LT1 Motor Swap
Hey guys, just wanting to see if anyone has done an LT1 swap in a square and see what they think about it? I'm considering taking out my 305 and doing an LT1 swap.
I appreciate all the help guys! ![]()
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
Re: LT1 Motor Swap
I have a 77 C10 that has an LT1 from a 95 Z-28 in it. I did not do the swap, the previous owner did. If I had to do it over I would go with an LS swap or put a regular small block in it.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
Re: LT1 Motor Swap
I did one from a 96 caprice. Check the build thread. The physical swap was easy. The wiring was a PITA.
Proud UA member since 2009 My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660 Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA |
#4 | ||
Re: LT1 Motor Swap
I'm thinking of doing the LT1 or go with the Vortec 5.3 or 6.0 motor.
Re: LT1 Motor Swap
I would go withtl the 6.0 if you have the chance. The lt1 is nice - dropped in place like any other iron sbc, but if I wasnt building the truck on a budget, I totally would have gone with an ls motor. I feel that they have more punch right out of the box, and it seems easier to get more performance out of them and keep them streetable.
Re: LT1 Motor Swap
Thanks man!
Yeah I'm going to keep an eye out for a 6.0 if the deal is right I called a local junkyard today, they have a 6.0 just the motor they want $1,500. So I'm probably going to end up running either a 5.3 or 6.0 Vortec motor that comes out of the silverado/sierra. I really would like the 6.0 but the price has to be right.
Re: LT1 Motor Swap
My Lt1 makes plenty power in stock form. At anything under a 25mph punch it will light the tires up. Mine has aluminum heads. Parts are not as cheap for this as they are for a "normal" small bock. I have been wanting to swap cams in mine for a couple years but can't bring myself to spend the $750 + that is required for a cam kit. I forsee a LS in mine in the near future.
Re: LT1 Motor Swap
OUCH!! 750 for a cam kit?!?! That's insane, yeah I'm definitely staying away from the LT1 now, it's either going to be an LS or Vortech though I'd really like the Vortech motor.
Re: LT1 Motor Swap
That would be for the "hot cam" kit.
Cam, springs, roller rockers plus the retainers and keepers. There are other (normal priced) choices out there
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Re: LT1 Motor Swap
You are correct, I did not mention the price was for a hot cam.
Re: LT1 Motor Swap
77c10 what kind of mpg you getting out of your LT1, and what upgrades do you have?
Re: LT1 Motor Swap
My motor is stock internally. Only aftermarket items are headers, aluminum intake, holley 4 barrel and HEI distributor.
On a road trip I get around 15MPG in it.
#13 |
Re: LT1 Motor Swap
Not too bad, thanks for the info bro!
Wait so is your LT1 carbed, or tbi? Because I was under the impresson they were FI?
#14 |
Re: LT1 Motor Swap
From the factory they are injected. The previous owner changed it to carbed and did away with the optispark and put a distributor in it.
#15 | |
Re: LT1 Motor Swap
Oh okay thanks man! I really appreciate you commenting and giving me advice on it. ![]()
#16 |
Re: LT1 Motor Swap
No problem. Don't get me wrong, they are good power plants but if I had to do it over myself I would go another route.
#17 |
Re: LT1 Motor Swap
Yeah, well I had been doing a little bit of reading and I remember the LT1's use to come in Camaro's 80-90's if I remember correctly. Like it states I'm thinking of doing a motor swap to get something newer more reliable, and get some power without going into debt
#18 |
Slots go on anything!
Re: LT1 Motor Swap
I bought a '79 that had an LT1 swap done on it also. It was still injected. The party that did the swap got it about 80%, but it had an engine fire and toasted the wiring up top. I got it after the harness had been repaired (kind of), but it ran. Injected with the 4L60E, it got around 20 on the highway and had pretty decent power, too. I don't know that I would do one if I didn't have it already,
#19 | |
Re: LT1 Motor Swap
Thanks Jonboy, yeah I'm not afraid to do the work but I just want to know if it's worth my time. And as you've seen most people on here and I've asked a few other individuals that have restored cars they say it's not really worth it. That there is better bang for you bucks on the markets.
#20 |
Re: LT1 Motor Swap
I had an LT1 Camaro and it ran great. They're cool motors, but not much room for tuning capabilities. I also thought about putting an LT1 in my truck, but ultimately swapped a 5.3 vortec. It's a very straightforward swap, cost me $2500 to finish.
#21 | |
Re: LT1 Motor Swap
Yeah I'm going to want it tuned to get some umpff! behind it and that's where I've been told that it's best to go to the vortec. I found a Vortec 6.0 for $1,500 of course right now I don't have that in my bank otherwise I would have me that motor lol
#22 |
Re: LT1 Motor Swap
I have around $2500 in my LS swap so far also, and it hasn't seen the truck yet. I changed trucks, so the CTS-V oil pan and related parts probably aren't as necessary this time, but I will leave them anyhow. It should be a cool swap, though.
As far as the LS swap goes, finding an LS f-body around here on the cheap is pretty easy. The nice thing about the LS is that it will sit exactly where your small block now resides, and the exhaust and all will work too. If you think about it, that engine was rated at 275 HP in the F body, and that was with lousy packaging- the intake tubing is severely restricted, and the exhaust isn't much better. Putting that in a truck, I would bet on around 240-250 at the wheels. I doubt a stock 5.3 would fare a lot better. Just me, but I would do an aftermarket harness either way, so that is a non issue. I would think it would come down to what you want. An LT1 in a truck is still a pretty "gee whiz, how did you do that?" type of thing; you definitely don't see it everyday. It just depends on what you want. |
#23 | |
Re: LT1 Motor Swap
![]() Yeah and that's what I'm going for something that's not seen everyday and is a how'd he do that. Yeah the LS is a very solid motor I'll say that, I mean with everyone's advice and things I've read I'm not likely to do the LT1, but I would really like to do the Vortec 6.0 swap, I was looking found some fairly cheap, plus I know there's a few vortec swaps too but not a lot. I will say this though if I came across an LS for the price I was going to pay for the Vortec 6.0, I'd have to get the LS. Posted via Mobile Device
#24 |
Master Hater
Re: LT1 Motor Swap
LT1's tune just as well as any LS.. and you don't get ripped off on parts like you do for an LS motor, ex. plug wires,, for an LS is outrageous.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
#25 |
Re: LT1 Motor Swap
The LT1 is a very good option for people like me who are well bought into the classic sbc, but want a cheap performance motor.
A Lt1 with full bolt-ons can get pretty close to 350 hp, and have a mountain of torque to go with it. Plus if you truck has bolt-ons or a hot distributor the LT1 can use them if you want to go carb'd. Plus the GMPP manifold offer about another 30hp over the stock set-up. |
