#26 |
Master Hater
Re: LT1 Motor Swap
remember the Iron LT1 heads flow almost 20% more than the aluminum ones. They are what the vortec truck heads were patterned after.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
#27 |
Re: LT1 Motor Swap
Any one install a check engine light...
#28 |
Re: LT1 Motor Swap
Yup. Replaced the "choke/glow plug" amber warning panel with a "service engine soon" insert from a cluster from a tbi truck. Than jumped 12v switched to the indicator lamp socket (which has no circuit board connection if it is a non-diesel truck) and connected the check engine wire from the pcm to the ground side of the lamp as the check engine light activates on a ground signal from the pcm
Proud UA member since 2009 My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660 Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA |
