Old 01-23-2014, 10:26 PM   #26
TR65
TR65's Avatar
Re: New Info
I really like my scan gauge. I use it for the digital speedo, a very accurate fuel level gauge, temp gauge, and tach. Of course you can see any gauge you want like the average fuel economy in the picture. You can calibrate it very accurately over time. The 17.8 mpg is correct.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 01-23-2014, 11:56 PM   #27
Andy4639
Old member
Andy4639's Avatar
Talking Re: New Info
TR
Yes I bought one the other day. It looks nice and looks to have a bunch of promise for the LSx motor info. I will have my factory gauges also but it will be nice to compare the 2 and see how they match up to one another.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-24-2014, 02:46 AM   #28
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: New Info
Handheld tuners arent' the same thing....and most handheld tuners are really only useful on certain vehicles. When I had late model chryslers', you had to have one for the srt4/8s that we did, but since working with late model GM efi, there just isn't a replacement for HPT. Buy a scanguage, save the rest of the money.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-30-2014, 10:52 AM   #29
Houston Ben
Houston Ben's Avatar
Re: New Info
I just bought the Scan gauge II, it is nice but unfortunately it is telling me I am only getting 14-15 mpg at 70mph
Houston Ben is offline   Reply With Quote
Old 01-30-2014, 02:42 PM   #30
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: New Info
It uses injector pulse to guess that, assuming you calibrated the tank and fillup system, that still might be off. The mpg calc isn't really that great, tho I find its usually as accurate as the lie-o-meter that comes on cars these days.
That being said, I don't think thats terrible for hurling a brick into the wind.
Old 01-30-2014, 04:29 PM   #31
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: New Info
even with these bricks....rpm at cruise still makes a huge difference in mpg. If you want the big mpg numbers...your cruise rpm needs to be at or below 2k rpm...every 100 rpm's or so above that is dropping the mpg that much more. the lower the better (to a degree).
My TBSS with 4.10's is running like 2200-2300 rpm at 70mph and 2500 rpm at 80mph (IIRC)....and it rarely gets better then 17mpg. I had a bigger/heavier 6.0L full time AWD, 2001 Sierra C3 that got better mpg's with its 3.73's.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-30-2014, 09:06 PM   #32
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: New Info
^ see mine's all wacky because I have a 3:73 and turn the same RPM's roughly (4l80e), and I can get 17-19 give or take freeway (but I also have those steel 12" wide wheels in back)
Old 01-31-2014, 05:56 PM   #33
68GMCCustom
Re: New Info
well I rechecked and I was off on the rpm's.....70mph is closer to 2500rpm with the 4.10's.
tire height makes a difference too.
is there a difference in an 80e's OD ratio and a 60e's? seems they are close...like .05 or .10 difference or so. can't remember.
Kurt -
Old 01-31-2014, 08:03 PM   #34
Andy4639
Old member
Andy4639's Avatar
Wink Re: New Info
That sounds more like it. Mine is 4:10 gears with the 20" tires and driving it to Greenville last Saturday was about 2500-2600 per the scan gauge. My regular tach want be right until the tuner gets his hands on it.
Old 02-01-2014, 03:23 PM   #35
Custom 68
Custom 68's Avatar
Re: New Info
Just flip the switch on the back to "4 cyl" mode and all fixed on your tach...
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 02-01-2014, 07:19 PM   #36
Andy4639
Old member
Andy4639's Avatar
Wink Re: New Info
Nope, not that easy on the Speed Hut gauges!
Old 02-02-2014, 08:16 PM   #37
Andy4639
Old member
Andy4639's Avatar
Question Re: New Info
Played with the scan gauge today. I got it to take the transmission codes and it saved it but it has no signal showing!
Can are will the computer tunner be able to turn this on in the computer when he does the tune? I was told the 4l80e should have the signal in the computer in a stock setup which I realize mine isn't.
Anyone have any thoughts on this? I sure would like to have a temp reading on the trans.
Old 02-05-2014, 10:39 AM   #38
smartass12
smartass12's Avatar
Re: New Info
Originally Posted by BR3W CITY View Post
Mine is 50% of my dash. I use it for a speedo, temp, oil temp and voltage gauges. Works simple, and color matched the other blue interior lights that I had.
Take a look through my build again, or take a look at the Truck Light Test video on my YT channel to see it litup/working.
Lights Test in the 66 C10 - REV J HD - YouTube
Did you have an issue with it connecting? My port might be wired wrong because as soon as i plug it in (without the ignition on it) It starts to try to connect but fails. I believe it should only turn on with the ignition.
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
Old 02-05-2014, 04:36 PM   #39
Andy4639
Old member
Andy4639's Avatar
Wink Re: New Info
Mine only comes on after cranking it up. It works fine just no signal from computer n the transmission.
