01-10-2013, 12:27 AM | #26 |
Senior Enthusiast
Re: Has anyone painted inside their cab themselves?
Since I wanted my truck gloss black inside an out, when it was apart I sprayed the entire cab inside and out with black lacquer on the same day. The outside has since been repainted, but the inside remains as originally sprayed. The only decent shots I have are on VHS tapes. Here are some poor quality snapshots -
Stripped to bare metal: Sitting in primer: Finished:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
01-10-2013, 01:05 AM | #27 | |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
01-10-2013, 01:43 PM | #28 |
my 61 is kinda semi dark gray (satin) not silver.
1961 chevy K10 my build is------------61K10 build |
01-10-2013, 05:53 PM | #29 |
66 gmc Were they all white this year?
01-10-2013, 06:17 PM | #30 |
Been plottin on painting them door panels some other color, thats alot of white. Were the seats green like this or is this a recover?
01-10-2013, 06:30 PM | #31 |
Man I want to try a two tone using white but I can't pull the trigger on it - afraid it will always look dirty... looks great in your truck however - so maybe it's still on the list of possibilities
01-10-2013, 06:48 PM | #32 |
Its almost a flat finish. I think its factory, but dont really know. In that pic it had been over a year since I cleaned the inside. I dont know how to read the vin to tell what the color was.
01-10-2013, 07:11 PM | #33 |
meowMEOWmeowMEOW
Mine was actually in pretty decent shape on the dash etc, but the door lowers needed to be re-done. It took 3 tries to get the color and level of metallic right, since as far as I know my interior isn't a stock shade. First pic is the painted/blended door lower (everything under the door card was painted)...ignore all the white crap, its just a little calcified water from wet sanding later.
Second pic is with the door panels on....no one has said they've seen a difference in person. This was also my first full paintjob, and with the exterior being a color change, it was a tightrope dance between keeping good inside paint, and blending the new stuff in. (just realized it was different sides in the pic, but the same was done to both)
01-10-2013, 07:33 PM | #34 |
Hey Jimmydean...What are your seats out of? They look good!
01-10-2013, 07:39 PM | #35 |
Who Me?
Here some of mine.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
01-10-2013, 08:13 PM | #36 |
01-10-2013, 08:46 PM | #37 |
I painted mine last spring. What a pain, but I'm glad that part is done.
01-10-2013, 09:22 PM | #38 |
Who Me?
Its Hurculiner. I just rolled it on.. It hold up great!
01-10-2013, 09:23 PM | #39 |
Who Me?
That looks great!!
01-11-2013, 11:15 AM | #40 |
I guess I'm crossed up with earlier paint colors, did GMC have a dull silver interior?
01-11-2013, 04:05 PM | #41 |
was custom cabs different? my 61 is more like my 57 and 58 i had. it really looks like primer that is not completely flat. they sure didn't splurge on nice paint inside my base truck.
01-11-2013, 04:13 PM | #42 |
some real nice work.......
01-11-2013, 07:02 PM | #43 |
can anybody recommend a good single stage paint to use on the interior? My '64 interior is the lighter shade of fawn and I'd like to keep it that color since I'm just going to spray the dash and floor. everything else is in good shape.
or will it be impossible to get a close enough match? |
01-11-2013, 07:34 PM | #44 | |
01-11-2013, 09:01 PM | #45 |
Thanks for the info Astro. That sounds like a great plan. Any chance you have the paint code handy?
Posted via Mobile Device |
01-11-2013, 09:24 PM | #46 |
I used '03 Nissan Sunlit Sand, code "EVO" but if you have a paint shop nearby that has a scanner they can match your existing paint pretty much exactly.
01-11-2013, 11:37 PM | #47 |
hey man i really like how your interior turned out ..question did you paint everything with the same color like your stearing columb door panels , pic sorta makes it look different . thanks
01-12-2013, 12:14 AM | #48 | |
02-03-2013, 02:42 PM | #49 |
astronaut,
off topic but what knob did you use for the thrift air? Did you just add some epoxy in the hole or use a set screw type knob? The only setscrew knobs I've found are for the wiper and they have a hole in the middle (for washer). thanks.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
02-03-2013, 03:03 PM | #50 | |
