Old 03-25-2014, 09:12 PM   #1
Softpatch
Softpatch's Avatar
Top removal 63 C-20
I wanted to add this to the thread i saw a few weeks back
and give props to the memebers for the post with pic's and were to get spot weld remover (Harbor freight)..Thanks
It took me 4.5 hours
spot weld remover tool
two battery packs
It's worst then I Imagine I have rust Issue
Before
Softpatch is offline   Reply With Quote
Old 03-25-2014, 09:16 PM   #2
Softpatch
Softpatch's Avatar
Re: Top removal 63 C-20
Top off
Looking down the corners Drivers side you can see the screws that hold the sail on and gas tank filler hose
Pass side look i can see the ground but that another issue
AFTER
Old 03-25-2014, 09:16 PM   #3
Lugnutz65
Lugnutz65's Avatar
You gonna find a donor roof? That's not gonna be an easy repair if you have to re-use it.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 03-25-2014, 09:20 PM   #4
Softpatch
Softpatch's Avatar
Ok looking for advice..... Were do I go from here
Try to repair this top.?
Find another top .?...will 60-66 fit same.?
Scrap this cab and go with another because rust issue is to far.?
thanks in advance for any imput...Sp
Old 03-25-2014, 09:22 PM   #5
NEWFISHER
NEWFISHER's Avatar
PM LT1burb, he has a top section, another A/C cab etc.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 03-25-2014, 10:32 PM   #6
Softpatch
Softpatch's Avatar
thanks for the info
having trouble sending a P,M,
(The server is too busy at the moment. Please try again later.)
Old 04-03-2014, 04:31 PM   #7
Softpatch
Softpatch's Avatar
Ok found a really nice upper Cab Skin
on a 1964
My question is
Will a 64 Cab Top Skin fit my 1963 Truck?
The measurement are close
65"1/2 X 44"1/4. 12" from rear to middle crease.....Help... thanks...Sp
Old 04-03-2014, 04:44 PM   #8
aggie91
I'm just glad to be here!
aggie91's Avatar
That 64 top should fit your 63 cab. That rust does not look to bad in the pictures. I have seen MUCH worse...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-03-2014, 05:37 PM   #9
63burban
Chevy addict
Come to the Midwest, we will show you rusty cabs !
63burban is offline   Reply With Quote
Old 04-03-2014, 11:15 PM   #10
Softpatch
Softpatch's Avatar
Wink Re: Top removal 63 C-20
thanks for the feedback I have never seen your kind of rust issue
but when I pop this top I was overwhelmed my passion/ truck is in a stall mode.!
I got a smoking price on a top (64) and it looked realy good
Motivation back on track
And "When it rain's it poors"
An old friend is giving me a gift.... will post pictures if we can agree
on arrangement
(sorry for being vague)
I feel like I'm scratching a lottery ticket it's looking good.
But have one number left
Old 04-04-2014, 12:52 AM   #11
Captainfab
60-66 Nut
A word of advise, in case you don't know. Before you weld your new roof on your cab, cover up all your glass really well, particularily the windshield. Weld spatter will stick to glass.
Old 04-04-2014, 10:24 AM   #12
Jeff La
I want to take the roof off my cab when I start my restore just for rust prevention, but I don't think it's happening.
Jeff La is offline   Reply With Quote
Old 04-04-2014, 11:13 AM   #13
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I'm gonna be pulling dents outta the top of my roof...Doesn't seem rotted up there...there is some type of "sealant" in the gutters around the cab.
Glad your able to find a new top for a good price.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-04-2014, 12:39 PM   #14
Shaky
Six in a row makes it go...
Shaky's Avatar
If you look at the '67 thread in my sig line, you can see I did a similar thing with my C20.
We painted the inside with rust paint, put some new sound deadener down, and glued a new top from a donor on (except for the back where we welded).
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-07-2014, 09:27 PM   #15
Softpatch
Softpatch's Avatar
I saw that Shaky you have skills
picked up my top today
was feeling bad about distroying another truck to save mine....
I guy at the yard put me at ease said that truck in the yard was never to see the road and was destin for the crusher by taking the top I was saving another truck from being parted out .
he was right
Old 04-08-2014, 04:36 PM   #16
Shaky
Shaky's Avatar
Yeah - I used the top of a cab that was destined for recycle anyway too.
You could probably glue that whole thing.
Old 04-09-2014, 12:56 AM   #17
Softpatch
Softpatch's Avatar
my father hooked me up with this and said wear gloves
.so I applied some
found some more holes
Old 04-09-2014, 09:41 AM   #18
aggie91
aggie91's Avatar
Looks like that stuff is doing a good job on the rust. Those smaller holes should not be too hard to repair since you have the skin off.
Looks good!
Karl
The LST Challenge:
Old 04-09-2014, 10:24 AM   #19
Improbcat
Improbcat's Avatar
Thanks for all the photos of this, I'm going to be tackling a similar project at some point soonish(dent repair rather than rot) and these are helping let me know what I might be in for.
Do you know what kind of acid that is? As it seems to be doing a hell of a job.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline   Reply With Quote
Old 04-18-2014, 08:42 PM   #20
Softpatch
Softpatch's Avatar
[QUOTE=Softpatch;6610969]
on arrangement
old friend came through
I dragged this home
Old 04-18-2014, 09:32 PM   #21
63burban
Chevy addict
Nice, I think it should come to Wisconsin !?
Old 06-22-2014, 02:32 PM   #22
Softpatch
Softpatch's Avatar
it has been awhile wow did some scans
practic sealing another trunk..no success
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Old 06-22-2014, 09:58 PM   #23
hotrod66
hotrod66's Avatar
nice! is that a short bed?
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 06-23-2014, 11:45 AM   #24
Softpatch
Softpatch's Avatar
It was a short bed I really injoyed that 64 swb truck but
Wen it rains it pours.....
Here's my story and i'm sticky to it...!
I sat down after dinner a couple of weeks ago (6-4-14)
my daughter is telling she met a guy who knew my father and knew were
his old truck is.......
You just can't make this stuff up... So I stepped up
(please read my thread)
Old 03-07-2015, 12:13 AM   #25
Softpatch
Softpatch's Avatar
11 Month's later....
I'm at it again
1964 roof on 1963 truck
Removed the spare roof today took 4 hrs
and then test fit it on the truck
some pictures of the day...Sp
note mice nest on roof
test fit 64 roof on 1963 cab...looks good
