![]() Join Date: Mar 2012
what do you guys think of these engine combos for the wow factor
im getting ready to make a decision on the engine for my 66 short bed step side.
here's the choice's this is just a drive it every now and then some cruise's and show's. im kind of after the wow factor for this truck. the chassie will be beefed up as needed for what ever enging i run. things done so far are as follows most of the frame is boxed in.a x brace in the rear frame rails is already installed. the rear trailing arme are boxed a tricked out inline 250 a rebuilt 1966 corvette engine bbc 427 _ 425 hp or a 5.9 cummins with about 500 hp transmision undecided. |
Re: what do you guys think of these engine combos for the wow factor
A small block Chev W/3 2 barrels.
i like tricked out 250 or 292s
also 427 would be nice with a 4 speed I know a retired man near my house, he has a chevy 302 with a munice 4 speed in his 1965 short fleet, pretty cool combo i'm not big on the Cummings thing; keep these trucks gm powered
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
big block
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#5 | |
It's Better With Nitro
![]() ![]() ...or, a blown 500 ci Cadillac: ![]()
Gotta go with the Vette 427, especially if you're not going to drive it. That should wow a few folks.
![]() Join Date: May 2012
Here is what I'm putting in my 66. 540 ci motor I built for my race car three years ago.Swapping the piston's out this week so I can run pump gas.
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
348 or 409 would be the coolest "wow" factor in my book.
BBC allways gives the best WOW factor
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
Anything with an 8 throttle body/individual runner intake.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#13 |
I think a 427 would be the coolest, even if you do drive it regularly.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck |
#14 |
348 or 409 would be the best WOW factor in my book too
Ken B ![]() 60 Chevy Apache 08 Chevy Silverado Z71 Why buy something when you can build it for twice the price.. ![]() Just because something can be done doesn't mean it should be done... |
#15 |
![]() Join Date: Jul 2006
Turbo inline 6. There are a couple running around here and a guy who has it pretty well figured out. Dad and I were on that trail for awhile...
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#16 |
#17 | |
so maybe a blow thru carb and a turbo would be different and well in my budget |
#18 |
I say 427...I have one on my engine stand right now to go in my '68 project. The 8 Stack injection would put it over the TOP!!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#19 |
even though about taking the turbo engine out of my race car a putting a smaller turbo on it since im not racing right now. right now it has a 101 mm turbo with right at 1800 hp a little to much for the truck lol
#20 | |
Gotta make my own intake since I can't find an affordable manifold for an LS with the Weber bolt pattern. ![]() Shooting for something like this. ![]() Posted via Mobile Device
#21 |
multiple carb or stack on anything looks great!
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
#22 |
I would do a relatively stock small block or I6 with a simple EFI single turbo setup. Making your power with boost is much cheaper than buying cams, and crazy heads, to a point. If your goals are under 500hp it's pretty damn easy to force that through a good sized v8 with an inexpensive turbo. I just installed and tuned a complete EFI setup on my '66 for about $800 and I could easily build a turbo setup to go with it for about the same again.
#23 |
![]() Join Date: Jun 2006
Dual quads or tri power on the 427 just to be different.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#24 |
Pontiac straight 8 for wow, run eight straight pipes.
Posted via Mobile Device |
#25 | |
info please on doing efi on a straight 6 for about $800.00 and building a turbo setup for about $800.00 |
