11-26-2013, 12:25 PM | #26 |
Re: MPG comparison...How's yours?
Have a 66 short step with a 230 and turbo 350,3.07 out of 72 truck.Just got back from trip to Moultrie got 15.65 cruising 70 the whole way.Think I can fine tune and get a little better,think the vacuum advance went bad on trip.Oh yea,I have 235/75/15 tires on rear.
11-27-2013, 12:36 AM | #27 |
I would say mines about 2 gals to a mile. Tired ol 350, though it still runs ok ...don't smoke or used oil I know it drinks tha gas.
On a serious note though, the gas gauge is broke in my ride, so I'm only guessing. I just stop at stations and try to keep it on the full side. thank god for jiffy cans. |
11-27-2013, 03:40 AM | #28 |
I'll let you know once I get it sorted out but it will be a bone stock 6.0L truck engine with carb for now. My Powerglide because it still works just fine with a Boss Hog Convertor and 4.10 gears. To keep the revs down I'm going with a 32" tall tire on either 18" or 20" rear rims. I will be dropping it 3/4 and I have relocated the batteries and fuel tanks to the rear for better weight transfer.
1965 GMC Longbed
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
11-27-2013, 12:03 PM | #29 |
Here you go.
11-27-2013, 01:14 PM | #30 | |
1500rpm------2000rpm---------2500rpm----------3000rpm--------4000rpm *35mph----------46.44mph------58.16mph-------69.66mph-------93mph **50mph--------66.34mph-------83.mph------------99.51------------132mph Kieth **700r4 |
11-27-2013, 08:26 PM | #31 |
11-27-2013, 09:43 PM | #32 |
The year after next the 200R4 will go in and a switch to 3.54 gears and then some shorter tires if I decide I want to drop it more than 4".
11-28-2013, 12:13 AM | #33 |
283 w/ 600 Edelbrock/700r4/3.90/29" tire. Drove almost 1000 miles on the power tour and got 13 mpg!! Didn't play alot but way better than the 9 mpg we got last year...
11-29-2013, 08:51 AM | #34 |
Smogger 350 / QJet / TH350 / 3.73 in a '66 short wide. Getting 11.5 mpg. That is with no tuning, there is more to get for sure. I'll be hooking up a wide band data logger when I get it off of my other ride...
12-01-2013, 06:49 PM | #35 |
worn out 350 needing valve guide Badly (vortec heads) 200R4 and 3.73 posi 255/60/15 tires. gets 14 mpg all day on freeway doing 65 mph.1964 short fleet BBW. Was getting 8 mgg with leaky Quadrajet and TH350 tranny, then 9 .5 mpg with small Edelbroack carb and TH350, now using small Edelbrock carb and 200R4 tranny...
12-01-2013, 07:45 PM | #36 |
Who Me?
I get around 10 with my 305/TH350 3.08 and 255/70/15's.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
05-20-2014, 08:18 PM | #37 |
1965 Chevrolet C-10 with a 283 bored to .060"-over, an RV cam, Edlebrock Performer Intake, Holley 4360 4-bbl Carb, Headers, SM420 Transmission, 3.08 Rear End, 29" tires.
Assuming little wind resistance - In-town: 15-17 quite regularly. Got 17.4 this last time. By in-town, I mean freeway and city street driving, sitting idling at the drive-thru and intersections, etc. Highway (60-65 mph with very few stops): 17-21, depending on if I'm hauling something, driving hard and fast, or fighting headwinds. |
05-20-2014, 09:16 PM | #38 |
66 short wide, 427 big block with Holley avenger efi,700r4, 3.07 rear end! 28" tires. Getting 11 to 12 mpg. Better than I would have expected!
Steve 66 C10 Short Wide 51 1/2 ton (in storage waiting for 66 to be done) Pickups N Panels Club - Dallas/Ft Worth |
05-20-2014, 09:56 PM | #39 |
Enjoy your truck
This past weekend I was getting between 18 - 20 mpg highway.
2000rpm (65mph) with a 327, my6 4 speed, 3.73:1 ratio rear gear, 285/50/18 tires. Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
05-20-2014, 09:57 PM | #40 |
posted twice by accident sorry.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 05-20-2014 at 10:02 PM. Reason: add |
05-20-2014, 09:58 PM | #41 |
Enjoy your truck
05-20-2014, 09:58 PM | #42 |
230 in-line six stock 373 rear end 350 tranny 12.2mpg
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
05-20-2014, 10:33 PM | #43 |
My 66 C10 5.7 TBI 4L60E 3.73 rear gear 275/60/15 tire 16-18 around town 19-21 on open road 65-75.
05-21-2014, 12:27 AM | #44 |
im guna say bad. 1965 3/4 ton fleet w/ 292 inline 6 rochester monojet carb, HEI distributor, ported cast exhaust manifold, sm420 4 speed with a 4:11 in the back. wish i knew the actual millage, might test it out one day.
05-21-2014, 12:15 PM | #45 |
My 64 averaged 28 mpg on my haul from Dallas to Austin. Only time Ive ever clocked it.
4 cly turbo Diesel, Sm465, 2.92 rear gears 235/75/15s cruising speed of 60-65 The first leg I drove 110 miles on 3.4gal of fuel |
05-21-2014, 12:55 PM | #46 |
Neat. How's the performance with the 4BT and those tall gears + the SM465? I'd like to try a diesel if I come up with one I can afford at some point...
05-21-2014, 03:46 PM | #47 | |
By the way, I couldn't afford a 4bt either. Ive got an oddball under the hood. "3.7L Hercules diesel" |
05-21-2014, 07:48 PM | #48 |
24 combined average with a 4bt ranger sm420 and 4.10 gears running 285-75-16 at 60-65.
I have gotten as good as 30mpg from Grand Junction to Denver before but that is not an average.
63 k20 with cummins 4bt, owned sence 1982 |
05-21-2014, 10:54 PM | #49 |
I have 283 edelbrock 500cfm (primaries leaned out as far as it will go), powerglide with 3:73 rear 235 75 15 tires getting 18 to 22 hwy but only 12 to 13 city. I do have 800 to 1000lbs of tools in the bed everyday and I can tell the weight is direct relation to mpg. When its empty it really moves out..
05-21-2014, 11:56 PM | #50 | |
Neat. I really like the idea of those little auxiliary OD transmissions for the split gears; does that combo do pretty well? |
