01-18-2014, 07:28 PM | #1 |
Old member
New Info
Has anyone added one of these since they put their LS engine in? Seems like it would be a good info source to have and it plugs into the aldl connection and has real time data. I think I may invest in one.
Scan Gauge 2 II OBD2 Performance Monitor Scan Tool Trip Computer Digital Gauges
01-18-2014, 09:06 PM | #2 |
meowMEOWmeowMEOW
Re: New Info
Mine is 50% of my dash. I use it for a speedo, temp, oil temp and voltage gauges. Works simple, and color matched the other blue interior lights that I had.
Take a look through my build again, or take a look at the Truck Light Test video on my YT channel to see it litup/working.
01-19-2014, 07:38 AM | #3 |
Re: New Info
so Brew, when you datalog etc, do you unplug your scangauge 2, or do you have two aldl ports?
1988 GMC c1500 SWB D/D RHD 5.7L 700R4 |
01-19-2014, 10:25 AM | #4 |
Old member
Re: New Info
BR3W CITY,
Cool video! Well I wil be buying one at Auto Zone later this week I hope. They have them in stock.
01-19-2014, 06:30 PM | #5 |
meowMEOWmeowMEOW
Re: New Info
Theres this interesting place called Amazon.com, they sell them cheaper.
I unplug the scangauge to log. The computer displays all the same info that the gauge would, and I still have an analog tach to look at on the dash. Sometimes running two Aldl ports works, as I've heard from some...but certain things like HPT don't like to work with the other devices.
01-19-2014, 07:04 PM | #6 |
Old member
Re: New Info
Yea I'm going to look around and see. E-bay was the same price as the store. I may get the windsheild mount also but have been thinking about putting it in the ash tray with a flip up for it.
Amazon is same price also. $159.95 Amazon.com: ScanGauge II Ultra Compact 3-in-1...
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-19-2014 at 07:50 PM. |
01-20-2014, 12:28 AM | #7 |
meowMEOWmeowMEOW
Re: New Info
It can plug in from behind OR the right side, so you can flush-mount it to the dash/ashtray without exposed wiring.
01-20-2014, 01:06 AM | #8 | |
Old member
Re: New Info
01-20-2014, 10:49 AM | #9 |
Re: New Info
What about those cheapo bluetooth devices that hook up to scan pro or torque scan or what ever it is and monitor it on your phone or other device you might already have? I saw one a buddy had but didn't play with it much. I may grab it and give it a shot. I have HP tuners for the real stuff...
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
01-20-2014, 03:28 PM | #10 |
meowMEOWmeowMEOW
Re: New Info
They work physically, though I don't know how good the refresh rate on the information is. With the scanguage plugged in directly, there is still a few milliseconds delay, which can be less than ideal for things like an accurate tach signal.
For things like speedo or pressure/temp sensors, it should be fine as the refresh rate on the information is unaffected by a small delay. I.e your temp sensor won't see huge changes in fractions of a second, nor does the EXACT value matter as much. The difference between 198* and 199* on a gauge doesn't really matter (egt's excluded)
01-20-2014, 05:02 PM | #11 | |
Old member
Re: New Info
01-20-2014, 09:15 PM | #12 |
Truck and auto performance nut
Re: New Info
I run an Aeroforce Interceptor. Does the same basic things I believe...but only shows 2 results. It does however allow for pairing 2 Interceptors to give you 4 results. It also allows for two +/-5v inputs for each gauge...for like running 02 sensors for air/fuel readings or something else.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
01-21-2014, 07:56 PM | #13 |
Old member
Re: New Info
I picked it up at Auto Zone today. They had it on sale for $149.99! $160.00 even out the door.
01-21-2014, 09:53 PM | #14 |
Re: New Info
with these '96up obdII powertrains........and communicating with them.........now days you HAVE to have something like this, at the least.
01-21-2014, 10:24 PM | #15 |
Old member
Re: New Info
I have the actron scanner also. It's just a basic scanner. I may invest in a good scanner though. Anyone have a good suggestion on a good one to buy.
01-22-2014, 12:15 AM | #16 |
Re: New Info
you may find you can do it all with your new scan gauge.
01-22-2014, 01:58 AM | #17 |
meowMEOWmeowMEOW
Re: New Info
Yup, mine clears codes etc just fine.
See its like this My check engine light comes on and And then the scanguageII goes And so my truck is like
01-22-2014, 02:44 AM | #18 |
Old member
Re: New Info
Yea I don't worry much about codes as long as the truck is running. The old setup kept odd codes all the time that's why I put a toggle switch on the check engine light so I could cut the light off.
I had hawks just coil the engine light up for now until I decide where I want it. That reminds me what kind of bulb are you all using for this? As far as scanners I was thinking more on a scanner that can check for anything not just engine stuff but for all electrical stuff in the 08 Tahoe and 2014 camaro and the wifes 2011 Treverse.
01-22-2014, 09:39 AM | #19 |
Re: New Info
Andy, there are some that use a laptop. the big step up would be to go to hptuners that gives you lots of scan and code clearing options and it also gives you the ability to tune. It is much more spendy than a code reader.
I am sure the new scan gage you got will read and clear codes also. It is handy to know what the light is on for even tho it is running fine. Good luck and hope you get it going this week. PS.LOL Brew, that was very visual...
01-22-2014, 10:17 AM | #20 | |
Re: New Info
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-22-2014, 07:50 PM | #21 |
Old member
Re: New Info
Yea these are the ones I was thinking about. HPtuner are something like it. My only concern is I would get into it and mess something up and have to pay Bruce again to redo it.
01-23-2014, 09:39 AM | #22 |
Re: New Info
it is like writing an essay or something Andy, just save save save...
When I mess with mine I always have an original known good one saved usually a few places... like a work computer and your laptop that way we can always go back. There is a ton of things that can be changed. I had mine tuned initially back in 2005 and it was awesome they did a great job. I added a cam and they did a retune and again awesome. When I went turbo the tuning got harder, then I went 2 bar system and figured I better get the software and tune. Now the guy I used included retunes so any changes he can just e-mail them to me no more sending the computer. plus I find it intimidating to the other racers when I am in the pits tapping away on my laptop...
01-23-2014, 04:05 PM | #23 |
Old member
Re: New Info
Well that good info to know right there. I haven't talked to Bruce at length at all about his tuning. I guess I need to. I'm not planning on racing it any except to see it go down Z-max in June. I want some good pictures of it on the track.
Thanks can't wait for June to get here.
01-23-2014, 07:09 PM | #24 |
Re: New Info
Nice, I will be looking into this!!
01-23-2014, 09:02 PM | #25 |
Old member
Re: New Info
I found this article tonight and will find out from Hawks before I buy anything. But for a stock setup LSx in a truck this maybe the way to go.
Why is it no one does anything for the Truck guys! Handheld LS1 Tuners - Tuned In Eight Hand held LS1 Tuners Go Head-To-Head On The Track And Dyno-And The Results Might Surprise You By Rick Jensen, Photography by Rick Jensen GM High-Tech Performance, May 01, 2008 http://www.gmhightechperformance.com...n/viewall.html
