#26 |
Re: anyone running turbo?
Hell, even a stock 5.3L is pushing 300-325 hp, and goes pretty good.
#27 |
![]() Join Date: Jul 2012
There is a local 2010 camaro that is running a 800+ hp LS and you hear him coming. It sounds like an old carbed BBC. I don't know what his mpg is but it drives it enough that it must be close to stock.
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
#28 |
Lmc truck is where Im lookin at for most of my parts I know that some people has had bad service with them but I've bought most of my parts from them including a new gas tank and fuel pump and both look great and nothing going wrong with them yet.
On that note they have everything I need to have front disk for 3-400 and extra hundred for performance slotted drilled disk and 300 for master cylinder, and I will be changeing all lines as I get to it that's not a big deal their not too expensive. Their rear disk setup is 999.89 right at a grand I would figure fronts to cost more too but that's not what the book says. I'm buying a 5lug drum axle this week I'm going to strip it and get limited slip gears and rebuild the axle sand blast and power befor I put it in... That will cost around 12-1300 then rear disk jumping it up to another grand it would be nice but just not sure yet. I like punching it every now n then n gettin a little side ways on the corners like I said not much for the top speeds any more been there done that it was fun and it was freighting I don't plan on going over 100 anymore.. I've looked up some 383 I've found a 325hp but it jumps to 405hp is there nothin in the middle there? Aren't the ls really electrical? I plan on getting like a dokata digial for a slick look but how easy is it to hook a ls up? I haven't checked into them yet at all ill do that now. |
#29 |
It's a three wire hookup (12v power, ground, 12V+ hot in run, and starter signal) when you send off the harness to be re-worked. There are some wiring for gauges and cruise if you want it. Really not bad at all.
#30 |
Do they have ls creats with just the main drive pulley? I don't need do ac I like the windows down all I need is accl fan and alt pulleys I don't need all the other bull crap on therei got the vent windows and I'm gonna get a slidin back glass that's enoghf air for me and it's free hah
I'm needing a creat engin for this one bedding to get it droped in quick ill build for my other projects but I'm needing to get this one done quick I'm gonna be building my house n shop n need to save up for that so I'm trying to get this one done. |
#31 |
What all do they do to the harness when I send them off and should I buy new ones to send in? Mines all messed up I was gonna but new ones n it would just hook up
#32 |
On the LS engines, the AC is on a separate drive all together. So you just remove the compressor and belt. Done.
#33 |
How would they compare in sound a 383 310hp with long tube headers vs ls 327 327hp with long tube headers?
#34 |
#35 |
If you are actually serious about this thread an LS is the only way to go if you want a turbo setup. If all you want is to be loud and obnoxious driving down the road get yourself a useless 350 and put some glass packs on it!
Troll away my young friend, troll away! |
#36 |
Hey......I resemble that remark.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
#37 |
