#26 |
Re: What's your winter plans?
4:11 posi and a 5 speed.
#27 |
Patch the floors, pair of inner fenders. some rally rims n new tires. Hopefully a new cam w its goodies( timing chain n valve springs at least) maybe do some body work depending on time n budget left over after the other items.
#28 |
MOTORHEAD!
My plans are full body job. Hope to have it better than new for 2014!
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
#29 |
Hoping to 'finally' get the rear axle in the disel fixed. Would like to get the carb done on the 77. But most likely I'll work on the 16 year tractor project, if I can get it running I can make some room in the garage for truck stuff.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
#30 |
#31 |
78K & 79C Jimmys
been looking for a place to store/work on my trucks, as we will only have two spots this winter,and they handed notices again,to everyone,not to work on cars in laneway,
may have found a barn and yard park the 79 work on the carb keep the 78 for bad storms (work on radio,drivers side running board,tilt) the other 79 with plow ,gona use it to plow the friends yard,seems his neighbour with tractor moved
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#32 |
Re-paint my truck myself. Doing the rust oleum job, but hvlp spraying it. Doing a bed liner after that but got a really bad DIY job from a PO that I will have to strip off first. Should suck pretty bad but I gots to do it. Love to find a camper shell b4 paint so I can do it with the truck.
#33 |
World class t5 swap ,using a 94 s10 t5 world class transmission ,jeep bell housing and factory hydro pedal and clutch components. These trans are rated to 400 hp over a 100000 mile life cycle .i may do a tech article on it .this is not the weak early non world class trans and they shift way better than the getrag later model trans.
#34 |
![]() Join Date: Oct 2008
I don't know. My wife hasn't told me what they are yet.
![]() The Jimmy will stay in the garage. I hope to get a TH400 SP built and put in. And some work on getting the door glass back in and new rubber all around. A/F meter is on the list too, along with a tune kit for the Holley and some spring tuning. |
#35 |
I think it's time to take the bed apart and refinish the boards..Have not touched them in about 10 years...Need to get some finish on the inside of the wheel wells also...
#36 |
Gonna work the old horse. Doesn't rain here in the winter and it is just cold enough outside to cut down some trees and pull the stumps. Maybe get those new tires that cost way too much.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#37 |
Daily driving my 84 LWB and continue to make the small upgrades I have planned after the drop in the next few weeks. We don't get a lot of snow and ice where I live so I'm not worried about driving it at all. Besides what's the use of an office job if I can't work from home when it's too icy to drive in to work?
#38 |
Cruzzzn' Vet
She's my DD so she'll be pounding the pavement as she has for the last 30yrs
#39 |
Looks good, Malo. What is the drop on your truck?
#40 |
#41 |
fix my a/c
#42 |
Cruzzzn' Vet
#43 |
Cruzzzn' Vet
#44 | |
#45 |
Sanding, sanding, priming, sanding, sanding..oh did I mention sanding. Hopefully paint by Christmas....
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
#46 |
Sitting on my hands, holding onto every nickel I can get. Hoping to survive yet another threat to the wife and I's jobs. Getting tired of this.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#47 |
I'm in TX, so my winter plans include driving my truck a lot.
#48 |
I'm in Connecticut, so my winter plans included freezing, shoveling, and *****ing and moaning...And driving my truck when the roads are not covered in the toxic stuff that they spray on the roads that eats fuel and brake lines...
#49 |
![]() Join Date: Mar 2009
Im gonna try not to fill up my brand new shed....so far I'm not doing too well.
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD '77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD rust repair on the '77 http://67-72chevytrucks.com/vboard/s...d.php?t=740291 |
