Old 09-08-2013, 05:24 PM   #26
Edahall
Re: Boost your trucks A/C in 20 minutes.
The fan out of my 1990 Suburban quit one day so I put in a fan out of junkyard 1999 Tahoe. To be honest, I notice no difference.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 10-03-2013, 03:36 PM   #27
Malo83
Cruzzzn' Vet
Malo83's Avatar
Any updates on this thinking of switching out my tired old fan.
Malo83 is offline   Reply With Quote
Old 10-03-2013, 05:08 PM   #28
Edahall
Yes, if you want more A/C output, ditch that r134a refrigerant and switch back to r12 or better yet r290. I've got my A/C set up to freeze you out even when it's 100 degrees out here in Southern Texas.
Old 10-04-2013, 03:14 PM   #29
Malo83
Cruzzzn' Vet
Malo83's Avatar
Still running the R12
Old 05-06-2014, 03:19 AM   #30
Malo83
Cruzzzn' Vet
Malo83's Avatar
Changed out the old blower with the new and ,Whala! the new blower pushes more air! probably cause it's a new blower or whatever, but i'm getting more air than before
Old 05-06-2014, 11:49 PM   #31
hatzie
Moderator
hatzie's Avatar
HC refrigerants R290 & R600a can be used as an R12 replacement but getting a proper charge is different from CFC refrigerants.
The nature of government agencies like the EPA are valid considerations...
This is Jungle Eddy's post on the Aircondition.com forum. That BBS may still be available via the wayback machine.
http://67-72chevytrucks.com/vboard/s...48&postcount=6
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-06-2014, 11:58 PM   #32
69chevytrucker
69chevytrucker's Avatar
that fan will fit on a 69 as well there all the same i got a 69 and put the fan from a 85 bolted right up
69chevytrucker is offline   Reply With Quote
Old 05-07-2014, 01:12 PM   #33
Malo83
Cruzzzn' Vet
Malo83's Avatar
Looking for some Freeze 12
Old 05-18-2016, 01:29 AM   #34
Harley03joe
Will VDO Blower Motor PM129 Work In A 71 C20 A/C
Thank You
Harley03joe
Harley03joe is offline   Reply With Quote
Old 05-18-2016, 01:49 AM   #35
Harley03joe
Hi Sorry Im Late But Question About The R290 Freon
My 71 Truck Was R12 Then Went To R134 With The R134 Oil,, The Question Is This Do I Have To Put Different Oil In It Or Would The R134 Oil Be Ok ??
And How Much R290 Do I Put In It ? > Till The Dryer Glass Runs Clear ?
Thank You For The Answer
Harley03joe
Old 05-18-2016, 01:50 AM   #36
Harley03joe
Good Luck
Old 05-18-2016, 04:19 AM   #37
hatzie
Moderator
hatzie's Avatar
Envirosafe is still available but not Freeze 12.
Harley03joe
R290 is not Freon it's refrigerant grade Propane. If you already converted to R134a you are going to have to make it work.
A 71 should have the big Harrison A6 compressor. That compressor combined with the huge condenser on these pickup trucks should freeze you out of the cab on Max AC even using R134a. Most folks overfill the system with oil. Overfilling with oil insulates the inside of the condenser and evaporator so you don't move as much heat. You'll have to flush the excess oil out of the evaporator and condenser, empty the compressor, then refill the compressor with the correct amount of oil, replace the dryer, vac down, and re-fill.
If your lines have a muffler you'll need to replace that section because you will not be able to flush it out.
The only refrigerant with a spec for the number of pounds to use is the original R12. For non original refrigerants don't use a scale. Follow the link I posted to the Jungle Eddy method for charging the system. This method works with any non original Hydrocarbon and DuPont "Freon" refrigerants.
Old 05-18-2016, 02:02 PM   #38
Harley03joe
Hatzie
Thank You For The Info, It Will Come In Handy, I'm Glade There Are People Like You On The Forum
Thank Again
Harley03joe
