04-11-2014, 02:31 PM | #26 |
Re: 6L80 4WD to 2WD
3rd of 4
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
04-11-2014, 02:32 PM | #27 |
Re: 6L80 4WD to 2WD
4 of 4
04-11-2014, 02:47 PM | #28 |
Re: 6L80 4WD to 2WD
Looks good.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-11-2014, 04:08 PM | #29 |
Re: 6L80 4WD to 2WD
Thanks Rob! Do you foresee any problems with this? Because I really can't think of any but what do I know.
04-11-2014, 04:55 PM | #30 |
Re: 6L80 4WD to 2WD
neat neat neat!!
04-11-2014, 05:27 PM | #31 |
Re: 6L80 4WD to 2WD
I think u nailed it!
06-03-2015, 02:58 AM | #32 |
Re: 6L80 4WD to 2WD
What was the final outcome? Did everything work as you'd hoped?
06-03-2015, 10:10 AM | #33 |
Re: 6L80 4WD to 2WD
I had to put a 2 or 4* shim(cant remember) on the rear axle to lower the pinion angle but other than that it has about 7K miles with no issues. My son drives it everyday.
06-03-2015, 10:33 AM | #34 |
Re: 6L80 4WD to 2WD
will this also work with a 4x4 4l60e?
'66 chevy lwb c10 '65 chevy lwb c20 |
06-03-2015, 10:45 AM | #35 |
Re: 6L80 4WD to 2WD
You will need to find the short tail shaft housing from a 2wd 4l60e like out of a car with without a slip yoke.
The one I got was for a 6l80 out of a camero. They are not slip yoke tail shafts. Because I had a 2 price driveline I was able to make a slip yoke style work because the front drive line doesn't slip. Hope this makes sense. If you have a 1 price driveline or need the driveline to move in and out of the trans this will not work. The 4x4 tail shaft in the trans has a spline of only about 3-3/4" On my truck the trans connection is a slip style but the driveline is stationary to the center carrier bearing. Again not sure this makes sense without pictures and details
06-03-2015, 03:47 PM | #36 |
Thanks for the heads up on both of your posts today. We kinda resurrected this thread, ha ha. This is good information!
Posted via Mobile Device |
06-03-2015, 04:36 PM | #37 |
Re: 6L80 4WD to 2WD
No problem this is why I started this thread. I had not seen much on this subject.
06-04-2015, 12:01 AM | #38 |
Re: 6L80 4WD to 2WD
06-04-2015, 01:47 PM | #39 |
Re: 6L80 4WD to 2WD
Is the tailshaft on a 4L60E 4x4 different then the car 4L60e with the triangle yoke and black rubber joint? Other than the center bolt?
06-05-2015, 07:06 PM | #40 | |
Re: 6L80 4WD to 2WD
Another issue is the VSS Reluctor wheel is on the Output shaft on 2wd 4L60E. IIRC, The GTO was the only car to use a Rubber joint & a 4L60E, They used a standard 2wd 4L60E & a Slip Yoke. |
06-05-2015, 07:14 PM | #41 | |
Re: 6L80 4WD to 2WD
06-08-2015, 08:11 AM | #42 |
Re: 6L80 4WD to 2WD
This is a pretty cool idea for the guys with a two-piece driveshaft. Lots of 4x4 trannies where I am.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
06-08-2015, 11:40 AM | #43 |
Re: 6L80 4WD to 2WD
Great idea First C10. I'm curious for the 2-piece drivelines, why not just run the 4WD transmission as is w/o the transfer case? Since the driveshaft does not need to slip, is it necessary to change the tail housing, pull the freeze plugs, etc. There is really nothing I can think of that needs lubrication. I would think you could just grease the splines of the output shaft.
06-08-2015, 12:15 PM | #44 | |
Re: 6L80 4WD to 2WD
I understand what you have asked. It sounds like it would be ok. But remember the coupler to the TC is supported by the TC. The tail shaft housing has a bushing that keeps the slip yoke centered and provides support. I wanted to keep the trans somewhat stock looking as the 4wd mount is large and would look like I just made anything work to get it running. (to me at least), it also woulds have a place for debris to be trapped. Another thing , If you look in post #24 you can see the center hump drops down towards the driveline. If you were to use the 4wd transmission mount (see post #2) you would probably have to clearance more of the tunnel. In post #2 the yoke is actually to long so I bought a shorter one. Even though the slip yoke doesn't slip because the center support bearing is rigid the transmission is basically a stock car transmission without the bolt on yoke. Hope this makes sense. Scott
11-24-2015, 05:51 PM | #45 | |
11-25-2015, 12:08 AM | #46 | |
Re: 6L80 4WD to 2WD
11-25-2015, 12:15 AM | #47 |
11-25-2015, 07:59 PM | #48 |
Re: 6L80 4WD to 2WD
Let us know how it works out!!! Good luck.
11-26-2015, 01:04 AM | #49 |
The Older Generation
Re: 6L80 4WD to 2WD
I have a couple of questions on your swap 1. What did you end up using for the bushing and seal in the camaro housing, and 2. Would you happen to have the part numbers for the bushing and seal? One of the posters in the thread asked if this would work on a 4l80e but there was no response to that question. Clinebarger stated it wouldn't work on the 4l60e but I would like to try using it on a 4l80e. Thanks, LockDoc
11-26-2015, 03:08 PM | #50 | |
Re: 6L80 4WD to 2WD
The tailshaft housing I used came with the housing, bushing, seal and was even lubed up. I just added the o'ring where the housing attached to the transmission.
