#26 |
![]() Join Date: Jun 2013
Re: Just for stepside drivers.
I bought a new stepside every year from '64 to '83 and the spare was carried under the frame. The fender mounted spare was extra but not much. The entire truck in '67 was only $1700 and that included an AM radio and heater.
#27 |
![]() Join Date: May 2012
i guess i never saw one with the spare tire under the bed on a step side, i have seen them mounted on the left step and right step . i was just wondering if you could order what side you wanted it on, mine is on the left and it does get in the way with the left mirror.
#28 |
![]() Join Date: Feb 2002
I can't speak for Down-Under export models, but I've never seen a passenger-side tire mount in the Continental US in 40 years of driving a stepside.
#29 |
there is a red one here but i am not sure who it belongs to, i will try and find it later and post a pic of it...
#30 |
What year model? The last passenger side mounted spare I saw was '53 or earlier. At a glance it's difficult to tell the year from '48 to '53. Same probably goes for the drivers.
Gale Gorman '54 3100 '67 C20 stepside |
#31 |
the truck is owned by tschevy its for sale in the 67-72 classified section. it has a right side mounted spare, not sure but it may be custom , red and black, i do not know how to move the photo to here, but go to classified for sale, then 90 pic's per page and its on page #6. it took a while but i finally found it.
#32 |
I took a better pic to show what I was talking about. if you look at the photo below the tire sits to low and there's a very large space between tire and the fender. it's hard to tell in your guys pic's but it looks like your tire actually sits in the cut out, mine sit's in front of it. there is no holes in the box so nobody moved it forward and the frame of it is touching the fender so it can't be moved back. so I like the idea of the spare being there but I don't like it because it doesn't actually sit in the cutout.
1969 Chevy C10 2wd stepside longbox |
#33 | |
My '54 bed has the holes to receive the mounting bracket even though it wasn't shipped with a side spare.
#34 |
I've never had the spare off it since I bought the truck in 93
#35 |
might be a lie I don't remember if I had to take it off when I removed the fender to prime it
#36 |
I'll lay the fender on the side panel along with the mount bracket and take a picture in the morning.
#37 |
you got me curious maybe po did something odd to this truck.
#38 |
The way that spare mounts does look quite odd. My truck is the same model = '69 c10 long stepper. I'll try to find time today to remove the spare and snap an image to post here.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
#39 | |
Last night I said I would assemble the parts this morning and then I got busy at something else. I just stopped to lay the bed side, fender, spare mount bracket, and a tire so you can see how they are supposed to look. These are all original parts from a '68 lwb step side. Look at relation of the bottom of your wheel well to the 'molding' line on the fender.
#40 |
I like how your guys looks, it doesn't fill up the space but at least it's centered in the space. GRX can you post up a pick of your 69 to see if the cut out matches Gale's 68 or if it is cut out like mine and maybe they screwed up the mount when the crunched the fender under the tire (forgot about that dent til last night). can't imagine and old farmer from winnett, mt would have took the time to build the cut out and do as nice a job as it is most everyone around here just mounts the tire to the grill. and also to cut the round hole in it like the factory did.
#41 | |
As for the clearance, these trucks were intended for farm use and the practicality of using the step to muscle a bag of feed in or out of the bed. I'm glad they made the clearance even and neat. If the clearance was much less a larger tire and a little mud would be difficult to handle. Whoever did the cutout on your truck missed the dimensions by 4" too much in one direction and 4" too little in the other.
#42 |
I've seen that hole in some of the other trucks why it's there no idea makes no sense
http://67-72chevytrucks.com/vboard/s...6&postcount=19 this one looks like it's cut the same as mine http://67-72chevytrucks.com/vboard/s...0&postcount=22
#43 |
Pretty strange there are different cutouts. That may be why none of the repro suppliers offer that fender. I've always assumed the cutouts were the same.
#44 |
I appreciate you taking the time to get the pictures for me gale, still haven't figured out why mine sits so far forward and going from what pic's I can find my mount looks ok but I did figure out that the hole is for the short bed's
http://67-72chevytrucks.com/vboard/s...4&postcount=11
#45 |
Looks good at 20-ft .....
I'm NOT the world's expert on these, but I'll take a whack at it. Sorry for long-winded reply.
Take a look at the mounting bracket in the Palf70 photo (attached link), and the ones above where the tire sits so obviously too-far away from the fender (Gale & Wreckedchevy's). The bracket on Gale's & Wreckedchevy's photos (the gold truck & the red truck) both have two vertical angle irons outside (in front of) the fender. Pretty sure that those are the correct long wheelbase spare tire brackets, but I believe both of those trucks have (wrong) short wheelbase fenders on them. The fender cutouts are in a considerably different spot on a correct long wheelbase cutout fender. My diagnosis: correct wheelbase bracket & wrong fender = really bad tire placement in the fender. Look on Palf 70's tire bracket in the link, & there is only one vertical angle iron in front of the fender. That is a correct shortbed bracket (the other vertical angle iron sits inside under the fender itself & isn't seen). That's why the hole is in the shortbed fenders, because one of the struts goes thru the hole & bolts to the vertical angle ion inside the fender, out of sight. Correct bracket, correct shortbed fender = good location of the tire in the cutout. On my former truck, I also changed over to 5-lug wheels from 6 lug originals, & the three lug nut bolts on the bracket didn't hit the holes right on the 5 lugnut wheel. Only one of the three bolts did hit a wheel hole, and I cut two of the three off, rotated the tire & wheel very slightly & it dropped into the cutout on the fender so close to being centered right that you REALLY had to look to see it. I saw it, but nobody else ever did. On both Palf70's & my truck, shortbed bracket & shortbed fender = correct "fit." Even tho mine is off ever so slightly because of the 15" 5-lug Rally wheels Vs the original 6-lug 16"-ers. Last edited by 68shortstep; 08-09-2013 at 03:39 PM. |
#46 | |
On a short bed the tire just sits closer to the cab. It's relation to the fender doesn't change. I have to modify the tire mounting plate to take an 8 lug rim since I'm using this bed on a C20.
#47 |
Not beat a dead horse, but here's more: I knew I had these filed somewhere, just took me a few minutes to find them. Assembly manual drawings, longbed Vs shortbed, 2 views each, both with sidemount spare brackets.
Hope these help: |
#48 | |
Your truck looks great!
#49 |
On second look, I agree.
#50 |
Thanks! At some point years ago I had detailed drawings of frames, etc. and didn't place enough importance on them. But then I could just buy a new truck next year.
