Old 11-18-2013, 12:37 AM   #26
Jyman
Re: My Winter Build 54 Chevy 1300
Wow at the rate your going the truck will be on the road before the new year, to bad for all this snow. Do you plan on taking it to any shows around town?
1948 Chevy
305, NV3500, 3.73 rear, sitting on a 95 s10 frame. Still in the works
2000 Chevy Extreme lowrider, 4.3, NV3500, 3.08 rear, upgraded/modded
2001 GMC Sonoma Zr2, 4.3, NV3500, Stock
Jyman is offline   Reply With Quote
Old 11-19-2013, 11:15 PM   #27
54 CHEVY LR
Snow Snow and more of it. The truck is being built as a Driver. I am sure it will be seen around town.
Last night I Bled the brakes, mounted a torque converter cover,and installed a thermostat and housing.
Shopped for Air line fittings got them installed today.
54 CHEVY LR is offline   Reply With Quote
Old 11-21-2013, 02:35 PM   #28
Wybrow
Great build, I've waited a while to see one of those aftermarket frames get used.
Wybrow is offline   Reply With Quote
Old 11-21-2013, 05:00 PM   #29
_Ogre
_Ogre's Avatar
the frame is going together fast
i like fast, just doesn't happen in my shop
shop air compressor timer
Old 11-22-2013, 12:20 AM   #30
54 CHEVY LR
I like fast. I hope to have this truck complete by june 2014.
I want to finish the frame then start on the body. I am thinking I may need to get the body in sooner as I am trying to decide on the air tank placement. I might go outside the frame. I placed my Gas tank and air tank inside the frame behind the axle, they fit. BUT my filler will not be centered in the box. My dillema.
Any ideas as to how I should install the tanks? this is all new to me
Old 11-22-2013, 12:51 AM   #31
Jyman
you could always put the air tank in the cab behind the seat where the old gas tank would have been, it would be safer then the gas tank sitting behind you
1948 Chevy
Old 11-24-2013, 10:15 AM   #32
Bubba54
Build is looking nice, you'll be on the road before you know it.
Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647
Bubba54 is offline   Reply With Quote
Old 11-27-2013, 12:48 AM   #33
54 CHEVY LR
Not much done this week. I installed the emergency brake cables. Have them run to the brake pedal area. Also conected the air lines to the bags from.the stainless lines. Set the fuel injection body onto the manifold and cut the kick down cable to length, mounted the return springs. Installed the wire holders and made up the spark plug wires.
Old 11-27-2013, 10:14 AM   #34
Wybrow
Looks great, love the engine/transmission colour.
Old 12-04-2013, 01:02 AM   #35
54 CHEVY LR
I brought the truck home today now comes the work. I will be stripping the truck and getting it soda blasted. Never know what hides under the paint.
Installed a Marsh serpentine system on the block.
Drive shaft picked up, ready to polish and install.
Old 12-04-2013, 10:24 PM   #36
54 CHEVY LR
Polished the Drive shaft and got it installed.
Old 12-04-2013, 10:28 PM   #37
54 CHEVY LR
Here are a few pictures of the truck.
Old 12-04-2013, 10:46 PM   #38
54 CHEVY LR
try to load pics again
Old 12-05-2013, 12:05 AM   #39
54 CHEVY LR
March kit minus belt.
Old 12-05-2013, 09:23 AM   #40
solidaxel
solidaxel's Avatar
I love to see projects that do not have a finished budget !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-05-2013, 02:46 PM   #41
oldman3
oldman3's Avatar
That set-up looks great...Jim
oldman3 is offline   Reply With Quote
Old 12-05-2013, 03:59 PM   #42
tpimuncie
tpimuncie's Avatar
LOVE THE DETAIL!! Don't see that much too much anymore Great job!
tpimuncie is offline   Reply With Quote
Old 12-05-2013, 10:53 PM   #43
Root2812
Root2812's Avatar
What size is the wheel and tire you have on the side mount in the last picture? I am having a hard time finding a tire size that doesn't look too big. I like yours.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 12-06-2013, 01:10 AM   #44
54 CHEVY LR
16" 6.oo
Old 12-06-2013, 01:11 AM   #45
54 CHEVY LR
If you want the tire let me know. Send me a om you can have it.
Old 12-09-2013, 09:00 PM   #46
54 CHEVY LR
Removed the front end and Cab this weekend. Frame is in great shape. Cab has some issues I need to fix.
Here are a few pics of the dis-assembly.
Old 12-09-2013, 09:05 PM   #47
54 CHEVY LR
A few more pictures. I have Rotten cab corners , as well as the kick panels on both sides. I expected as much. Once it gets Soda blasted maybee more ghosts will show their face.
Old 12-15-2013, 01:15 PM   #48
54 CHEVY LR
I have the box removed. Built a dolly to move the cab around, did a preliminary on the panel repair needed.
Cab corners were repaired once before, but was a quick fix. I will cut out and replace. Drivers side front cab corner has some metal missing, Dam rust.
Rear fenders were welded to the running boards as they also had some rust and was a quick repair.
Old 12-15-2013, 01:18 PM   #49
54 CHEVY LR
Few pics of the rear fenders and box.
Old frame was in great shape.
Old 12-24-2013, 07:25 PM   #50
54 CHEVY LR
Christmas came early
