01-06-2013, 02:05 PM | #26 |
Tot Roddin'
Re: Picture Request - Manual Air Ride Switches/Gauges
SCOTI... you are running 4-way setup right? Just don't have the other switches mounted?
AVSJASON... what is the depth measurement of your switch/gauge pod pictured above?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-06-2013, 02:11 PM | #27 | |
67-72 parts collector,…
The paddle move one direction to fill, the other direction to dump.
01-06-2013, 02:40 PM | #28 |
I went to this site and could not find this paddle valve set...............where is is...a link?
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
01-06-2013, 03:53 PM | #29 |
who makes a panel that will hold 2 guages, 4 switches, but has the ROUND holes for the toggle switch looking valves?
=MATTHEW 69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
01-06-2013, 10:03 PM | #30 |
Here is mine with manual valves. I made a mount a took out the ash tray brackets.
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
01-07-2013, 01:27 PM | #31 |
needs more $$$
Looks very clean rmvlt1100, nice job!
1970 2wd Blazer |
01-07-2013, 02:13 PM | #32 |
Tot Roddin'
Are the switches/panel from Boris at Street Machinery?
01-07-2013, 05:08 PM | #33 |
I'm curious why your going with manual switches.
My reasoning for not using them is to cut down on the amount of airline that could possible get a leak in it. Just my opinion, but with manual valves there is a whole lot of lines going into the cab. |
01-07-2013, 05:38 PM | #34 | ||
01-07-2013, 07:33 PM | #35 |
DLOE65's manual valves look really nice, I'm torn between keeping it simple and using his manual valves or going all the way with Accuair E-level when I get to that point.
http://dloesvalves.webstarts.com/index.html
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
01-07-2013, 09:22 PM | #36 |
Tot Roddin'
I guess if it's setup right... there shouldn't be any leaks.
01-07-2013, 09:24 PM | #37 | |
Tot Roddin'
01-07-2013, 09:52 PM | #38 |
ok.. Really not leaking, but increasing the chances of one of the lines coming in contact with metal when it passes through the cab twice. Unless you are using one feed line and making four T's inside the cab.
I like the simplicity of a manual valve, its just the amount of lines that has always concerned me. Just my point of view.. Either way your truck will look great on air. |
01-07-2013, 10:25 PM | #39 |
Tot Roddin'
Trust me Rochlow... I know exactly where you are coming from. With money aside... Accuair would have been ordered. Ha!
However, ease of use and quality are my main concerns. Ease of use could be on the installation side or on the function side... just depends on how wide I want to open my pocket book.
01-08-2013, 12:30 AM | #40 | |
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
01-08-2013, 09:23 AM | #41 | |
01-08-2013, 10:42 AM | #42 |
Thanks for the look tubbedII. Have a good day.
Posted via Mobile Device Posted via Mobile Device
01-08-2013, 10:46 AM | #43 |
No, the panel I made from some thick sheet metal and the switches I got from a friend of mine that had extra ones. I have to replace them later. I also had the gauges from a previous purchase off of e-bay.
01-08-2013, 10:57 AM | #44 | |
Have a good day. Posted via Mobile Device Posted via Mobile Device
01-08-2013, 02:30 PM | #45 |
AIRBAGPARTS.COM
01-08-2013, 02:31 PM | #46 |
AIRBAGPARTS.COM
10-12-2015, 03:09 PM | #47 |
You guys with manual valves; where do your air lines enter/exit out of the cab?
10-12-2015, 09:36 PM | #48 |
The lines to the front wheels, the drives side goes out the fire wall where the inner fender bolts to the fire wall. The same on the passenger side. The rear lines I wrapped them in tech-flex loom and ran them under the seat to the rear of the cab and exit the cab there. The rear lines share the hole where the supply line goes to the valves. If I can find pictures I will post them. Hope this helps and have a good night.
11-12-2015, 05:29 PM | #49 |
Sitting in on this one. Manual, electric, hose routing. all of which I am struggling with. Because of cost, I am certainly starting with manual. I just hate having to put all those holes in the cab for lines. I am drawn to electric because it just seems like it would be easier to get back to ride height with out having to bump each corner. it will be my DD so that will get old.
11-12-2015, 05:32 PM | #50 | |
