05-02-2015, 10:32 PM | #26 |
Re: 71 C10 SWB Project Built
Nice looking project. I like your YJ also
1970 SWB Build |
05-04-2015, 12:15 AM | #27 |
Nice project from me as well, i like the idea of stacking the cab into the bed too. Oh, i couldn't help but notice the crochet extension cords, somebody taught me that one back about 1980 but it looks like you took the middle ones to another level.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
05-11-2015, 10:54 AM | #28 |
Thanks...its my wifes YJ. That was her first vehicle when she turned 16. That will be another project in the future. It has a 4 cyl in it now but later plans for a V8 swap that she doesn't know about yet. lol
1971 C-10 SB 2WD - Project Money Pit Project Build: http://67-72chevytrucks.com/vboard/s...d.php?t=606875 |
05-12-2015, 10:43 AM | #29 |
Nice progress!
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
08-18-2015, 08:25 PM | #30 |
I need some opinions on the rear end...Not sure which direction to go. Anything will help...Thread below
http://67-72chevytrucks.com/vboard/s...d.php?t=679749
08-26-2015, 07:38 PM | #31 |
Here is another picture of the frame painted.
[IMG][/IMG] This is what I used. I would recommend this to anyone. Very durable. [IMG][/IMG]
08-26-2015, 07:46 PM | #32 |
Time to start tearing into the rear end...
[IMG][/IMG] Took it to Danny at PM Machine Shop in Carlinville, IL to weld up the axle tubes to the housing. Did a very good job. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] Wire brushed it and soaked it in brake cleaner to help get gunk off of it. I'm going to put it back together and finish cleaning it further. Then I will be painting it with the same product as I did the frame. [IMG][/IMG]
08-31-2015, 09:38 PM | #33 |
Here is what I'm going to order to rebuild the rear end...all from SummitRacing.com
Eaton Posi 30 spline ETN-19556-010 Moser differential cover MSR-7111 Moser main cap stud kit MSR-7115 Moser axle bearings MSR-9559 Timken bearing and seal kit TMK-DRK322 Yukon axle shafts 30 spline YGA-21257 Yukon axle c clips YGA-33083 Yukon pinion shims YGA-55008 Motive Gear 3.73 ring and pinion 4 series MGR-GM12-373 Moser 1350 yoke MSR-PY100 Richmond carrier shims RMG-3800071 Tonight I cleaned up the rear end. (Soaked with oven degreaser, scraped off all of the grease and wire wheeled it) Put etching primer on it tonight and tomorrow I will be painting it with SEM Rust Shield. I have pictures but I will add them tomorrow.
09-01-2015, 11:57 AM | #34 |
Thanks to CaptainFab...Here are the brakes that I will be putting on the rear end. 94'-96' Impala SS brakes. Great kit! Comes with all the hardware and even a parts list to help you get the parts you need.
[IMG][/IMG]
09-01-2015, 06:25 PM | #35 |
Finally got the 12 bolt painted and its ready for a good cleaning (inside) and all new internals.
09-01-2015, 06:31 PM | #36 |
I painted the back of the caliper bracket and the flange just so there was some protection between the 2 when I bolt them together. I also painted the inside of the trailing arm saddles.
[IMG][/IMG] [IMG][/IMG] SEM Rust Shield [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
09-01-2015, 09:01 PM | #37 |
Cool build! Really interested in the rear brake set up. Going to tag along.
09-04-2015, 10:27 PM | #38 |
Today I finished striping all the internals on the 12 bolt and cleaned it completely out to get ready for the new parts coming tomorrow!!! Had to get out my trusty hammer to help get the job done...
With the pinion, bearings and races removed. You can see how much cleaning I had to do on the inside. I soaked a rag with brake cleaner and taped it to the end of a broom handle. Some spots were a little tougher than others but it turned out nice.
1971 C-10 SB 2WD - Project Money Pit Project Build: http://67-72chevytrucks.com/vboard/s...d.php?t=606875 Last edited by xtremedurb00; 09-04-2015 at 10:39 PM. |
09-04-2015, 10:29 PM | #39 |
Next, now all that gunk was in the housing so had to scrub away on that too. Removed the main caps and wiped everything down with a rag and soaked it all with Autozone brake cleaner. It works wonders.
[IMG][/IMG]
09-04-2015, 10:37 PM | #40 |
Finally got up in the attic of my garage and got some presents down for the C10...21 Gallon rear mount gas tank from LMC and POL tubular motor mounts.
I had some intertubes laying around and used them as a rubber cushion between the tank flange and the frame. Worked out pretty well.
09-05-2015, 05:13 PM | #41 |
I got the gas tank installed today. Looks pretty good. Not happy with how low the tank sits but hey, I'm gonna need a good size tank when that BBC starts up...
Also got my POL tubular engine mount put on too
09-05-2015, 05:20 PM | #42 |
My favorite people in the brown uniform showed up today with some presents!!!
I got everything except the Moser axle bearing and seal kit and Timken differential bearings. Unfortunately, the Timkens are on back order and will be here in 2 weeks. The Moser axle bearings for some reason came in a package of Moser axle studs!?!? Had the correct part number and label, it was just not the bearings. lol. Called Summit and their taking care of me and sending them free of charge! Great customer service!
09-05-2015, 05:25 PM | #43 |
09-09-2015, 09:39 PM | #44 |
Quick question. I was planning on ordering the heavy duty trailing arms from earlyclassic.com but I just happen to run across these. What do you guys think of the price? Anyone have any run ins with this company? I'm probably still going to get the HD ones, just wanted to put it out there for others to see.
Stock replacements - $377.90 for both. http://www.restorationperformance.co...r-control-arm/ Early Classic HD - $499 for both. http://www.earlyclassic.com/fullImag...ion=912-6372TA
09-17-2015, 10:23 PM | #45 |
Update: Today I dropped off the 12 bolt rear end and all the goodies to Seth @ Country Side Repair in Hillsboro, IL. He is going to be building it for me. With a new baby at home, I haven't had the time. But...the build is moving forward!
09-17-2015, 10:25 PM | #46 |
09-17-2015, 10:26 PM | #47 |
09-17-2015, 10:31 PM | #48 |
Got a little time today to put the brake lines on. Had to do a little massaging but the fit nice.
Driver Side Pass Side
09-18-2015, 09:07 AM | #49 |
Next item on the list will be to get the HD trailing arms and 4/6 drop from Early Classic.
09-18-2015, 09:08 AM | #50 |
Does anyone have any pictures of how they have their rear brake lines with the Impala SS brakes??? Just looking for some ideas. Thanks
