Old 03-15-2014, 05:19 PM   #26
ls1nova71
ls1nova71's Avatar
Re: been doing a lot of research and....
Originally Posted by dman1982 View Post
How did you do the return lines?
Those are both the feed and return lines up to the corvette filter/regulator. The feed out of the filter to the engine isn't ran yet in those pics.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-15-2014, 05:20 PM   #27
dman1982
dman1982's Avatar
Gotcha, I see a lot of people using a t fitting back to the sending unit
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 03-16-2014, 02:41 PM   #28
BlueJeep
BlueJeep's Avatar
I also have the SUR&R kit but haven't installed the lines yet. I thought about running the nylon lines through some larger diameter fuel lines or similar before I push the ends on where it might rub on something, then secure it well. I'm kinda exploring OEM plastic clips that are used to mount the lines as a viable option for securing the nylon lines....but I haven't found much on that yet.
LS1Nova, I like how you did your lines. Are you using a mastercool or similar flaring tool to re-create the push on "flare"?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-16-2014, 02:52 PM   #29
dman1982
dman1982's Avatar
sur&r kit?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-16-2014, 03:43 PM   #30
ls1nova71
ls1nova71's Avatar
Running the nylon through some regular rubber hose before putting the connectors on is a good idea for locations where anything could possibly rub.
I also tried to find some factory clips to hold the nylon lines, but they are usually big and hold4 or 5 lines and are kind of bulky. I wandered the pick-n-pull for a long tome and never found anything nice and compact looking. I still keep an eye out when I'm there, so maybe ill find something sometime.
And to answer your question, yes, I'm using a Mastercool hydraulic flaring tool. The best flaring tool you'll ever use! I've had several of the older kind and they are just a pain to use sometimes. It wasn't cheap, but for as many swaps as I do, I decided to splurge. With it and the Dorman kit I have about $500 in my fuel system, which is about what some people spend on AN fittings and braided line.
Old 03-16-2014, 03:56 PM   #31
ls1nova71
ls1nova71's Avatar
sur&r kit?
Its the fuel line repair kit that was posted earlier .by jorgensenc.
Old 03-16-2014, 03:57 PM   #32
dman1982
dman1982's Avatar
Duh...lol...hopefully mines here this week
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-16-2014, 10:23 PM   #33
BlueJeep
BlueJeep's Avatar
Glad to hear that you like it, because I bought the Mastercool too but haven't used it yet. I really would like a mix of hard and nylon lines, and you've done exactly what I've been thinking about. I assume you also did something similar up at the fuel rail (hard line most of the way, then nylon).
The 4-ish line clips are what I've seen so far too. I've done some google searching and haven't turned anything up that way either.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 03-17-2014, 11:53 AM   #34
ls1nova71
ls1nova71's Avatar
The only problem I've had with my Mastercool flaring tool is the line will sometimes get stuck in the die for the push to connect flare. I've found out that sanding the coating off the line helps.
Old 03-22-2014, 12:58 PM   #35
dman1982
dman1982's Avatar
Originally Posted by jorgensensc View Post
It was a very simple setup. I don't have any pics, but I may be able to get some in a day or two. And yes br3w is right. That is what the piece was. I will try and get a part number for you when I get the chance. Hope this helps some!
Shawn
i should be ready to put the fuel system in here in a couple hours, did you ever have a chance to take some pics?
heck id like to see some pics of everyone else's pics too
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
