Old 03-11-2014, 02:40 PM   #1
dman1982
dman1982's Avatar
been doing a lot of research and....
starting to feel better about the fuel delivery to my 5.3 swap, but looking at google i seen some guys doing the 5.3 swap and using regular hose and clamps on their fuel lines....does this work? i thought it would just blow off? ya know being high pressure and all....am i wrong?
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 03-11-2014, 03:41 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: been doing a lot of research and....
You can use sections of FI rated fuel line and FI clamps. They are still a rubber line and hose clamp, but the stuff is reinforced to handle the pressure, and the clamps don't dig into the line the same way. Its still ideal to keep the rubber hose sections to a minimum. I started mine with rubber, but ended up replacing it all with braided stuff shortly after.
NHRA tracks don't like to see rubber hose, i think its less than 24" total. You'd have to cross check me on that number tho.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-11-2014, 03:45 PM   #3
dman1982
dman1982's Avatar
Oh gotcha...those an fittings freak me out some lol, I know what clamps your talking about, I think is what I'm going to do is the rubber lines til I can get it over to the guy to have these lines made up
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-11-2014, 06:10 PM   #4
akdg87
akdg87's Avatar
i figured do it once and do it right, all AN and braided stainless lines on my build, its actually very easy to put together. The rubber line is alright for short distances but its very susceptible to the elements and damage from chaffing or rubbing, i'm sure it breaks down over time. Plus you would probably use 4 times as many clamps to secure it to the frame as its not very rigid.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 03-11-2014, 06:18 PM   #5
dman1982
dman1982's Avatar
I totally understand, I just need to get it over to him to get the right lines, and from the prices I seen on summit and jegs this guy isn't much more, my biggest concern is my gears, trying to get someone to give me a hand, I don't wanna have to pay someone to do it
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-11-2014, 07:14 PM   #6
ls1nova71
ls1nova71's Avatar
I generally as a rule don't tell people to do it with rubber hose because its so easy to do it wrong and I don't want someone coming back and saying their truck burned up because I told them to do it that way. Look at this thread about the wrong way/old hose and you'll see my point. He used old lines, not sure how they were attached, but keep this in the back of your mind. http://ls1tech.com/forums/conversion...-disaster.html That said, my Nova has rubber fuel injection hose and fuel injection clamps in the flex points between the hardline. Double clamped on both ends and a bubble flare on the steel line to keep the hose from being able to just blow off. If you use MOSTLY steel lines, SECURE them good and bubble flare the ends of it, it will be fine. DO NOT just slide the hose on a steel line and clamp it! Also, always make sure no lines rub anything, this is important! Done right its fine, and my Nova with 120k on the swap is proof of that, done wrong, and its a recipe for disaster. Just something to think about.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-11-2014, 07:35 PM   #7
dman1982
dman1982's Avatar
I pulled all the old lines out today, I'm going along the drivers side with all the fuel lines, but it's also like I said above, I'm only doing this till I can get it running and get the better lines put in, I'm trying to do this as professional as I can with the little know how I have on this subject, I'm pretty worried about leaks is the only reason I'm having this guy do it which is a professional business, this is the only thing they do
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-11-2014, 09:55 PM   #8
Ebstard944
Ebstard944's Avatar
Over on ls1tech on hybreds and conversions page 1 or 2 there is a guy with before, during, and after the fire. I think it is a Nissan 240. I don't know, or don't know about using the rubber hose, but that is what he is talking about in his post.
Ebstard944 is offline   Reply With Quote
Old 03-11-2014, 10:02 PM   #9
Ebstard944
Ebstard944's Avatar
Old 03-11-2014, 10:44 PM   #10
truckdude239
truckdude239's Avatar
I did all brained line and was worried sick as I'd never done it before but I had no leaks
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-11-2014, 10:56 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by Ebstard944 View Post
Thats the exact same link Ls1Nova posted a few posts up.
Old 03-11-2014, 11:41 PM   #12
Ebstard944
Ebstard944's Avatar
Whoops, my bad. I thought I was caught up.
Old 03-12-2014, 10:46 AM   #13
dman1982
dman1982's Avatar
gotcha...ill just get all the measurements i need, haha, don't want all this work to go up in smoke!!!
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-14-2014, 05:08 PM   #14
jorgensensc
jorgensensc's Avatar
This is what I used:
http://www.thetoolwarehouse.net/p-64...paign=Product&
Easy as pie!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-14-2014, 08:40 PM   #15
dman1982
dman1982's Avatar
Originally Posted by jorgensensc View Post
and this had everything you needed to do your fuel lines?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-14-2014, 08:48 PM   #16
jorgensensc
It had everything I needed for a single fuel line system. I think I had to buy a short stick for the c5 fuel filter/regulator. Worked great for me. I liked it a lot.
Old 03-14-2014, 08:50 PM   #17
dman1982
dman1982's Avatar
short stick?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-14-2014, 08:51 PM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by dman1982 View Post
short stick?
I assume the little 6" pieces of brake line on the parts store rack.
Old 03-14-2014, 08:52 PM   #19
dman1982
dman1982's Avatar
oh gotcha...you happen to have any pics of your system?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-14-2014, 08:59 PM   #20
jorgensensc
A short piece that plugged into the fuel pressure regulator. It only cost a few bucks at the parts store. I think 10 or 15 dollars. The kit is pretty easy to use and it came with the cutters and crimpers. It was cheaper and better than rubber lines and clamps. Maybe not as great as steel lines, but I suck at flaring and don't exactly have the quality tools necessary for custom fuel lines. Besides, late model vehicles use the same type fuel line and they spent millions on R and D.
Old 03-14-2014, 09:01 PM   #21
dman1982
dman1982's Avatar
ordering it now, and i agree, steel lines are nice, but for the price i spend on 8 feet of steel line i can get about 2 of these kits, oh id you have any pics of your fuel line set up by chance?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-14-2014, 09:06 PM   #22
jorgensensc
It was a very simple setup. I don't have any pics, but I may be able to get some in a day or two. And yes br3w is right. That is what the piece was. I will try and get a part number for you when I get the chance. Hope this helps some!
Shawn
Old 03-14-2014, 09:10 PM   #23
dman1982
dman1982's Avatar
heck ya it did, i just got done ordering that kit, ill be looking forward to getting the rest of the stuff i need for the fuel system...hopefully by the end of next week ill be ready to drop the motor in
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-15-2014, 03:24 PM   #24
ls1nova71
ls1nova71's Avatar
Im actually using a Dorman fuel line repair kit right now. First time I've used it so I haven't recommended it to anyone just yet, but does seem to work alright. I'm using both steel and nylon lines though, as I have to run the lines in places you can't secure it very well and would be afraid the nylon would rub through over time if it wasn't secured well. The down side to it is it's hard to get the nylon line, which comes coiled up, to straighten out, and there's no way to bend it in a tight radius. You can make bends in it since it's flexible, but sharper bends are only possible by clamping it in place with several clamps. I would recommend to anyone planning to run nylon the whole length of your truck, to clamp it with some Adel clamps (the rubber covered metal clamps that you can buy at the hardware store) every 18" or so, and to make sure NOTHING is rubbing the line anywhere.
Here's the kit I have, and some pics of my Blazer frame.
Old 03-15-2014, 04:29 PM   #25
dman1982
dman1982's Avatar
How did you do the return lines?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
