Old 02-09-2014, 03:49 PM   #26
NEWFISHER
NEWFISHER's Avatar
Re: Goldie coming along
Originally Posted by FlowerForwarder View Post
That question needs to be answers by Curt Ukasik the owner of RPM Hot Rods. Fabrication work is his specialty. Search his name on the internet. He has won plenty awards from the GoodGuys as well has the builder of the year for a SEMA CATEGORY.
Great work he did under the bed!
Your fans demand pics
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 02-09-2014, 05:03 PM   #27
mano
mano's Avatar
I hate to answer for Curt and his guys, but Jim ask if I could explain. The bags are in the stock location were the springs use to be, with a 2in drop block. There is a pipe notch installed. Maybe the notch is little higher then yours. His tire size is smaller also. I know that doesn't raise the rear end but it gets the truck lower to the ground. There were no pictures taken of the install. Maybe Jim can shoot you pics after its finished. It has basically the same air ride parts you have from Boris. Bags are airlift 2500s. Hope this helps
mano is offline   Reply With Quote
Old 02-09-2014, 07:04 PM   #28
NEWFISHER
NEWFISHER's Avatar
Helps a ton Mano, thanks. It must be his tire size that drops it a couple inches lower in the pics. Same set up as mine too, same bags,location etc. I used a 5 1/2 inch 1/4 wall pipe and have a deeper notch than a bought one but the deflated bag stops the 3rd just as it touches the bed floor. I would cut my floor and use 1 1/2 inches more of the notch, but the bags stop it from going lower. I need to come off the side of the frame or something.
GOD BLESS AMERICA!
Old 02-09-2014, 07:54 PM   #29
RPM HOTRODS
RPM HOTRODS's Avatar
Hey Guys, I'll try to find a little time tomorrow to post up a few pictures or I'll send them over to Jim to post.
In the front we weld the flat bottom plate, then the top flat plate we notched so the bag would fit inside when deflated. We did take pictures. The fronts also drop spindled too. It sits the front flat on the ground and the tires touching the factory inners with a 215/70/15. I used the bigger Firestone bag on the front just cause it collapses down better the the AirLift bag.
In the rear we build our own weld in notch, I plate the inside rail for strength and use a 6.5" inside diameter pipe to fit the axle and u-bolts into a little better. I spent a little time with it on the rack just grinding little issues to make sure everything cleared the way I wanted it to. Has a 2" block, Airlift Bags stock locations, Rear end goes thru the bed floor (no kissing it here). But still not crazy like I'm use too. But I think we trimmed it off nicely!!!
Double switch panel, dual needle gauges, 5 gallon tank, 2- ViAirs 444s, 175 pressure switch.
Hope that helps!!!
RPM HOTRODS is offline   Reply With Quote
Old 02-10-2014, 01:30 PM   #30
ol_skool_chevy
ol_skool_chevy's Avatar
I'm liking it . cants wait to see it in color
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 02-10-2014, 01:39 PM   #31
cutb4udye
cutb4udye's Avatar
Oh yes!!!
cutb4udye is offline   Reply With Quote
Old 02-19-2014, 04:41 PM   #32
Desert.Chevy
Desert.Chevy's Avatar
Hope we dont have to wait to long.
Hope that helps!!!
Did you have time to find the pictures?
I think were all dying to see pictures of the setup and paint if thats done.
Desert.Chevy is offline   Reply With Quote
Old 02-21-2014, 01:30 AM   #33
**grumpy**
**grumpy**'s Avatar
Looks good Jim, but Ive said that on IG and FB already lol
Road Hounds
**grumpy** is offline   Reply With Quote
Old 02-21-2014, 11:51 AM   #34
kieth
kieth's Avatar
Originally Posted by flowerforwarder View Post
- air bags
- drop spindles
- custom fab work from www.rpm-hotrods.com
- power disc brakes
- front tire size 215-70-15
- stock fender wells . It will lower about a 1/2" more if removed.
- custom c-notch by www.rpm-hotrods.com
- small rectangle opening for rear pumpkin to nest up into bed when aired out.
what mods did you do the the front end besides spindles ? Air bags of course up front and rear but did you section the crossmember or add cups to the lower control arms ??? I have a build in process and do not really want to make it layout but just sit like yours does when lowered and then raise to go down the road.....thanks kieth
kieth is offline   Reply With Quote
Old 02-21-2014, 05:24 PM   #35
FlowerForwarder
Hope that helps!!!
FlowerForwarder is offline   Reply With Quote
Old 02-21-2014, 11:16 PM   #36
ol_skool_chevy
I wish I knew what bigger Firestone bag collapses down better.
flattest one I have seen was 2.7 inches..
Mark with Chalk
Cut with a torch
Old 03-02-2014, 08:20 AM   #37
FlowerForwarder
All coming together!!!
Old 03-02-2014, 09:47 AM   #38
Bigru
Bigru's Avatar
Where's the pics?
1965 Short Fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=637478
1983 Short Fleet (Under construction for my 13 year old son)
2008 GMC Denali
2012 Harley Roadglide
Follow me on Instagram: Ru_django
Bigru is offline   Reply With Quote
Old 03-02-2014, 09:54 AM   #39
FlowerForwarder
Originally Posted by Bigru View Post
Where's the pics?
Here are some...still at ww.rpm-hotrods.com
Old 03-02-2014, 12:27 PM   #40
boonedogs72
boonedogs72's Avatar
Looks great!
boonedogs72 is offline   Reply With Quote
Old 03-02-2014, 06:35 PM   #41
tazattitude
tazattitude's Avatar
Super sharp!
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 03-04-2014, 10:29 PM   #42
FlowerForwarder
The stance!!
Old 03-05-2014, 02:29 AM   #43
NEWFISHER
NEWFISHER's Avatar
Nailed it!
GOD BLESS AMERICA!
Old 03-05-2014, 09:30 AM   #44
ol_skool_chevy
That is sweeter then honey on a warm buttered biscuit
Mark with Chalk
Cut with a torch
Old 03-17-2014, 12:42 AM   #45
Desert.Chevy
Truck looks great.
Can I see pictures if zero air, ride(alinment) height, and full air.
Old 03-17-2014, 10:57 AM   #46
FlowerForwarder
On to the interior
Old 03-17-2014, 01:22 PM   #47
64chevtruck
Okay, thanks for the pics of your fine truck. That satin gold looks perfect with the red rims, caps, and rings, any suspension pics?>
Have a good week
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 03-17-2014, 01:27 PM   #48
FlowerForwarder
Have a good week
The truck is still at RPM HotRods doing the interior...will take complete pics when it returns.
