Old 03-07-2015, 02:56 AM   #26
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Top removal 63 C-20
"note mice nest on roof "
I think they all came with factory installed mice and a nest!
those things have totaled more cabs......
Old 03-07-2015, 02:02 PM   #27
bcontractor
bcontractor's Avatar
Originally Posted by Captainfab View Post
A word of advise, in case you don't know. Before you weld your new roof on your cab, cover up all your glass really well, particularily the windshield. Weld spatter will stick to glass.
Yes...everything burns !!
bcontractor is offline   Reply With Quote
Old 03-07-2015, 02:06 PM   #28
bcontractor
I would look into some kind of auto body epoxy they use now instead of all of the welding....
Old 03-07-2015, 07:10 PM   #29
Softpatch
Softpatch's Avatar
..again thanks for that.
will have to weld up the holes
in the drip rail i made when removing the original roof first
then I plan on glue the new roof on
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 03-09-2015, 08:32 PM   #30
cheessee
Here's a trick for other people if they are replacing the outer skin.. If u use a cut off wheel with a thicker wheel on it u can grind the spot welds.. But that's ONLY on the skin that you are getting rid of u don't do it to the "new" skin.. Grinding them will take way less time than a normal spot weld bit... Im a collision tech and I do it once or twice a week on panels definitely saves time..just my 2 cents
1963 GMC swb sbw 5.3/4l60e porterbuilt
From middle Tennessee
60-66 hood for sale or trade for bench seat rust free nose little pin holes on top message for more details..
cheessee is offline   Reply With Quote
Old 03-09-2015, 11:00 PM   #31
Softpatch
Softpatch's Avatar
used my flat hammer to remove some of the small dent in the doner top
some welding and grinding mostly the holes i made to remove the old top
and the rusted front corners of drip rail
Old 03-10-2015, 05:59 AM   #32
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Kudos for doing this repair the right way- and for documenting the process for others
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 03-19-2015, 08:22 PM   #33
Softpatch
Softpatch's Avatar
Treated the underside of the top with rust converter Phosphorous acid
then sealed it with Rust-loc
Old 03-19-2015, 09:55 PM   #34
jdl71
jdl71's Avatar
Looks good!
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 08-13-2015, 08:47 PM   #35
Softpatch
Softpatch's Avatar
Haven't worked on this project in a while "no excuses"
I wanted to add this post link because some great advice and picture courtesy of LT1 Burb
http://67-72chevytrucks.com/vboard/s...d.php?t=679312
Old 10-11-2016, 03:40 PM   #36
Softpatch
Softpatch's Avatar
raingutter repair threads
http://67-72chevytrucks.com/vboard/s...d.php?t=719572
