#26 |
Re: Ram Horn Exhaust Question
The Dorman 2.5" ram horns work fine on the Vortec heads, with the exception of a little grinding on the top square casting lugs so the centerbolt valve covers will fit properly. The straight down exit works fine on my 4 wheel drive Blazer.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
#27 |
Any thoughts on the "limit" of the ram horn manifolds compaired to headers as far as engine mods and performance? Larger cams and such?
#28 |
C10 with the engine in the standard location need the curved, C10 and Ks in the 4x4 location can use the straights. I would look in the classifieds for OEM manifolds before going after market unless you need the 2.5 inch versions. Probably Dorman if after market.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#29 |
The rams horn exhaust manifolds were designed by Zora Arkus-Duntov in the early 50s for use on the corvette. They will fit all G1 & 2 SBC heads. They were later adapted for several other platforms. Most were 2 inch with 2.5 inch used on corvette 350, 365, and 375 HP solid lifter 327ci engines in the mid to late 60s. Like all GM performance engines of the late 60s and early 70s these HP ratings were very conservative. While headers typically add about 20-25 Horses to a small block, switching from rams horns will only add about half that. My blue printed 30-30 solid lifter cammed 365hp 327 only gained 7 ponies on an engine dyno going from rams horns to headers.
Duntov was the father of GM racing and was the chief designer from mid 50's through the hay days of the 60s and early 70s. In the 40s his company pioneered the ford V8 flathead aluminum head design that later turned into Offenhauser. As a designer and driver he won several class divisions at Le Mans in the early 50s driving a porsche. Soon after he joined GM and laid the foundation and strategy that Chevrolet has used ever since to create the most successful performance parts programs in the industry. In the process, he would change the Corvette from mundane into a formidable sports car that challenged Porsche, Ferrari, Maserati, Mercedes-Benz, and won.
#30 |
Looking at my 71 they look like they may fit, the driver side might be close to the engine mount. Harpie, a few replies back says he has them on his 71 C10 2wd without an issue.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
#31 | |
Cool history lesson. Brings more "life" into these parts we talk about so much. Thanks for posting.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. ![]() |
#32 |
And here I've been thinking I'd toss out the rams horn manifolds on my truck and install headers before long.
Had no idea they were from the brilliant mind of Zora Arkus-Duntov Time for a re-think...... |
#33 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I started this thread and really like the way threads can weave and bob and still keep to the original theme. Thats one of the things that makes this site super.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#34 |
![]() Join Date: Sep 2014
Once again, Great site!
I decided to remove my Hedman Headers and install the original Ramshorns on my 72' C-10 1/2 ton. I have read other forum discussions about not using gaskets or Grade 8 bolts. I don't have the bolts for mounting and need to get the correct hardware. Can someone please tell me if there is a specific manifold bolt kit you would recommend or lets say NAPA parts have the correct length bolts, washers and copper nuts for installing? Any advice and feedback would be appreciated. Thanks, Sam |
#35 |
![]() Join Date: Oct 2009
I've had ram's horns and headers. Realistically, headers are only a horsepower maker in the higher rpm range, but they may help a little on the lower end of the range. They should be considered for an engine upgrade if the intake (carb, valves, cam (especially) are non-stock, performance oriented. Not much point to them on a bone stock engine as ram's horns are pretty efficient. Used to think everything needed headers, but got kinda tired of the extra noise - prefer stock for the most part now. And they don't eek as much heat into the eng compartment either. My 2c! And thanks for the cool info Lee.
#36 |
TRKFRMR1
![]() Join Date: Oct 2002
Did all the small block trucks use the heat riser?Is there any way to delete it?
Thanks. |
#37 |
#38 |
![]() Join Date: Sep 2007
I picked up a nice setnof ramhorns angled off a 69 el camino with a 307. It has the emission rods sticking out of them. Can they be easily removed and then plugged?
1967custom |
#39 |
#40 | |
http://www.speedwaymotors.com/Tru-Ra...Iron,3823.html |
#41 |
check this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=404828
#42 | |
I've tried cheap headers before and they are a waste of time. If I went back to cast iron I'd want either the LT-1 manifolds or the Speedway ram's horns. I'm convinced that the factory ram's horns are likely better in dual exhaust configuration, the factory Y pipe is poorly designed, and even worse if the reversion cones are gone. I'm only speaking of the 2" outlet that angles out I've never used the Corvette style with 2 1/2" outlets that go straight down; I've heard they are better. I'm installing a SWB frame soon, and will likely upgrade to 3" pipe. What I've done, and my experiences. Have fun and be safe. Last edited by mechanicalman; 09-25-2014 at 08:50 AM. |
