#26 | |
Re: Need help with 1972 chevrolet c30
#27 |
Check out this wikipedia article...will find all info about the small block chevy v8
http://en.wikipedia.org/wiki/Chevrol...ock_engine#350
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
#28 |
Re: Need help with 1973 chevrolet c30
updates...oldsmobile 5.7 diesel engine out...chevy 350 in...finally it has a working engine..can drive but i have no brakes for some strange reason...hoping to have that fixed asap
#29 |
removed the tray today and started to clean the chassis....a new tray will be built locally...still need to look for a cabin as mine is in terrible shape
#30 |
Nice to see u making progress finally. Depending on how long the truck was parked up for the rear wheel cylinders probably gone now and probably check the master cylinder and booster too. Did u find out how much it would cost to import a cab from USA?
#31 |
![]() Join Date: Feb 2007
I have a good cab like that but I don't have any idea how u would get it to whatever island you are on.
#32 | |
As for shipping, once I can get the cab to Miami...its easy to ship to Trinidad! |
#33 |
#34 |
![]() Join Date: Apr 2011
You do have a booster on that truck - but it's not a vacuum booster like you're probably used to seeing. Your truck was a diesel from the factory, which makes no vacuum to supply to the conventional vacuum booster. It has what GM calls Hydroboost, you can see the Hydroboost unit behind your master cylinder. Instead of vacuum assist, you have hydraulic assist power brakes - the hydroboost is driven off the power steering pump.
Now that you've swapped in a gas engine in place of the diesel, you may want to also swap in a conventional master cylinder and vacuum booster, just to simplify things for yourself.
1971 Chevy K20 350/SM465/NP205 |
#35 |
cool! like seeing the foreign stuff. or foreign builds i mean. that body style stuff is dime a dozen everywhere around here. you shouldnt have a problem finding decent parts.
id restore it too being its the only other on the iland lol
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
#36 | |
#37 | |
