Old 08-24-2013, 06:37 AM   #1
cleansquare
Boost your trucks A/C in 20 minutes.
Replace your blower unit located on passenger side with one from a 95 silverado. Wow does it blow better! I get much more air from the vents now. 5 little bolts and a power wire.
Make sure you scrape off the paint for the ground. This thing was cheap too. Like 15 bucks.
cleansquare is offline   Reply With Quote
Old 08-24-2013, 07:36 AM   #2
slam59
Re: Boost your trucks A/C in 20 minutes.
Really that much better huh? What years will it fit? Would it fit a 77 3/4 ton? What's the part number?
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
Old 08-24-2013, 08:18 AM   #3
1slo_camaro
hrm..... might have to be something i knock out before the weather gets cold and see how well it works haha. Id have to recharge my AC i think i have a small leak since it only lasts about 4-5 months depending on how long the truck sits
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 08-24-2013, 01:53 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
It's great to do in non a/c trucks too.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-24-2013, 06:38 PM   #5
solidaxel
solidaxel's Avatar
I will check with the experts at Century Auto Air Conditioning and see if there are any others that will interchange.
Thanks for the tip.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-24-2013, 09:06 PM   #6
SilverMiner
SilverMiner's Avatar
Yes, please give us some part numbers! NAPA and/or Rockauto numbers would be most useful in my instance, or even just tell us more specifics about the 95 Silverado.
SilverMiner is offline   Reply With Quote
Old 08-24-2013, 11:31 PM   #7
Chvy2NV
That's a great tip. Also waiting on cross ref part #'s. thanks again.
Chvy2NV is offline   Reply With Quote
Old 08-24-2013, 11:33 PM   #8
cleansquare
Sorry guys all I did was ask for a blower motor at oriellys for a 94 pickup. Thats all I know!
Old 08-24-2013, 11:41 PM   #9
slam59
I just zoomed in on the pic and looked up the number on the part in the pic. It is PM 129 and autozone has it guys.
1974 C10 swb 350
Old 08-25-2013, 06:33 AM   #10
DBLSPRT68
DBLSPRT68's Avatar
Thanks for the tip! My Suburban will get one of these
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 08-25-2013, 10:45 AM   #11
UKNOWME
UKNOWME's Avatar
I'd like to hear other people's response/opinions after switching
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 08-25-2013, 11:15 AM   #12
slam59
Same here. I want to do what a few threads here say to do as far as cleaning out my air ducts and all the vents and combined with a stronger blowing motor it should be awesome. I need to do this to my wife's 77 3/4 ton cause the air is cold, and sounds like its blowing real hard on high, but there's not alot of strong air coming out, like its only on medium. I'm sure being a 77 and never probably having the ducts and all cleaned out is the reason. People here who have cleaned there's out say there was a HECK of a difference in air flow afterwards.
1974 C10 swb 350
Old 08-25-2013, 02:15 PM   #13
cleansquare
No time like the present to try it yourself!
Old 09-07-2013, 09:48 PM   #14
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Cool Re: Boost your trucks A/C in 20 minutes.
Could I get some updates from you guys regarding this fan change?
I am getting closer to removing and replacing mine.
I could really use the faster fan speed.
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 09-07-2013, 10:23 PM   #15
BONUSCAB
It's the same motor. Your old one was just wore out and shot.
Few things in life will make you look stupider than putting a dollar sign after a number.
BONUSCAB is offline   Reply With Quote
Old 09-08-2013, 06:48 AM   #16
Skunksmash
Skunksmash's Avatar
I was going to ask what the difference really was. I was thinking that maybe the later model motors pulled more power or something.
Skunksmash is offline   Reply With Quote
Old 09-08-2013, 08:29 AM   #17
tucsonjwt
Just curious, what is the difference between the two motors? Is it possible that you just had a weak original motor and an fresh new motor made the difference - both motors having the same specifications?
tucsonjwt is offline   Reply With Quote
Old 09-08-2013, 08:42 AM   #18
Desert1957
Desert1957's Avatar
I do not understand this thread?
Just looked up my 87 R10 and my 83 C20 VS the 95 Suburban you listed on "Rock Auto"
calls for the same GM part number 1580213 , What gives?????
Desert
Desert1957 is offline   Reply With Quote
Old 09-08-2013, 09:58 AM   #19
SkinnyG
SkinnyG's Avatar
I have nothing good to add to this thread so its been edited by moderator
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 09-08-2013, 10:36 AM   #20
BONUSCAB
Example: if this fan you put in was some super powerful fan that drew a ton of amps, hooking it up to the stock wiring could cause a fire. And I, as I'm sure many would agree, that "it just is" is not an acceptable answer when asking why something is better.
The way you talked of this new fan, leads the reader to believe the 95 Silverado fan is a better fan is a better fan than any other 73-87 fan, when it's not. In fact, it's the same fan. And I doubt that the autozone Made In China fan is any better, in any way, to a new GM fan.
Old 09-08-2013, 12:00 PM   #21
ymerej71
ymerej71's Avatar
You have to know why for many reasons. Example: if this fan you put in was some super powerful fan that drew a ton of amps, hooking it up to the stock wiring could cause a fire. And I, as I'm sure many would agree, that "it just is" is not an acceptable answer when asking why something is better.
Very true, details do matter...especially in electrical components! It is the same blower motor, and it probably does a better job and moving air because it's new. This particular blower motor is very common part that is used in many make & models besides GM. I recently replaced the same part in my '79 GMC as well, and it does seem to boost the airflow... but I also replaced the blower motor resistor because the high speed coil was burnt out. I figure that had more to do with the airspeed... Haha!
ymerej71 is offline   Reply With Quote
Old 09-08-2013, 02:35 PM   #22
Chevy1966
Recently I replaced the AC blower motor in my '76 GMC with a VDO unit similar to that shown in the original post. It works great. I paid $21.99 from O'Reilly (part number VDO PM102) and that even includes a lifetime replacement warranty. I re-used the original plastic fan part as there was no reason to replace it. Now there are some important details to consider when changing out this component. First, be sure the plastic fan unit is cleaned and well-balanced when installed on the new motor. Next - VERY important - as mentioned above make certain that you have a clean, bare metal ground connection to the flange at the base of the blower motor. Also, I used 3M strip caulking to re-seal the unit to the blower housing. Be careful not to over-tighten the attach screws as they can easily be stripped out. I want to go on record to say that I always prefer to use "made in USA" parts. The reality is that this is not always possible. Even Delco now buys a large percentage of their products from non-US sources. Sad but true.
Chevy1966 is offline   Reply With Quote
Old 09-08-2013, 02:43 PM   #23
Tx79chevy
Tx79chevy's Avatar
Yeah the way the thread was written, i was under the assumption that there was a difference between the stock motor and the one made for a 95. They seemed like the same blower motor to me so i couldnt figure out what was so much better about the 95 either.
1951 Styleline Deluxe 2dr
1957 Belair 4dr
1975 Scottsdale
1979 Silverado
1987 Silverado
1987 Cutlass Supreme (For Sale)
Tx79chevy is offline   Reply With Quote
Old 09-08-2013, 03:38 PM   #24
Skunksmash
Skunksmash's Avatar
Somewhere on there, there are probably stamped or stickered specifications. Somebody needs to compare 'em
Old 09-08-2013, 04:05 PM   #25
RPOZ11
RPOZ11's Avatar
ya, that was how I was interpreting his post.
HO72 build :
2017 SS
