#26 |
![]() Join Date: Aug 2010
Re: Bed Fill Gas Cap Pics ????
Might not be what you're looking for but we relocated the tank on my dads truck and he used the stock fuel filler location. Just ran a line from the cab back to the tank. Here are a couple pics
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
#28 |
![]() Join Date: May 2014
Thanks for that. I like your setup, it leaves most of the bed usable. Does yours have a vent line going up close to the filler.?
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
#29 |
My tank has a rollover vent installed on the top. That seems to allow enough air into the tank when it's filling.
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
#30 |
It's not a fleetside, but here's what I did on my stepside. Motorcycle pop-up cap on a filler coming out side of Blazer tank and up to fender. Bending pipe or adding elbows can place it anywhere you want.
#31 |
Mine is pop up as well. When it is closed, you can barely see it
#32 |
Excited to finish mine, so I'll post it. I don't know how you guys were able to make a 90* turn unless you went parallel with the bed first and then turned. I had to use a 3.5" pipe to fill in where the 2" filler ran. But it doesn't intrude at all, still put sheets of wood in and my ATV. Also drilled and tapped the housing for a vent to aid during filling. All connects to a Byod side fill EFI tank.
EDIT: it will all get LineX'ed when I'm ready, so it should blend into the bed nicely ![]() ![]()
'68 C10 SWB '85 K30 Blazer |
#33 |
Nice job. I like that filler.
#34 |
![]() Join Date: Sep 2010
Not mine, but here are two pictures of beds with fill lids that I've saved: . . . . |
#35 |
Using a side fill Blazer Tank. This is how we're doing our filler.
#36 |
I saw this one at Carlisle a few weeks ago. Its a clean look but I'm guessing this wouldn't work very well on a lowered truck.
#37 |
Mine, slow to fill but it works.
#38 |
Here is mine
#39 |
![]() Join Date: Oct 2005
Here's mine.....found cap on a late 80's olds and molded in. Button behind license plate actuates solenoid to open. Works great!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
#40 |
![]() Join Date: Jul 2001
Here's mine on stock height 4x4 long bed.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#41 |
I like the way you think! The first pic shows how I went through the bed cross rail. The finished product was slightly different, but you get the idea. Sorry the pics somehow got rotated.
70 SWB 454/TH400 |
#42 |
![]() Join Date: Sep 2011
Wes, Do you recall make of the filler door u used? Stainless or polished aluminum? thx, D'
1967 C10 SWB Owner - Rustbelt Restorations |
