Can't decide what gears to run...need opinions
I've searched here on the forums and read threads but still can't make up my mind about my rear gears. I'm swapping a 5.3/4l60e in my truck with 3.08 gears. On one hand I know it might be good for fuel economy which is what I want but on the other hand I want that low end and passing power along with the fun factor. So its between the 3.08, 3.42 or 3.73...which do I run? Truck is going to be a daily driver and around where I live there is a lot of 55, 65 and 75 mph highways. I'm running 235/75/15s but may run 275 or 255/60s down the road too.
It's alsways something.....
![]() Join Date: Nov 2008
Re: Can't decide what gears to run...need opinions
3:07 is too tall with OD in my opinion. I run 3:73 with 29.3" rear tire. I've heard that 3:42 would be nice, but AFAIK that gear set wasn't an option in the 71/71 diffs
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
I have 3:08's in my '71 swb with a 5.3/4l60e and I get around 17-18 mpg regardless of how or where I drive. I thought on the highway it would do better, but I think they're just a bit too tall and take the engine out of its optimum performance range trying to keep the truck moving. My last twoo trucks had 3:73's and I like that fear better. If my truck didn't have the factory posi in it, I would have already changed it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
hotrod mag gave 3:55s the best of both worlds votes, like the 3:42s in my Bird.
Chevy GMC Trucks Find Of The Day https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I put in 3.73's and I like them just fine, like others have said, 3.08's are too tall ( that is what I had), so I think you will be happier with the 3.73's but 3.42's are a nice happy medium.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I vote 3.42 or 3.73 for daily driver duties. Remember, you have OD with a lockup converter, so the 3.73's aren't going to hurt at higher speeds. I'm running 4.11 in my truck and it still does fine at 80.
#7 | |
3.42 is my "go to" gear and then I move up or down depending on the specific need. With an overdrive I would recommend 3.73 (which is what I have in my truck). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Registered Cruiser
I am switching to 3.73 this weekend! 3.08's don't do justice to the 5.3/4l60e, no need for the tall gears with that overdrive. Can't wait to get the outta there... then it's on to the tuner!
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
i have 3.73's and a 700r4 currently. with 255/60-17s its about 2000 rpm at 65mph
Had I a choice I'd put 3.42s for the long trips I plan on taking in this thing. |
well 3.73 it is then. im gonna run my 3.08s for the time being until I can save some cash and get a 3.73 with a posi unit.
I'm running 3:42's for daily highway driving, still has tons of bottom end....I had 3:08's in it, crazy top end, still pulled pretty hard....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Truck and auto performance nut
changed my trucks 3.08's to 3.73's years ago. Seems like the best 12 bolt performance/economy compromise. Like 3.55 as an option too. otherwise go....
4.10-4.56 for performance 3.55-3.73 for performance w/economy 3.23-3.42 for economy w/performance 2.56-3.08 for straight economy
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#13 | |
#14 |
I have a 2011 5.3 w/6L80 and 3.42 gears no posi. I can peel on will... I am putting in a True Trac this week to hopefully help with my tire spinning problem!!!! I run around 2000 rpm @ 70 mph
#15 |
Fabricate till you "puke"
On a 29" tire, with OD....3.73 will be the best "all around gear'. If you are more into performance, I would go 4.10? I have 3.42 gears in my truck...1 st is deep, & OD is .76. The old truck will cruise @ 100-105 mph, @ 3100 on the tach in OD? 4.10,s were a little deep with that combo & a 383....unless you like to run 90 mph in an 1/8 mile (not the best way, on a street ride)! The 3.42's, will be a freeway flyer , with the OD
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#16 |
Its pretty much all highway where i live so highway mileage is important right now but i would like a bit of performance at the same time
#17 |
What do plan to run for tire size(diameter)?
#18 |
Im currently running 235/75/15s but will change to either 275/60 or 255/60 15 tires eventually
#19 |
![]() Join Date: Nov 2012
I'm running 275 60 15's, 3:73's,5.7 w/ 4l60e. I've been on a 4000 mile trip the last few weeks and I've been getting 18-20mpg. I had thought about going to 3:55's before the trip, but 18-20 makes me happy. Running about 2100-2200 rpm at 75mph. With that being said I would go with 3:73's. Dave
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build http://67-72chevytrucks.com/vboard/s...d.php?t=589869 |
#20 |
I will put it out there again. With an auto trans, gears have less of an impact on performance than the torque converter does. With a lock up OF trans, unless you are towing, I would put a fairly big converter in the truck and keep a very tame gear.
I have run 1.67 60's with a heads cam 5.7 with 3.73 gears and a 30" tire. I am quite sure I could have gone in the high 1.5's if I had a 5,500rpm converter vs the 4,500 I had in the truck. My point, even a 3,200rpm verter coupled with a 3.73 gear will out run a stock converter with 4.56's. I will be changing again from a 4.56 to a 3.90 in the coming months and will be happy to share the info again.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#21 |
Does the higher stall change the highway manners any? Or does it just affect the "launch" performance. Converters still mystify me...
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
#22 |
So your saying a 3k converter and 3.23s would be good?
would the converter not hurt mileage though while cruising?
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 |
#23 |
With a lock up converter mileage on the freeway is not sacrificed at all. What I like doing for customers with big stalled 60e or 80e transmissions is:
Under minimal throttle, short shift the 1-2 and lock the verter early. This keep heat way down in the trans. I progressivly increase shift mph based on throttle postition as well as lock up. I have people running 4000-4400 rpm converters and still getting mid 20mpg on the freeway with 3.23 gears and cutting high 1.5 - low 1.6 60's in f-bodies.
#24 | |
#25 |
haha I was thinking the same thing. I'd prefer a chassis and street tune, but I might get a better tune from you without you even setting eyes on it
