02-21-2013, 12:32 AM | #26 | |
Re: Got my factory AM radio working today. Now a new problem. Nothing good to listen
Posted via Mobile Device |
02-21-2013, 12:55 AM | #27 |
If there is a tuner screw it might be in the radio case below the tuner shaft. You would have to remove the tuner knob and the dummy fader control knob. Then access it through a window in the mounting cup.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-21-2013, 01:05 AM | #28 | |
So how does this work? Posted via Mobile Device |
02-21-2013, 01:21 AM | #29 |
That looks like one. Set it to a station up around 1400-1600 and try small changes to see if the station improves. Make sure you note the start position in case it does not work out.
02-21-2013, 01:37 AM | #30 |
Way back in the early 70s I tried adjusting the trimmer screw on the original AM. Reception away from the city was worse than I had experienced with any other car AM radio I'd had. I was only able to marginally improve reception. So, I replaced the antenna with another just like the GM original. No better. Then I found another AM in the junkyard, installed and tuned it. Still no better. The antenna grounding was good. That's the reason I'm going with a semi correct AM/FM as I described in the post 16. Of course, the cool factor of the AM/FM is also nice.
I hope you have better luck. Last edited by FirstOwner69; 02-21-2013 at 01:50 AM. |
02-21-2013, 01:57 AM | #31 | |
So, how do I check the antenna ground? Posted via Mobile Device |
02-21-2013, 02:04 AM | #32 |
The antenna grounds directly to the cowl. Be sure there the pivoting block (I'm sure it has a better name) on the antenna that clamps the antenna to the underside of the cowl makes good contact with bare metal and that the cowl to body bolts and screws are not rusty.
02-21-2013, 10:22 PM | #33 |
heres what i am doing so i can plug the zune in or my windows 8 phone to the radio
http://67-72chevytrucks.com/vboard/s...d.php?t=509151
'72 chevy k20 '06 H-D Springer softail http://www.bluemooncruisers.com/ http://www.enginecycle.com/ ~Eric |
02-22-2013, 12:18 AM | #34 |
Here locally there is Rush Limbaugh at 12 noon on 790 AM and on 850AM 24/7 comedy. Lots of laughs all day.
02-23-2013, 07:00 PM | #35 |
From the assembly manual.
02-23-2013, 07:19 PM | #36 |
C/10 junkie
This is what I did, then added a speaker from an online company that has the correct ohms and it sounds pretty good
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
02-23-2013, 08:35 PM | #37 | |
We have some decent AM channels in Iowa. If you like country there is 540 AM and it seems to reach the entire state. There is also 1350 that plays some good 60'/70's but some bad and also plays the Cubs games in the summer. There is a classic rock station I can only get sometimes. My 72 Cutlass only had the factory AM and my current 69 GMC has the AM still and it works. My wife and I will listen on long car rides on a clear night and try and figure out what the farthest city we can pick up is. So far we have gotten the Denver Colorado area and it was a sports show. I know it was Denver because they played local commercials.
Bud |
02-23-2013, 10:00 PM | #38 |
I guess I've never thought of AM radio being less desirable than FM. To be honest I'm very happy when whatever I'm driving has a working radio lol. AM has all I care to listen to (talk radio and country) If I get sick of that I just tune into a Canadian talk radio show.
My Mom said that late at night when she was a kid she could pick up Oklahoma City from Wildrose.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
02-24-2013, 01:17 AM | #39 |
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
02-24-2013, 04:15 PM | #40 |
... ummm yea,am, not much there at all. last truck i hid a kenwood am/fm/cd in the glove box.
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
02-26-2013, 07:28 PM | #41 |
This seems to have helped. There's still nothing good to listen to lol, but it does come in more clearly now, with less high pitched squealing.
Also, I moved the antenna cable up. It was draping down over the heater box before Posted via Mobile Device |
02-27-2013, 10:36 PM | #42 |
See my Faq. Simple Aux input for less than $10 in parts installed intpo original radio. works perfectly still today. Plug my phone in everytime I go for a spin and I either use the phone to tune in an FM station or I switch to Pandora. Best mod I made. And one of the only ones thats not original! |
02-28-2013, 01:11 AM | #43 |
That was a great write up of yours and is actually the third time for the link on this thread. Keep up the good tips!
02-28-2013, 01:50 AM | #44 | |
1. I'm not interested in soldering, and wiring all that stuff 2. The radio was a pain to install, and I'm not about to remove it again and then have to put it all back I appreciate it though. That's a very neat mod Posted via Mobile Device |
02-28-2013, 02:15 AM | #45 |
Its going to be easier the second time. Besides if your wife gets a Blazer and your son a pickup you will need the practice. :-)
02-28-2013, 02:26 AM | #46 |
Just a thought here but do you have the braided engine ground straps, the coil supression capacitor and the heater blower capacitor installed? They are shown well in the assembly manual.
02-28-2013, 03:17 AM | #47 | |
02-28-2013, 03:36 AM | #48 |
You are right I forgot to even check your SPID. There is someone reproducing the straps I just don't remeber who right now. The supression capacitors should not be that hard to find either.
02-28-2013, 12:22 PM | #49 | |
http://67-72chevytrucks.com/vboard/s...ound+strap+kit
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
02-28-2013, 12:29 PM | #50 | |
