Old 03-29-2013, 09:31 PM   #1
Todd68Chevy
Todd68Chevy's Avatar
April Fools Swap Meet in Sauget, IL April 7th
I am heading to the 30th GCS Ballpark April Fools Swap Meet in Sauget, IL on April 7th. I am going to be set up as a vendor but going to limited on hauling space and thought if someone was going and needs something I might be able to bring it with me. I mail smaller items but I really do not have the time or abilities to ship these large items at this time. Let me know what you need and I will see if I have it and can get you a condition and price. I do work all week and it might take me some time to get you answers/ pictures. I do not have room to bring it all so let me know what you are interested in. I will only gaurantee to hold an item with money down.
****Parts can be picked up in Shelburn, IN also if that is better for you then at the swap meet*****
****I am also planning on being at the Class Pack Swap Meet at the Effingham County Fairgrounds in Altamont, IL on **** April 13th http://classpack.com/swap_meet ***
1967 Chevy/ GMC A/C dash $110.00 cut at the dash pad
1968-72 non A/C Dash $80.00 cut outside the windshield weld area
1967-68 Chevy Grill - bare $60.00
1968 paintable GMC grille $75.00
1969-1972 right front fender- some rust in the front pocket but repairable $30.00
1969-1972 Left front fender- some rust on the wheel well arch- pocket pretty solid $30.00
1971-72? Woodgrain tailgate panel with letters- drivers condition $80.00
1972 plastic door panels $25.00 and up, some with woodgrain
1967-71 metal door panels $25.00 and up
1967 Chevy/ GMC rust free right hand door- 2 available $135.00 each O.B.O. or $240.00 for the pair. no rust but does have dents
1967 Chevy Small Back window cab section $75.00
1969-1970 Chevy Hood surface rust under the front lip but solid $60.00
1971-1972 Chevy, 1969-1972 GMC Hood rust free but few dents $60.00
1967-1968 Chevy/ GMC Hood needs some repair to the front $80.00
1967-1972 Rear Trailing arms- minor rust in between but the sides check solid SOLD
High Hump bolt in transmission tunnel with hole $40.00
Bench seat- cover poor but the foam, springs, frame all look good SOLD
Dash Pad- usable shape but has been recovered $35.00
Set of 4 GM Truck Rallies with NO caps, tires or rings 6 lug 15x7 $100.00 each or $350.00 for all 4
Pair of GM Truck Rallies with NO caps, tires or rings 6 Lug 15x8 $55.00 for the pair
Set of 4 GM Truck Rallies with NO caps, tires or rings 5 Lug 15x8 $110.00 for all 4
Set of 4 Black Mod wheels WITH spinners, no tires 6 Lug 2- 15x7 & 2- 15x8 $125.00 for all 4
Manual Transmission Bell Housing $30.00
Automatic Transmission Crossmember $40.00
***************Found more parts today 3-30-13*************
Automatic brake pedal assy. $25.00 each
Clutch/ Brake pedal assy. $35.00
Brake booster brackets, used booster and master cylinder (conditions unknown) $55.00 each
1 1/16" Front Sway bar, bushing brackets and frame brackets SOLD
1971- 1972 Chevy Grill- Decent condition- some dings and couple cracks in the inner $80.00
Cowl panels -- $20.00 with ant. hole (several available)
$45.00 with antenna delete (2 available)
Many, Many more parts.
I do not have very much good sheet metal other than what is listed and I have no 4wd items (other than the high humps listed above)
I am also looking for a rust free 67-68 Chevy core support. If you have one you would like to sell, please let me know a price and pictures.
After Friday evening April 5th, I will be away from email. You can PM me for a phone #
Thanks for looking. I do not have room to bring it all so let me know what you are interested in. I will only gaurantee to hold an item with money down.
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Last edited by Todd68Chevy; 04-07-2013 at 09:39 PM. Reason: added pick up location
Todd68Chevy is offline   Reply With Quote
