Goldie coming along
Brillant work coming from www.rpm-hotrods.com
New air ride with stock arms and original bed floor height! Heading for paint next week....more to come! |
Re: Goldie coming along
wow....very nice!
Love the stance, Beautiful truck.
Very nice....... Is that rear bumper low or is it just the angle.
I have been looking for those filler pieces that go between the rear bumper and the bed
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Bumper shot
Going for paint? Wth, it looks perfect as it is!
![]() Join Date: Mar 2013
Looks perrty!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Agreed, I would drive the heck out of that thing, man that would be a blast to drive!
Let's see the bed. Curious if the pumpkin is poking through? Mine touches the underside of the bed floor and pushes the boards up a little,but isn't as low as yours.
GOD BLESS AMERICA! |
What tire size?
NewFisher- Yes, Pumpkin is up...small rectangle is cut-out, with "leather" patch over.
sorry no pic - truck is still at www.rpm-hotrods.com Tires - BF Goodrich - from Coker F P215-70-15 R P225-70-15 |
![]() Join Date: Sep 2009
no paint needed DRIVE IT!!!!!!!!!!!!!!!!!!!!!!!
#13 |
I've been following the progress on Instagram, love the look of your truck now. Looking forward to seeing the finished product.
Keep us posted. |
#14 |
Instagram ?
#15 |
#16 |
Nice truck man.
No trees were killed to send this note but a large number of electrons were terribly inconvenienced. AKA. RABIDJOE... if you have to ask you prob don't want to know. Ive had my shots *dont worry* 1960 235 4SPD C30 |
#17 |
This is a photoshopped picture of the truck that a board member did a few months back...... Next week it should look pretty close to it!!!!
#18 |
from a distance
#19 |
So.......... You running air bags Only or air bags and drop spindles and rear c notch.
also aired out are you front tires in stock inner wheel wells??
#20 | |
- Air Bags - Drop Spindles - Custom Fab work from www.rpm-hotrods.com - Power Disc Brakes - Front Tire Size 215-70-15 - Stock Fender Wells . it will lower about a 1/2" more if removed. - Custom C-Notch by www.rpm-hotrods.com - Small Rectangle Opening for rear pumpkin to nest up into bed when aired out. |
#21 | |
its looking good Jim. |
#22 |
Very classy.
Did you decide to white out the upper cab or just keep the white roof panel?
#23 |
What location are your rear bags? Plates off the frame and onto the arms further away from stock location or same spot as coil spring. If same spot as coils, what bags? Mine bottoms out on deflated bag (stock location) and won't go lower or push tube into notch. My 3rd member kisses the flor and even if I cut the floor, the bags wouldn't allow it to go any further. Any pics of your rear set up?
#24 |
#25 | |
Great work he did under the bed! |
| Bookmarks |
