) and give me a female o-ring thread to put the '97 Vortec P/S pump lines into? I thought I found it at Speedway but can't re-find it after a re-boot. Please tell me someone has found this.
benjaminearle is offline   Reply With Quote
Old 09-02-2013, 01:53 PM   #23
truckdude239
truckdude239's Avatar
I went to the junk yard and pulled the 1 inch hose fitting out of the back of the pump off an 72 and screwed it I. to my L's pump the junkyard only charged me a dollar for the pressure fitting g
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-02-2013, 08:06 PM   #24
clinebarger
That's too easy, People rather buy adaptors, Cut up hoses, Or buy leaky aftermarket crap
Old 09-02-2013, 10:38 PM   #25
truckdude239
Oh I know but I wanted easy quick fix if I ever blew a hose while on a trip by using that fitting I can use the stock 1971 hose
David fuller
2000 Tahoe 5.3l 378
