Old 02-27-2014, 04:25 PM   #26
Super73
Super73's Avatar
Re: Can't decide what gears to run...need opinions
I am not big on mail order tunes. It is one thing to set shift points, fan settings, correct Speedo, and things like that. But for wot tuning or idle with a decent sized cam there really needs to be a wideband in the vehicle and either on the dyno or at the track. Simply put, no one can get nail air fuel and timing with out being there with the vehicle or at least having a customer log with hptuners or efi live and e-mailing tunes back and forth.
Example, I have had two Camaros with the exact same mods on the same dyno on the same day (they were cousins). One wanted more timing and more fuel while the other wanted less timing and less fuel but they made with in 5rwhp of each other.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-27-2014, 04:42 PM   #27
Jmiller022
Jmiller022's Avatar
I currently email my tunes back in forth, but wonder if my guy could do what your talking about with the converter..
68' c10 stepper 5.3/4L60e
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917
Jmiller022 is offline   Reply With Quote
Old 02-27-2014, 04:50 PM   #28
Super73
Super73's Avatar
Any halfway decent "tuner" should be able to. Do you have hptuners? If so, e-mail me your tune and will see if I can help you. Shaunliddy@hotmail.com
Old 02-27-2014, 05:06 PM   #29
Jmiller022
Jmiller022's Avatar
no just efilive at the moment. also no TC yet. trying to decide on a brand
Old 02-27-2014, 07:56 PM   #30
ivorton74
ivorton74's Avatar
I will put it out there again. With an auto trans, gears have less of an impact on performance than the torque converter does. With a lock up OF trans, unless you are towing, I would put a fairly big converter in the truck and keep a very tame gear.
I have run 1.67 60's with a heads cam 5.7 with 3.73 gears and a 30" tire. I am quite sure I could have gone in the high 1.5's if I had a 5,500rpm converter vs the 4,500 I had in the truck.
My point, even a 3,200rpm verter coupled with a 3.73 gear will out run a stock converter with 4.56's.
I will be changing again from a 4.56 to a 3.90 in the coming months and will be happy to share the info again.
my boss on work was telling me I should run a 2800 or 3000 stall converter on my truck...I may have to eventually cuz I want to put in a nice cam and upgraded the valvetrain
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 02-27-2014, 09:01 PM   #31
Super73
Super73's Avatar
Imo no reason to not go bigger with the right tuning.
