Old 08-08-2013, 10:19 AM   #26
Frizzle Fry
Frizzle Fry's Avatar
Re: what do you guys think of these engine combos for the wow factor
Love the ITB's and Webers. Turbo'ed anything would be awesome. Flow-thru head on a 292. Or any GM 6 or 8 DOHC:
Or money no object:
http://www.youtube.com/watch?feature...&v=DRSugcmEaYo
Frizzle Fry is offline   Reply With Quote
Old 08-08-2013, 11:58 AM   #27
theastronaut
theastronaut's Avatar
How about a twin turbo LT5?
theastronaut is offline   Reply With Quote
Old 08-08-2013, 01:14 PM   #28
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I just redid the 250 inline in my wagon and of all the different old cars I have been taking to shows for decades, I have gotten more positive comments on this than an V8 I have had. V8's seem to be like belly buttons, everyone has one. This makes them do a double take.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-08-2013, 07:41 PM   #29
AcampoDave
AcampoDave's Avatar
I say go with a hopped up 6. Chevy Mike is right. The Chevy v/8 is everywhere including in my trucks. There are of course some stand out V/8 motors like Nailhead Buicks or Caddy 429'S but if you already have the 6 it will surely be a conversation starter every time you lift your hood at a cruise nite. And nice job Chevy Mike that does have a wow factor indeed.
AcampoDave is offline   Reply With Quote
Old 08-08-2013, 07:50 PM   #30
truckdrivinsob
Gear Jammer
truckdrivinsob's Avatar
cummins is my vote.
truckdrivinsob is offline   Reply With Quote
Old 08-08-2013, 08:05 PM   #31
lucifer
lucifer's Avatar
500 HP 700 ft/lbs torque 24 mph????? Easy choice CUMMINGS
WOW FOR SURE!!
and I like wow. Check this one out...who knows what it is??
Name:  M33 april 2011 009.jpg
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 08-08-2013, 10:48 PM   #32
66Submarine
66Submarine's Avatar
THERE IS NO SUCH THING AS A "CUMMINGS" ENGINE!!!
Say it with me- CUMMINS! Was that so hard?
Also, with 500HP, I think you can potentially reach speeds of up to 25MPH.
66Submarine is offline   Reply With Quote
Old 08-09-2013, 05:19 AM   #33
darkhorse970
darkhorse970's Avatar
I've always been a fan of a nicely detailed inline 6, this one looks nice! That's certainly another good option.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 08-09-2013, 01:54 PM   #34
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Reverse-running 350
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-09-2013, 04:51 PM   #35
Snailed
Snailed's Avatar
Originally Posted by norm roll View Post
info please on doing efi on a straight 6 for about $800.00 and building a turbo setup for about $800.00
The engine doesn't really matter much.
The cheapest way is probably to use a premade TBI unit for throttle plates, some sensors, injectors and fuel pressure regulator. I got a GM one for $55. The only other sensors needed were the air temp and coolant temp, about $35 new with plugs.
Then you need a computer, ECU, to take these sensor inputs and squirt the injectors the correct amount based on load and rpm. I use a pre-built Megasquirt II box for $444, they make ones for a lot less that would work on a basic setup too. It's internal MAP (load) sensor can read vacuum and boost so this would work great for turbo or SC later on. For the wiring, I bought a harness that plugs into the MS II box and then you make the rest by terminating it for each sensor input or device you want to control (injectors, idle control, fans, boost solenoid etc.). That was about $70 I think. So that's about $600 and you will eat the rest up with a fuel pump and other crap to plumb it all and rig up a throttle and stuff like that.
The best part is that later you could ditch the TBI and make yourself or buy a port injection setup and run it just the same way NA or boosted. The ECU i used can control timing via a distributor or even a coil on plug setup or coil packs. The options are endless really and any mechanical change you make can be carefully tuned to get the most out of it.
There are tons of different brands of standalone ECUs out there too. A used AEM EMS or an old Haltec could be other, cheaper alternatives. They all work the same for the most part.
Snailed is offline   Reply With Quote
Old 08-15-2013, 09:27 AM   #36
1963c-10
1963c-10's Avatar
How about a rotary engine from a plane? This engine will really make you fly. haha
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-15-2013, 02:33 PM   #37
66Submarine
That's a tiny one, how about a Wright R-3350 turbo-compound radial? There's a real engine for wow factor, lol. http://en.wikipedia.org/wiki/Wright_...Duplex-Cyclone
Old 08-15-2013, 02:56 PM   #38
contagious102
contagious102's Avatar
Got mine in the frame last nite.!!
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 08-15-2013, 03:00 PM   #39
mr andrerson
hey 1963c-10... did you see how that radial was putting the power to the wheels? or did they have a prop in the bed and runnin it like an air boat.... lol
mr andrerson is offline   Reply With Quote
Old 08-15-2013, 03:18 PM   #40
1963c-10
1963c-10's Avatar
I have no idea personally. Was just a random picture that I came across. There is a link that I will find where there was a thread last year on the 67-72 side about this truck and a 68 GMC also that has an airplane engine in it with a video of it running. Ill post it in a few minutes when I find it...
I will note that I am no airplane mechanic, but the exhaust does not seem to be hooked up. It might just be sitting in the engine bay (work in progress kinda deal).
Old 08-15-2013, 03:20 PM   #41
1963c-10
1963c-10's Avatar
Here is the link to the 67-72 page on the truck....It was at the Spokane 2012 Goodguys show, so MarkB and a few of the others from that area may have seen it if they went.
http://67-72chevytrucks.com/vboard/s...d.php?t=539202
Old 08-16-2013, 12:03 AM   #42
Captainfab
60-66 Nut
Yeah, nothing on that radial engine was hooked up. I have since talked with a guy that knows the builder, and he claims that the guy has an idea on how to make it all work and drive. Goodguys is this weekend, so I'll be curious to see if it's there again.
Old 08-16-2013, 08:10 AM   #43
1963c-10
1963c-10's Avatar
Thanks Captainfab for the update. Im interested in this build also. I have no desire to do one myself, just interested to see how its going to all go together. Im guessing it'll be front wheel drive?
Old 08-16-2013, 08:24 AM   #44
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
A tricked sixer is cool.. and any V8 with stack injection is cool too!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
