#26 |
![]() Join Date: Oct 2009
Re: Lets see your motors, Stock to wild
From stock 230 to Cadillac 500.
#27 |
Here's mine
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#28 |
Here's with I installed with Chevelle headers....
#29 |
My 650hp 454
65 Chevy C-20 Chopped 3", Doors Suicided, completely shaved, 650 hp BBC |
#30 |
Those other motors are beautiful...here is mine. Built it myself.
383 Stroker, 9.8:1 compression. Measly 420 hp but WAAYYYY more power than I'll ever need... First photo is where I started...second photo is where I am at currently. Notice, I have the brake booster bracket from Captain Fab at the top of the second picture...he does nice work and it's an easy bolt up for those who want to go to disc brakes...
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
#31 |
![]() Join Date: Aug 2012
Here's the 383 I should be getting in my truck this summer ... specs below pics ... headers and oil pan have been swapped out for different ones ...
![]() ![]() ![]() 383 4 bolt main 9.8 - 1 compression Scat Rods & Crank KB hypereutectic pistons - 12cc D-dish AFR 190 heads (older non Eliminator) Comp Cams 1.5 ratio Stainless Roller rockers Comp Cams beehive valve springs Comp Cams 280 XFI retro hydraulic roller cam 230* 236* @ .050" 113* LSA Lingenfelter/Accel Super Ram intake, plenum/ runners Holley 58mm throttle body Holley adjustable press regulator 30# injectors Fluidampr balancer Davis DUI big cap HEI for TPI setup Pete Jackson quiet gear drive All going in front of a T56 6 speed tranny
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
#32 |
![]() Join Date: Mar 2011
Here's what I started with and where I am now. 350 HO crate with 330hp and Edelbrock EPS manifold and other goodies. Still a work in progress.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
#33 |
Temporary 5.3 for mock up. Will eventually be a LS2 with LS3 heads. Intake is from Inglese with 48mm Weber IDA's that I'll swap out for 51mm Empi EPC's. Valve covers are from a 283, reshaped to fit the oval LS valve cover flange.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#34 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Thanks for the plug Tom
![]() That engine bay is looking very nice Quote:
#35 |
High compression 355 in sheep's clothing awaits its ram air filter assembly. Corvette ram horns mate to 2.5" exhaust pipes with Brockman's headers.
| Bookmarks |
