12-31-2012, 12:06 PM | #1 |
Tot Roddin'
Picture Request - Manual Air Ride Switches/Gauges
Does anyone have any pictures of the layout of their manual switches and gauges? Hidden, in the open, custom.... let's see them.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-31-2012, 01:29 PM | #2 |
Re: Picture Request - Manual Air Ride Switches/Gauges
Are you talking about the paddle switches.
Posted via Mobile Device |
12-31-2012, 03:21 PM | #3 |
67-72 parts collector,…
Does this help?
http://bagriders.com/modlab/tech/ins...it_install.pdf
12-31-2012, 03:40 PM | #4 |
My manual/paddle switches for the 64 are out of sight. I placed them inside of the buddy-bucket console.
12-31-2012, 05:08 PM | #5 |
AIRBAGPARTS.COM
12-31-2012, 05:09 PM | #6 |
AIRBAGPARTS.COM
12-31-2012, 05:10 PM | #7 |
AIRBAGPARTS.COM
12-31-2012, 05:11 PM | #8 |
AIRBAGPARTS.COM
And here are a few others we have started making.
01-01-2013, 01:15 PM | #9 |
67-68 buddy bucket console....
01-01-2013, 01:22 PM | #10 |
Nice work on the console!
01-01-2013, 04:23 PM | #11 |
Tot Roddin'
Thanks for the information guys!
SCOTI... you hit the nail on the head my friend. Awesome install! Simple, clean and cool - it doesn't get any better than that. Any other switch/gauge installs? Could be on a car, truck, whatever.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 01-01-2013 at 04:31 PM. |
01-01-2013, 04:34 PM | #12 |
Ridin' Dirty
Here's mine
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
01-01-2013, 04:41 PM | #13 |
Tot Roddin'
Mr. Pops... that's an electric setup right? Love it too!
01-01-2013, 04:51 PM | #14 |
Ridin' Dirty
Thank you! And yes, electric. I guess I think of them as "manual" compared to my buddies computerized preset system since I have to monitor and adjust each bag.
01-01-2013, 04:55 PM | #15 | |
Tot Roddin'
Are you running RideTech valves?
01-02-2013, 09:47 PM | #16 |
Contemplating going from static to bags?
01-03-2013, 02:32 PM | #17 |
Tot Roddin'
Just gaining knowledge from those experienced with air ride.
01-03-2013, 03:45 PM | #18 |
needs more $$$
Here's mine...but after seeing Mr. Pops I thing I'm going to put my gauges where the ashtray is in my console and put the ac controls back in.
1970 2wd Blazer |
01-03-2013, 11:45 PM | #19 |
Ridin' Dirty
Glad to be of inspiration! To tell you guys the truth, manual valves have never crossed my mind. I'm going to look into it since I'm annoyed with my electric valves. Simplicity is a beautiful thing.
01-04-2013, 01:08 AM | #20 |
needs more $$$
The only downfall to manual valves are the speed since they are 1/4 inch lines... But if that's not a concern then I don't see any problem with them. Oh... The air for the dump is right behind the switches too, so it would be a little loud... But I'm sure you could route a line off it put if the cab if it's a problem.
1970 2wd Blazer |
01-04-2013, 10:02 AM | #21 | |
Ridin' Dirty
01-04-2013, 03:44 PM | #22 |
It's just air, so I think the dumping locally isn't an issue. I guess you could route a dump outside but seems unnecessary.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
01-04-2013, 10:22 PM | #23 |
Ridin' Dirty
I've had it dump inside before. Not a huge fan. Loud and the burst of pressure hurts my ear drums. Plus when it dumps outside, it has more shock value to folks on the sidewalk..
01-05-2013, 03:08 PM | #24 | |
My 'in-cab' manual paddle set-up deflated much like a schrader valve would release air pressure from a tire. It can cause a slight odor depending on the amount of moisture in the tank/bags.
01-05-2013, 07:20 PM | #25 |
Ridin' Dirty
I've never had manual valves. I had my 3/8" electric valves dumping in the interior. I was assuming that a paddle valve would have a similar effect if the same amount of air was escaping..? I attached a hose into the threaded dump port and plumbed the hose through the floor to dump outside. If I understand correctly, there isn't a threaded dump port on a paddle switch?
