70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Ram Horn Exhaust Question
Do the ram horn exhaust manifolds work like headers and are they factory? Were they available for big blocks?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Ram Horn Exhaust Question
The Ramshorns are good as headers for normal street use. They are factory on 55-62 v-8 light trucks & longer on larger trucks. The Corvetts used them with a 2 1/2 in outlet. They are available new at a reasonable price through the aftermarket.
Actually on our trucks until 72 on the small blocks.
The Corvette ones are slightly different because of the frame. Just bought a right side from eBay for 43 bucks shipped. Fit perfectly! Posted via Mobile Device
1971 Chevrolet C10 Inflation Fighter ![]() 1994 C3500 Crew Cab Dually 454
You are right Monkey. I meant 72.
![]() Posted via Mobile Device
![]() Join Date: Dec 2012
Can Ram horns fit on 96 -20 vortec heads?
The new ones can be had with 2.5 inch collectors instead of the stock 2"...should be even better for performance apps.
That is a fine looking motor pictured above! Posted via Mobile Device |
![]() Join Date: Jan 2012
I am not sure about availability for the big blocks as I have not seen them but I run them on my 350 built for towing and they are as close to ideal as I can get. I would rather run them over headers for what I use them for. I tow a lot and sometimes some rather heavy loads and I would worry about headers getting a bit too hot and keeping my wiring away from them and the starter as well would be too much of a chore.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
#10 | |
2.5" Rams horns have straight down dumps as opposed to the angled back truck ones, however I don't know if dumping straight down will be a fitment issue or not.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
Good point, I will study that this week as I put my motor back in.
I have considered them for my 71, looking at it, it appears they would fit but haven't tried it for first hand experience. If someone has installed the straight dumps it would be good to know how it went.
#13 | |
#14 |
Is the dump far enough away from the cross member that it doesn't require an extreme bend in the head pipe to clear?
#15 |
Thanks for the replies, now I know about them for , small blocks . I have a 396 in my truck and thought they'd
#16 |
Thanks for the replies, now I know about them for small blocks . I have a 396 in my truck and if available thought they'd work good on it. What came stock on the 396/402 in our trucks?
#17 |
Corvette only big block exhaust manis are free flowing, I think I heard years ago they will fit in a truck. As far as passengers cars they only fit the Corvette. They are pricey.
#18 |
#19 |
laying low
![]() Join Date: Mar 2001
A quick look into LMC catalog shows ram horn manfolds with a different part number of course for the big block engines.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=115 My dad's 72 wrecker had a 454 but I don't remember if it had ram horns or not. It may be 73 up big block manifolds of a different design will fit in our 67-72 frames.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#20 |
The block in my truck has casting number 3902406 which according to Mortec.com means its from 1967 and could be a 2 or 4 bolt main. I dont know what the casting numbers are on the heads as I've never had a valve cover off to check. The attached pics are of the exhaust manifolds on the truck now. I don't think they are the originals seeing one of them has 454 written on it. Does the casting numbers on these tell anyone what they are from.
#21 |
![]() Join Date: Oct 2012
Big blocks and small blocks have exhaust ports in different locations. They are evenly spacedon the big blocks (see the picture above) where the small blocks have 2 together in the center.
Therefore they will not work. |
#22 |
Big Block Corvette manifolds looked like this:
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#23 |
Thanks for the reply. I know the small block ram horns wont fit on a big block and that is why I asked if they made them for big blocks as well and so far it seems they only made for for Corvette big blocks.
#24 |
Which after market ram horns do you recomend for SBC 350 to go into my 71 C10? Straight dump or should I get the curved dumps?
#25 |
I don't beleive the Corvette manifolds are "ramshorn" design. The spacing of the small block exhaust ports is what allows for the "ramshorn" design, I guess they could make them for BBC's, but they would look different.
